Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Airplanes > General Electric Discussions
Old 11-05-2009, 12:06 AM   #1
pstrdenver
pstrdenver's Avatar
Friends: (7)
Default reversing servo travel
can you reverse servo travel when you have atransmitter that doesn't have that option?
I have a HeliMax Axe Cx that needed a replacement servo but it travels the wrong direction. The TX does not have servo reversing capabilities that I can find.
Any thought?
Thanks!
"You can have your dreams or you can have your comfort but you cannot have them both." ---Bruce Wilkinson
www.michianaccog.com
pstrdenver is offline
Old 11-05-2009, 12:26 AM   #2
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery33
Club: Silent Electric Fliers of San Diego & Miramar RC Flyers of San Diego
Globetrotter Pilot  AP Contest Winner  3kW
Friends: (35)
Any thought?
Thanks!
Servo reversers are common
http://www3.towerhobbies.com/cgi-bin...&I=LXAFN1&P=FR
http://www.aeromicro.com/Catalog/dio...er_3975198.htm
Electricity... It's not just for light bulbs anymore.
Project Globetrotter Participant 7/09
Wings Across America Participant
AirfoilZ Factory Field Rep
BMK Designs BMK Designs
Nitro Blast is offline
Old 11-05-2009, 03:58 AM   #3
MustangMan
MustangMan's Avatar
WAA-08 Pilot
Friends: (7)
If for some reason you can't use an external device like Nitro referenced it's usually possible to reverse a servo direction by swapping the two "end point" wires on the position sensing potentiometer. PM me if you have to go this path, but I'd suggest looking at the external device first.
MustangMan is offline
Old 11-05-2009, 02:48 PM   #4
Matt Kirsch
Matt Kirsch's Avatar
You need to swap the wires on the motor too.
Matt Kirsch is offline
Old 11-05-2009, 05:01 PM   #5
Sir Raleigh
That transmitter looks similar to the ones supplied with a lot of RTF planes. On those transmitters there are a row of switches to the left of the off/on switch for reversing servos (see image).
Try this...
Press down on the label to the left of the off/on switch and see if retangular impressions are left where the openings in the case are that allows access to the switches. If so, you might try cutting out one of them to see if there is a switch inside.
If you find the impressions, and there are 5 of them, they are in this order, left to right:
V-tail mixing on/off
Channel 1 Reverse
Channel 2 Reverse
Channel 3 Reverse
Channel 4 Reverse
If there are only 4, then the transmitter doesn't have V-tail mixing.
Bill
Name:	E-FLY Transmitter.jpg
Sir Raleigh is offline
Old 11-05-2009, 05:10 PM   #6
Nitro Blast
Friends: (35)
I bet that he has this set:
Old 11-05-2009, 05:21 PM   #7
Sir Raleigh
Yep, and I'll bet the servo reversing switches are located under the Heli-Max lable next to the off/on switch.
That transmitter looks just like the one that came with my Wing Dragon 4 except without the servo switches showing.
Bill
Old 11-05-2009, 06:48 PM   #8
Nitro Blast
Friends: (35)
Bill
I'd take that bet! I have seen crystals hidden behind metal stick on badges but not switches. It would be a first for my eyes (not saying its impossible at all, just I've never seen it). In this case it appears the crystal is on the front panel, opposite the on/off switch. I honestly dont think this radio has reversing when finding details online.
pstrdenver, have you looked into the battery compartment? Sometimes reversing switches are inside there.
Old 11-06-2009, 12:57 PM   #9
Rodneh
Also, different brands of servos travel in opposite directions; for instance, a Hitec and Futaba will go in opposite directions with the same input. To electrically change the direction a servo goes, you must open up the servo and interchange the two outer wires on the pot and the two wires to the servo motor. This may be difficult if the motor is directly attached to the PC board inside the servo. If it is attached by wires, it is fairly easy if you can solder well.
Rodneh is offline
servo travel not equal Jetskeeter RC Radios, Transmitters, Receivers, Servos, gyros 3 08-03-2007 06:06 PM
4 in 1 blown by reversing a servo? vortex05 Micro Sized Electric Helicopters 17 06-27-2007 02:37 AM
Servo Reversing Laggard Beginners 8 05-04-2007 03:17 PM
Servo travel 150% ? rdjay RC Radios, Transmitters, Receivers, Servos, gyros 2 12-19-2006 06:52 PM
DX6 Servo Travel TexasRCFlyer RC Radios, Transmitters, Receivers, Servos, gyros 11 07-04-2006 07:11 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.26501 seconds with 38 queries
