Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 11-13-2009, 09:13 AM   #1
Wrench66
Ya' need to use mo rudda!
Wrench66's Avatar
View Wrench66's Gallery33
Club: Chino Renegades RC Flier's
Friends: (20)
Smile F-86 Sabre Jet pusher build
Well, here's another build that I've wanted to do for quite a while....even longer if you count the years I wasn't flying RC aviation yet..LOL.
I do like the look of the Sabre Jet, just something about it says "Fighter Jet" to me. I can remember back when I was still in grade school drawing pictures of these old first gen fighter jets.......always liked that sinister looking open nose too!!
I am using a different method with this build in that I already have a wing for it designed and flown many times with great success.......it's a blue foam flying wing When I was building the wing, I noticed something looked very familiar about it's shape, the sweep was triggering an image of an F-86 in my mind (that was back in March....I can repress the thoughts no longer! ) so I recently set about making a plan to build an F-86 fuse to go with that wing. The plane will be a pusher jet, wing span of approx 32in, length of 31in and will have just elevon controls like the wing to start but may do a flying tail when the build comes to that stage
I have no way to scale up the pics I have, so I ended up drawing the fuse profile freehand this evening on three 8.5x11 cardstock taped together. The fuse will be built with a much proven method of using 2in blue foam forward monobloc in a 6mm Depron box style that I have been using with great success lately.
NOW since I drew the fuse and am using a slightly different shaped wing than the orig, it may not be exactly "scale" but I am excited to get started and get MY Sabre together. As far as power trains go I am starting with the same setup I have been running in the wing.....Suppo 2208 1800kv with APC 6x5.5 prop, Rhino 1750mah 3s and have been good for approx 70-80mph.....not too bad for a $8 motor
HOPING for a sub-20oz auw but we'll see...I tend to overbuild and pay for the extra pork in lower speed and runtimes
--Ray
ID:	113272 Printed a three view, hand drew the scaled up version
ID:	113273 Using a 31in 3x8x3x8 stick to mock up where the motor will be in relation. The fuse looks about the right size for that wing
ID:	113274 I think the wing sweep is a close enough angle to use, I will be trimming the TE a bit more to match the real wings angle better.
Name:	F-86 Sabre Jet.jpg
ID:	113275 Hope it looks something like this one when it's finished....LOL.....well at least hope it flys well if not! hehe
Man, gravity is ALWAYS wanting something from me
Wrench66 is offline
Old 11-13-2009, 02:55 PM   #2
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
Sounds like a plan Ray!
One thing you can do to get a larger profile drawing is to take you 3-view to FedEx/Kinko's or ScottBlue or some other printing shop, and just have them blow it up. Costs about $5-10.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 11-14-2009, 07:51 AM   #3
View CHELLIE's Gallery13
Friends: (281)
Its looking Great so far Ray I know you will do a Super Nice job on it, the F86 Saber is one of my favorite planes Take Care, Chellie
Old 11-15-2009, 01:54 AM   #4
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
View Alpea42's Gallery59
Friends: (25)
If you need some 1 and 1/2" thick Dow blue let me know. Still got some.
THE B-2 Worlds most expensive airplane.
Alpea42 is offline
Old 11-15-2009, 06:36 AM   #5
Wrench66
Wrench66's Avatar
Friends: (20)
Thanks Al, but I have quite a bit still from the last "raid"..
Got some work done on the fuse tonight. I am thinking of doing a flying tail on this one, the later D models had it
I need to get started on building the wing for it as I now need the actual shape of the airfoil to then cut the wing saddle.
--Ray
ID:	113363 2in thick piece of blue foam, yet to be trimmed to make a forward battery cradle
ID:	113364 depron fuse formers and rear motor mount glued in
ID:	113365 I'll get the fuse glued together then build the wing and cut the saddle to match.
Wrench66 is offline
Old 01-30-2010, 01:24 AM   #6
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
o.k. what happened???
iflyrc1012 is offline
Old 10-29-2012, 02:31 AM   #7
Lord Vader
What happened to this thread? I would like to see pics and maybe some plans.
Lord Vader is offline
Pink Pusher Jet Build CHELLIE Foamies 225 07-19-2012 08:54 PM
EDF pusher Jet scratch build- contest 2 CHELLIE Electric Ducted Fan Jets 53 09-26-2010 11:47 AM
Wanted Alfa F-86 Sabre horizontal stabilizer algon Airplanes - Electric For Sale & WTB 0 06-11-2009 10:48 AM
any building advice for the Alfa F-86 sabre? mlamb01 Electric Ducted Fan Jets 1 12-04-2008 11:35 PM
Nitro Models F-86 Sabre-140 bdelmo Electric Ducted Fan Jets 7 10-16-2008 04:02 PM
Page generated in 0.34659 seconds with 33 queries
