Old 12-11-2009, 03:30 AM   #1
Flite-Metal
"Look Of The Real Thing"
Flite-Metal's Avatar
Club: Fort Bend R/C
Scratchbuilders Award
Default B-47, 1/8.7669 Scale Boeing Stratojet, In The Beginning
PHASE I: The Work-Up Begins...aka In The Beginning
Does anyone have interest in the Boeing B-47?
Welcome to a B-47E-IV construction project. I and Sam Collins are working our way forward on a pair of
Stratojets. This has been an exceptionally fast ramp up from research to the initial design phase.
It is my intention to share resources to enable anyone interested in replicating a B-47E-IV to be able to
do so from this thread.
This project has grown from an original 1/8th scale to 1/10th, 1/11th, and ended as a 1/87669. Why?
Here's why and how...
First the datum lines:
Project Preamble: Please read and determine for yourself how the following applies to you, the reader:
Any and all persons reading this discussion must come to their own determination of the safety and wisdom
of emulating or replicating
any and all aspects of what is described within this discussion.
This includes, but is not limited to your own decision on the safety of and whether you should be involved
in this or these activities and
any processes or use of equipment related to recreating what is, or has been
discussed here-in by subscribers to WattFlyer, the host of
this discussion.
Neither the author of this topic nor WattFlyer are responsible for proper or improper use of, or correct or
incorrectness of any process
activity undertaken by any one or all readers of this construction thread.
*As in all modeling activities, reader beware of your abilities to either properly or improperly apply the
principals described here-in. It is
impossible to declare whether this activity is or is not proper for readers
of this discussion.
Airframe #1:
1000th B-47 (B-47E-IV)
B-47E IV Labs Maneuver
Airframe #2:
WB-47B Weather (Cino Atmospheric "Sampling") Bomber
Airframe #3: (1 + 1 + 1 = 2)
YB-47E
First flight: Dec. 17, 1947 (prototype XB-47)
Model # 450: ( Built By Boeing, Douglas, Lockheed )
2 - XB-47
1,341 - B-47E
10 - B-47A
255 - RB-47E
397 - B-47B
35 - RB-47H
1 - YB-47C
Classification: Medium Bomber
Span: 116 ft. = 158.7790” @ 1/8.7669
Length: 107.1 ft. = 146.5969” @ 1/8.7669
Height: 27 ft. 11 in. = 38.2119” @ 1/8.7669
Power: Six 7,200 # thrust GEJ47GE25 turbojet
Crew: 3 crew ( original conf. )
Armament: One twin 20 mm turret, 25,000# of bombs YB-47E = 4 Cruise Anti-Radar Miss
Ed Clayman
"Flite-Metal For The Look Of The Real Thing"
Flite-Metal is offline
Old 12-11-2009, 03:32 AM   #2
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (86)
Oh Ya! bubsteve
Monkey Minion'air
stevecooper is offline
Old 12-11-2009, 03:41 AM   #3
Flite-Metal
Club: Fort Bend R/C
Default Stratojet
In order to do that you'll need this, or these... : )
Ed Clayman
Old 12-11-2009, 08:35 AM   #4
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
View Alpea42's Gallery59
Friends: (25)
Jimmy Stewart in The Strategic Air Command. Great movie of that plane.
THE B-2 Worlds most expensive airplane.
Alpea42 is offline
Old 12-11-2009, 08:28 PM   #5
stevecooper
Friends: (86)
looks like they worked real good!! bubsteve
Monkey Minion'air
Old 12-12-2009, 12:39 AM   #6
Flite-Metal
Club: Fort Bend R/C
Default ATO Parts
Steve,
The engines were so low on initial thrust they had to use RATO to get the B-47 off the ground when
carrying the bomb. I'm looking for 1/2 inch diameter slow burn smoke that can be ignited electrically.
There were 33 bottles on the RATO girdle.
Early 47's had internal RATO. After the E they utilized a horse collar harness which released after firing
during takeoff sequence.
Ed Clayman
Old 12-12-2009, 04:24 AM   #7
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
View Voyager2lcats's Gallery58
Club: Not Now- Maybe Never
Friends: (33)
You certainly wouldn't have had any trouble finding the B-47 immediately after takeoff with those rockets. Good lord that's a lot of smoke!
"Dum spiro spero." (While I breathe, I hope).
Voyager2lcats is offline
Old 12-13-2009, 07:05 PM   #8
Flite-Metal
Club: Fort Bend R/C
Default B-47 Thus Far
Thus far this has been learned:
Ed Clayman
Old 12-13-2009, 10:03 PM   #9
Flite-Metal
Club: Fort Bend R/C
Default We're Not The First...
Its been a productive afternoon...
As you can see, the rear mains using the Robart 160 tailwheel retract mechanism have no problem providing
proper retraction. Robart 160 up front requires change to air cylinder attachment point and alteration of the
scissors....both are a simple do.
After reviewing the Robart 160 tailwheel assembly with Sam Collins, we determined it need only the addition
of a cross tube between the bent sheet metal and a full width all-thread replacement of the pivot pins to
offset diagonal stress encountered during less than perfect landings.
The B-47 landing was best with both mains touching down at the same time. The Robart 160's have 3/8's
compression. This will be increased by another 1/4". Considering take off and landing are to be virtually
level, this should do the job.
Above...Joe Martin, of Sherline mill and lathe fame, appears on cover of '64 New England Scale Championships
program holding 80" w/s B-47D. The B-47D turboprop had comparable performance to the pure jet B-47s. Its
short coming, aka failing, was reliability.
Above is Joe at the 1965 NAVY NATs declared as a 78" w/s... Back at that time the U.S. NAVY hosted
AMA NATs at naval bases all across the U.S.
Joe, first to fly B-47 in competitive flying scale modeling, proved 36 degree sweep did not poise challenge
at the lower end of the r/c speed envelope...in 1962. Yes, you read it right, 1962. Joe campaigned his B-47D
from 1962 through '65.
The 1:1 Stratojet had yaw issues (Dutch Roll) during the landing approach which required use of a a drag
chute to reduce yaw during final approach. A second chute deployed after touch down slowed the B-47 to
enable the BF Goodrich brakes to stop it.
Calling Joe 47 years after his contest experience, I listened to a technicolor play by play that served to be
rocket fuel to my B-47E-IV aspiration. Joe's only regret...he failed to anticipate the B-47's need for a shallow
approach and landing. Joe's vivid recollection projected a visual as he described the B-47 bucking and bouncing
down the runway after contact.
Frankly, if it were not for my conversation with Joe Martin, I would not be doing this project. Joe Martin is a
true designer, builder, and scale pilot. You need only know the RC systems Joe was forced to use to gain a
HUGE appreciation for his piloting to say nothing for his design and construction skills.
Thanks, Joe! Passing the torch forward... ;^)
Name:	Joe Martin 1965 lrg.jpg
Ed Clayman
Old 12-16-2009, 04:17 AM   #10
Capt. Midnight
View Capt. Midnight's Gallery1
Default B-47
Hello Flite Metal!
What sort of model are you planning for your B-47? I recall seeing many B-47s at Boeing Field when I worked for Boeing (1951-1955), just before entering USAF pilot training. I don't recall any RATO-assisted TOs, but I worked 2nd shift, so wouldn't have seen all the flights. One of my pals from USAF pilot training was killed in a B-47 accident after we graduated.
Are you planning a 6-EDF model, and what scale?
Dave Plummer
Capt. Midnight is offline
Old 12-27-2009, 12:36 AM   #11
Flite-Metal
Club: Fort Bend R/C
Default B-47 Stratojet @ 1/11.48 aka 1/12
Dave,
Its a wee over 1/12th at 121"w/s (during this initial stage). Below are the first specs. As for RATO takeoff,
it was only utilized when nuclear weapon was onboard given runway length required it.
That was from the first EvoJet (turbine) work-up. I have moved to the StuMax 110 to reduce AUW. A pair
of StuMax in the inboard nacelles with the opposite engine bay occupied by batteries is where I am today.
This provides as much air flow across the elevator as possible at lower speeds. Landing speed being THE
issue at this point. With the EvoJet the LS would have been around 75 mph... :-(
Ed Clayman
Old 12-29-2009, 02:06 AM   #12
Flite-Metal
Club: Fort Bend R/C
I thought it would be no big challenge to find a bottle rocket size smoke bomb to simply ignite using either a
NCad or NMH onboard battery pack but its been a little more than frustrating to find.
Diameter of the RATO bottles is around 1/2 inch at 1/12th and about 1" long. Anyone have an idea what I can
use and where to source them?
Ed Clayman
Old 12-29-2009, 05:53 AM   #13
Capt. Midnight
Default Smoke 'Canisters' For B-47
Hi Ed!
Wouldn't Shorty's Basement be a good source for your smoke canisters (http://www.shortysbasement.com/index.php)?
My faint recollection is that (especially the early models of) the B-47 only needed the RATO assists for rather high ambient temperatures, when engine thrust was reduced; and I think the final versions of the aircraft (with increased-thrust engines) further reduced the need for the RATO devices. But, clearly, it would be impressive to have some smoke generators for your model, and Shorty's Basement might be a help.
David Plummer
Old 12-29-2009, 07:55 AM   #14
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Friends: (168)
Hi Ed
That would be an awesome sight
You could contact RC Smoke They may be able to help
http://www.regin.com/rcsmoke.html
They are local to me here in CT and i have seen and used there products many times
They work great
Take care
Hank
kenchiroalpha is offline
Old 12-29-2009, 02:14 PM   #15
Flite-Metal
Club: Fort Bend R/C
Default Smok'n :0
Thanks Dave and Hank ! ! This site is so helpful :^) I plan to make resin canisters inserted with the smoke
generators and attached to girdle released after take off.
Well, it appears at first glance and conversation my RATO solution is found... Regin S102 with 45 sec burn
time appears to be the way to go compared to all the others I didn't find close to its size 1.25" long x .55" dia.
This is well within the fudge factor size wise. Its 45 sec burn time is longer than I need, yet it was said the ignition
is virtually instant. Here is photo of 10 to the box @ $1.4 ea.
I do not need them to burn the full 45 seconds. I plan to bandsaw these in half if not thirds to accommodate the
number needed and reduce the burn time closer to 15 seconds. They are ignited by nichrome wire across one end
from a battery.
DO NOT use LiPo batteries to ignite them...
The overall shape affords easy front end attachment and consealment within the girdle. A simple molded
resin rear nozzle facade works for static resemblence to the 1:1 shape shown above. Ignition via cross
cut of the face then span the cross cut with nichrome is going to be the simplest method...yet to be
tested. I have tons of "fused" 4kmah packs with intelligent fast chargers for onboard ignition from wireless
data terminals I sell. Those should do the trick...safely.
John at Regin took interest in my project and answered questions as best he could. Most RC applications
they sell components for are for sky writing and aerobatic maneuver enhancement. I committed to providing
plenty of witness to their S102 capabilities if it served to satisfy my requirements. Since this is intended as
a Flite-Metal poster child to begin with Regin will definately get their payback for sharing information.
Below is a visual overview that should set the level of expectation for this project.
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Thanks guys :^)
Ed Clayman
Old 12-31-2009, 01:39 AM   #16
Flite-Metal
Club: Fort Bend R/C
Default D' Ageless Resource
Our project got a good kick in the rear to shove it forward with introduction of plans from the late 50's.
If you are interested you can acquire the plans from Air Age. We reviewed everything and its going to
contribute a great deal to meaned former shape as we replot the fuselage.
Retract requirement was sealed with the Robart 160 series unit altered to provide greater lateral strength.
Will show the 160's alteration as we move forward. The alteration is something anyone can do to firm up
the lateral strength of the retract frame.
Ed Clayman
Old 12-31-2009, 02:26 AM   #17
kenchiroalpha
Friends: (168)
Hi Ed
And a very happy and prosperous New Year to you my friend
Im overjoyed that you are making progress with this fantastic model
Heres some thing to inspire you
Take care
Hank
Old 12-31-2009, 03:10 AM   #18
Flite-Metal
Club: Fort Bend R/C
Default New Resources
Hank,
Gotta love it :^)
Yes, its been a rewarding day. I finally have an auditable former set that will permit me to move forward
rapidly. Considering the short turn around on resources I have it will be interesting to see how all the data
flows from the planset we received today. Its the AirAge B-47 planset published in the mid 50's. Definately
answered initial questions which could not be answered from the miltiple view line art.
Its been interesting to note the majority of the line art does not show a datum line view with concentracy...
There is a 5 degree stance plus 2 degrees of wing incidence. For some reason that confuses the artists who
are used to drawing the wing in the head-on view such that only the leading edge is seen. This makes the
fuselage forward of the wing appear to slope down and therefore does not permit the viewer to observe the
concentracy of the fuselage.
Ed Clayman
Old 01-01-2010, 10:17 PM   #19
Flite-Metal
Club: Fort Bend R/C
Default CNC Multi-Axis Hotwire Cutter Needed
I considered using a multiple-axis hotwire cutter for each section of the model. It is important that they are in the hobby to
reduce amount of error due to mis-communication.
There are three fuselage sections...
A). Nose back to last full panel ahead of wing centerline appex within fuselage.
B). Rear section just forward of the vertical fin leading edge intersect with fuselage rearward to rear most point.
C). Center section between above portions.
Within the fuselage I plan for a truss supporting the above three sections of the model.
Ed Clayman
Old 01-01-2010, 11:26 PM   #20
View CHELLIE's Gallery13
Friends: (281)
I rapidly approach the need to find a multiple-axis hotwire cutter who is in the hobby. It is important that they are in the hobby to reduce amount of communication relative to detail.
1). Nose back to last full panel ahead of wing centerline appex within fuselage.
2). Tail forward to where fuselage width and height remain constant.
3). Center section between above portions.
Within the fuselage is a tig welded truss supporting the wing, and the fore & aft main gear.
maybe these people can help you, Hope that helps, Chellie
http://www.flyingfoam.com/
http://www.rcsoaring.com/manuf.shtml
Old 01-02-2010, 12:45 AM   #21
Flite-Metal
Club: Fort Bend R/C
Chellie,
Thanks, I spoke to Bob Mellon back some time ago and he was "not into cutting fuselages" from high density
Styrofoam
. I was very surprised that he was not eager to do it. He does wings and that appears to be all he
wants to do.
Fuselages require a tremendous amount of double checking over a multi-datum line alignment matrix. Checking
multiple times before cutting is a must or the trash gets full fast.
I failed to find any reference to CNC multi-axis on the second site.
Ed Clayman
Old 01-02-2010, 06:38 AM   #22
Friends: (281)
no job to small or big they claim
http://www.wecutfoam.com/
Foam Cutting and Composites Services
We-Cut-Foam specialize in customized foam cutting out of almost every foam available, No project too small or to large, with projects
ranging from a few inches to 20' x 30' full 3D shapes.
Full scale racing car, full scale truck and even airplane fuselage
Old 01-02-2010, 06:28 PM   #23
GGRN
GGRN's Avatar
Club: Les aigles de Moroges, FFAM (Moroges Eagles, Fédération Française d'Aéro Modélisme)
HI guys ! Happy new year to all !
As for me, great interest for the Stratojet ! I've started building one for 6 GWS EDF 50 and feigao 5300Kv... 2, 00 meters long, 2,30 meters WS, retracts. I'm targeting a final weight of 2 kg...
Here are the firsts pics of the build... All the airframe will be out of 3 mm depron, with some plywood reinforcements where needed : Something as simple and light as possible to save some weight. Just have some uncertainity about the CoG location... Where would you locate it ?
Greetings from Paris
Philippe
GGRN is offline
Old 01-02-2010, 07:36 PM   #24
Flite-Metal
Club: Fort Bend R/C
Default B-47 CG Calculation
Originally Posted by GGRN View Post
HI guys ! Happy new year to all ! As for me, great interest for the Stratojet ! Just have some uncertainity
about the CoG location... Where would you locate it ? Greetings from Paris Philippe
Phillippe,
Here are my two CG calculators from ScaleAero.com:
http://www.scaleaero.com/CG_Calculator.htm
http://www.scaleaero.com/mac_page.htm
The CG on the planset I am using as an audit tool is 9" from the wing apex with a sweep of 35+ degrees
on a 57" w/s. This position should be weighed agains the calculators. My 121" w/s is a 2.1228 ratio to the
measurements on the (AT THIS SCALE) 57" 50% w/s. As we progress the w/s of our model will change as
we work through all components.
As for your use of Depron. I do not want to assume anything...it appears you have used XPS to skin built
up wood structure instead of using balsa or obeechi skinned hot wired foam.
The most critical element of the B-47 is the wing root and fixture mechanism to enable a multiple piece wing
to be used. I am creating a fuselage truss from which my wings are suspended. It is designed as an internal
T&C component.
Looking at this from one end looks like a vertical diamond polygon. There are two telescoptic sections to the
truss. Each section is bonded to a hot wired cavity within each fuselage section. Each of the three sections
telescope to permit proper break-down for transport.
As for CG, Boeing provided Dave with this illustration showing 25% of MAC within it.
Ed Clayman
Old 01-03-2010, 03:29 PM   #25
Flite-Metal
Club: Fort Bend R/C
Default PHASE II: Refining Airframe Sectional Shapes
January 3, 2010 marks phase II for this project. All the raw resources I have collected-to-date are refined,
not unlike oil when it first comes out of the ground.
From this point forward, the process is a series of audits to mean out all but what is deemed "the" proper
shape. Remember we are dealing with art and individual interpretation by each artist as they drew multiple
points of view. It is extremely important you read and understand the next paragraph..... <l:^0
In "every drawing set" I discovered none of the individual perspectives (head-on, side, top-down, bottom-up,
& rear-on) views~drawings were drawn with accuracy of scale...to each other. As you move forward, all
perspectives are being rescaled and meaned to a composite illustration. It is absolutely necessary every view
is sized properly. Otherwise guys, they are useless... Go check your favorite three view and see what I mean.
If all I wanted was a simple three or more view of the B-47.....I've found there are several out there.
These become the tools with which to work-up and derive a meaned set of refined tools to build a B-47E-IV
model. This is not to say this is "the" way or how it should be done. I'm saying this is the only way I know of
achieving this without a laser scanner.
At the beginning of this thread this was my infant work-up. Today, I work with everything gathered to create
"the project image master" and a measurement index.
Sam Collins is my partner in crime. Sam shared my interest in the B-47 and wanted to
build one the same size with edf for power instead of BB's quest to build it with six turbines. After I worked up
a B-47 powered with a pair of EvoJet turbines the AUW brought me back to edf.
After our last skull session, Sam was left working mechanics of the flaps. Later today I'll send wing bottom-up,
rear, and head-on view at scale for Sam to work with. Our last conversation had us headed down a path to a
pair of carbon fiber tube-in-tube for alignment and a tilt-mechanism with a laser cut and channel lined cam
path either side of each flap section. I more or less stole this from a friend's Tu-95. George Maiorana's Tu-95
is shown on my YouTube flap focus.
YouTube Video
YouTube Video
YouTube Video
I'll be back and share as this moves forward... :^ )
Ed Clayman
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Boeing 747? CygnusX1 Electric Ducted Fan Jets 12 05-30-2009 03:56 AM
Need 3 View Of Boeing B-9 Bomber Tucson Don Foamies 3 02-24-2008 03:45 PM
BOEING 777 AIRBUS by Dragonfly?! reyes ParkFlyers 6 04-26-2007 03:21 PM
Airliner Plans Boeing 727 CarreraGTSCS Airplanes - Electric For Sale & WTB 1 06-21-2006 04:35 AM
Boeing 314 clipper mc2th Seaplanes E-Powered 5 04-01-2006 11:54 PM
Page generated in 1.35683 seconds with 84 queries
