Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > General Topics > RC Radios, Transmitters, Receivers, Servos, gyros
Old 11-07-2009, 12:51 PM   #1
Phil Alvirez
Club: Sun Parlor of Windsor
Default DX6: disabling throttle for electric airplanes
I would like to freeze the throttle on my electric airplane by using the gear switch (so i can keep flying without current to the motor), or have my plane on the ground with the switch ON, without the chance of starting the motor by inadvertently moving the throttle stick.
1.-Is there a program to do so?
I know that i can use the flap switch for this, if i change to heli mode, but i need it for changing trim on climb and glide.
2.-If not, is there a program for using the throttle cut button for freezing the throttle?
(In this case, i would replace the button with a toggle switch)
This is a safety feature for electrics that i believe should be included in all the radios, just as the throttle cut for engines (IC) is included in the DX6 and DX6i.
Phil Alvirez is offline
Old 11-07-2009, 04:05 PM   #2
aramid
The only easy way I can think of is using the throttle cut button. You generally have to set it up in the menus before it'll do anything at all, but once it's activated it will kill the throttle whenever it's held down. If you soldered in a new toggle switch it should do exactly what you're looking for.
Another possibility is to put the ESC on an auxiliary channel and mix that to throttle, so when the mix is turned on with your choice of switches, throttle signals make it to the ESC and when the mix is turned off there's no link between throttle movements and ESC response. You'll have to test this approach carefully, though, as there's a chance it'll want to go to half-throttle whenever the mix is turned off (since that's neutral for a servo, which is what would normally be connected).
aramid is offline
Old 11-08-2009, 08:16 PM   #3
pilotpete2
Pilotpete2
pilotpete2's Avatar
If you use a mix to run the ESC on another channel, you will also lose the throttle failsafe
Pete
"If the women don't find you handsome, they should at least find you handy"
Red Green
pilotpete2 is offline
Help , I need a throttle spring for a DX6 !! Jbreddawg Radio Equipment For Sale & WTB 1 06-29-2007 03:04 AM
DX6 Throttle Cut TexasRCFlyer RC Radios, Transmitters, Receivers, Servos, gyros 1 04-30-2007 04:35 PM
Spectrum DX6 throttle setup? rcelano RC Radios, Transmitters, Receivers, Servos, gyros 0 03-31-2007 08:03 PM
Initial MX400 Pro throttle/pitch curves on the DX6 Chickenhawk Beginners - Helis 3 09-14-2006 05:05 AM
Are there any magazines on Electric RC Airplanes? Grasshopper General Electric Discussions 17 03-02-2006 05:55 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.18699 seconds with 23 queries
