Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > FMA Direct
Old 01-18-2010, 10:10 PM   #1
Tim Marks
President FMA, Inc.
Default Sneak Peek at the NEW Cellpro PowerLab 8
UNLEASH THE POWER!
POWER you have been waiting for, SAFETY you have come to expect in a Cellpro!
INTRODUCTION:
Well we have been at it now for around 15 months all told. We’re getting anxious to let the world know what we’ve been focused on for all this time. It’s time to let the cat out of the bag and give you a sneak peek at what’s heading your way.
Welcome to the new thread dedicated entirely to an open discussion about the new FMA/REVOLECTRIX Cellpro PowerLab 8 Battery Workstation. Not only is this thread about an exciting new product, it represents a new concept for FMA Direct. Of course we have always been diligent about beta testing our new products carefully to ensure they work as advertised when they hit the streets, but this is the first time we have been inclined to open up our beta test program to our valued customer base in advance of the anticipated product release date. What’s even more unusual is that we are choosing to tell you all about this awesome new unit not through advertisements, but through the words of our dedicated and capable PowerLab 8 beta team members. Collectively, this group represents more than 100 years of modeling experience and work with electronic instruments and testing. This unique thread is being started by FMA Direct, but it will be monitored by the beta team. You are invited to ask technical questions or inquire about available features to your heart’s content. Answers will be supplied by team members who now have logged cumulatively, thousands of happy hours with the prototypes each has received. From time-to-time, we may step in to offer assistance in this regard; however, for the most part, this is their thread. ENJOY!
Meet the Beta Team:
Glen Crandall
Jack Doherty
Charles Langley
Heyward Macdonald
Steve Meliza
But before you start asking questions, take a quick look at the specifications and the feature set of this ground-breaking new battery management system:
PowerLab 8 Specifications:
For Battery types: Lithium Polymer (1s to 8s balanced, 1s to 2s unbalanced), Lithium Ion (1s to 8s balanced, 1s to 2s unbalanced), Lithium Manganese (1s to 8s balanced, 1s to 2s unbalanced), A123 (LiFePO4) (1s to 8s balanced, 1s to 9s unbalanced), NiCd (1s to 21s), NiMH (1s to 21s), 6v, 12v, 24v Lead Acid batteries (Flooded, Gel, AGM, SLA)
Pack capacity: 20 mAh to 360Ah
Input voltage: 10-32VDC, reverse polarity protected
Input current: 1A to 50A, software limited
Power conversion: Synchronous DC/DC converter, supports multiple switcher frequencies of 31.25 kHz, 62.5 kHz, 125 kHz; user selectable by preset, 85% to 93% efficiency depending on output current
Output battery charge current: Adjustable range 10mA to 30A, limited by 50A input current*
Output battery discharge current: Internal discharge 10mA to 10A, 100W max
Regenerative discharge 10mA to 30A, 1000W max**
Continuous max output power: 516W @ +12VDC input, 1008W @ +24VDC
Cell balancing: Resolution 78uV (16 bit) for 1s-8s Li or A123 (LiFePO4) balanced charging
Voltage calibration: Cell voltage measurements are factory calibrated to a standard traceable to NIST; calibration is to +/- 6 mV
Current calibration: Charge current is factory calibrated on a 4A standard; calibration is to +/- 1mA
Measurement accuracy:
Voltage resolution: 78uV (16 bit)
Voltage tolerance: +/- 6mV
Charge current: +/- 1%
Capacity added to pack: +/- 1%
Percent capacity (“Fuel”): +/- 5% (with accurate fuel table defined for battery being charged)
Serial data output: 19.2kbps, 8 bits, 1 start bit, 1 stop bit, no parity
Data integrity: Checksum, CRC checking
Cooling fans: Twin, 13 CFM, 50mm diameter
Heat sink: Internal 200W aluminum, thin finned
Output battery connector: “Cellpro” compatible, JST PA series, 9 position
LCD: 2 line, 16 character, light grey/blue backlit
Footnotes:
* Please note, for safety reasons, available charger current may be limited for certain battery types and/or charging modes, e.g., non-balanced charge of Li
** Please check bullet number 8 in the section titled “Major Features” below for a detailed description of Regenerative Discharge
PowerLab 8 Feature Set:
Major Features:
• Selectable charge rates range 10mA to 30A
• Continuous maximum output power rating, 1008W @ +24VDC input voltage, 516W @ +12VDC input voltage
• Using +24VDC to +32VDC input, 1008W output will deliver full current rating (30A) over the full range of output voltage up to 33.6V
• Smart power management allows customer to select between programmable input power sources. Using the Charge Control Software (CCS), choose from several templates to get you in the ballpark, then fine tune the settings. Available settings include power supply input current limit, input low voltage limit, regenerative discharge rate and voltage limit. PowerLab 8 stores 1 set-up for Power Supply and 1 set-up for Battery and asks for verification one time on start-up
• PowerLab 8 supports charging through node wires only (automatic current limiting to 3A maximum) or node wires in combination with discharge wires (charge rate support up to 30A max)
• Initiate charge, discharge, monitor, and multiple cycles at the PL8 or via remote control from the CCS. Graph all major operations when using CCS.
• Open Architecture presets allow for customization of any User Preset including show/hide presets on unit, preset name editing, up to 100 parameters control how presets are displayed and charging/discharge/cycling parameters associated with particular batteries and/or charging strategies. Unit includes 25 user preset banks pre-loaded for most major battery type/chemistries, plus 50 library presets.
• Environmentally friendly, industry first, regenerative discharge capability of up to 1000w. Unlike traditional methods of discharge, which deplete the output battery’s energy in the form of heat across a transistor, regenerative discharge takes most of that energy and puts it back into the input battery. In other words, when you discharge your LiPo for storage, you will be re-charging your Lead Acid input battery. The total amount of power that you can achieve is limited only by the amount of current that your input battery can accept, or 1000W, whichever is lower.
• PowerLab 8 is also equipped with a traditional, 100W internal discharge capability which is non-regenerative.
• Twin cooling fans
• Massive over-sized internal heat sink
• 10AWG silicon input power cable and heavy-duty, removable plier clips
• Massive sendust core toroid capable of 50A continuous input current requirement for maximum output specifications
Other Features:
• Supports native Cellpro batteries automatically
• Adapters available for all popular R/C battery brands
• 2 line, 16 character backlit LCD
• Available opto-isolated PC interface and free Charge Control Software (CCS)
• Intuitive 4 button user interface
• Sleek and attractive high-impact ABS enclosure for maximum airflow efficiency
• Sturdy Aluminum top panel with reliable, recessed tactile buttons
• Quick “preset over-ride access” to common charging parameters like setting charge and discharge current and operational modes of charge/discharge/monitor/cycle(s)
• Additional advanced options menu for adjusting in-depth charging parameters and global options at the unit
• GUI PC software (CCS) allows access to 25 User Presets and 50 Library Presets stored in the unit or available in unlimited number on the P.C.
• Free and reliable firmware updates for the life of the product using the CCS
• Automatic Low voltage restore for recovering damaged or over-discharged packs
• Programmable options allow speaker ON/OFF or volume, LCD contrast, customized welcome screen, and much more
• Cold weather mode reduces end-charge voltage; parameters adjustable by customer including ON/OFF, end-charge voltage offset reduction, and temperature
• Multiple product cases can be interlocked
• Future provisions for master/slave mode whereby one PowerLab 8 master can control one or more slaves, send over preset information, control all aspects of charging and balancing. This feature is perfect for charging multiple packs of same chemistry and capacity using multiple devices such as split packs connected in series during operation all at unbelievable rates.
• Auto charge mode available utilizing advanced fuel gauging technology
• Customizable fuel table lookup values based on presets. Fuel tables can be created using a Fuel Table Wizard in the CCS and applied to individual battery brands by presets for improved accuracy
• COMING SOON! Industry’s first Smart Parallel adapters available to maximize available power potential. Safely connect two packs (2s-6s) of equal cell count/capacity together in parallel; charge, discharge, cycle, or monitor on a single PowerLab 8. These items will be peripheral products, available separately, not included as a part of the actual PowerLab 8 unit. Also will be backward compatible with the Cellpro 10s charger.
Please note: all specifications and features listed above subject to change prior to delivery.
Price range for the Cellpro PowerLab 8 will start between $250 and $300. Delivery of first production run is estimated for Spring, 2010. Initial quantities will likely be limited. That's all we can say for now. We will of course update you as time goes by. Some customers have already begun to inquire about pre-ordering. We are not yet taking advance orders for the PowerLab 8. When we are ready for that, we will let everybody know with a bulk email announcement. If you are not already on the FMA Direct email list, you can join at the following link:
http://www.fmadirect.com/email.htm
To get a better idea of the power levels attainable using the Cellpro PowerLab 8, check the following link from the FMA Direct website which will direct you to a zip file. This zip file contains an interactive spreadsheet designed to answer several key questions relating to power supply requirements, available charge rates and/or power levels: http://www.revolectrix.com/support_docs/item_1301.zip
The manual for this product can be downloaded from the FMA Direct website in PDF format at the following link: http://www.revolectrix.com/support_docs/item_1340.pdf
The PL8 Charge Control Software (CCS) is available for download and install at the following link: http://www.revolectrix.com/new_appli..._software.html Windows program does not require that you have the PL8 in order to install and run the software. Check the on-line help with direct access to pertinent information by clicking the "?" buttons throughout the various tabs.
ID:	118484 Cellpro PowerLab 8 Battery Workstation
Tim Marks is offline
Old 01-18-2010, 10:16 PM   #2
View firemanbill's Gallery67
4kW  Globetrotter Pilot  1kW
Friends: (55)
OH MY!!!!
Where is that drooling Icon?
Bill Sorrell AMA #9303
Planning for SEFF 2011
Old 01-18-2010, 10:47 PM   #3
View Don Sims's Gallery3
Globetrotter Pilot
Friends: (30)
You folks at FMA have been busy fer sure!
Take care and thanks for posting at WattFlyer!!
Don
Old 01-18-2010, 11:14 PM   #4
heymac
heymac
Default PS-8 Beta Test Team
OH MY!!!!
I know!
As a Beta Tester, I have about 300 hours of working with it, and I am still amazed.
If you have questions about the capabilities or operation of this instrument, the Beta Team can respond. Just post away.
heyward
heymac is offline
Old 01-19-2010, 04:16 PM   #5
Jack Doherty
PowerLab 8 beta tester
Jack Doherty's Avatar
Hello fellow flyers,
FYI the people at FMA developed a "PowerLab Current Calculator" Excel spread sheet. This spread sheet can be down loaded from the following site.
http://www.fmadirect.com/support_docs/item_1301.zip
It is very helpful, convenient and easy to use. It addresses six major power supply/PowerLab questions you may have.
Jack
Jack Doherty is offline
Old 01-19-2010, 04:28 PM   #6
idealhobbies
idealhobbies's Avatar
Club: C.D.P.A.
Single pack charging only?
idealhobbies is offline
Old 01-19-2010, 04:42 PM   #7
SteveM732
SteveM732's Avatar
Club: BCRCC
Well, it is a single charger, yes. You can charge packs in serial or parallel and FMA is working to make an additional device to permit very safe parallel charging of two packs.
SteveM732 is offline
Old 01-19-2010, 05:00 PM   #8
everydayflyer
Southern Pride
everydayflyer's Avatar
View everydayflyer's Gallery13
Using parallel and series adapters and harness which I made I have charged 4 each 4S 3300LmAh LiPolys configured as a 8S2P 6600 at 30Amps. or 4.5C. That is a nonimal 960 watts output from the charger.
This was done to prove to my satisfaction that this charger would indeed meet the specification claimed. IMO configuring and using such an array is best left to those with enough knowledge and experience that they do not have to ask how do you do that.
Please do not expect me to give wiring details for these. Once again FMA is developing a safe interface for up to 6S parallel charging.
Charlles
ID:	118545 Top balancing harness for two 3S in series as a 6S, middle Dean is series and also parallel adapters. bottom 4ea. 4S in series and in parallel.
everydayflyer is offline
Old 01-19-2010, 05:48 PM   #9
MaxAdventure
AMA 198798
MaxAdventure's Avatar
View MaxAdventure's Gallery20
Club: LEAF, BAS
Send a message via Yahoo to MaxAdventure
3kW  1kW  2kW
I would assume any two pack charging would require the same chemistry? Also, can the NiCad/NiMh charging methods be described? I still use Nickle based batteries for quite a few power applications for surface vehicles, etc. I love that FMA is providing a charging solution that crosses all the different consumer chemistry!!!! I can finally dump my POS TritonII that just sits around in case I need to deal with Pb batteries.
This is sure going to be nice next to my CellPro10 ......
Like water off a ducks back...
MaxAdventure is offline
Old 01-19-2010, 06:22 PM   #10
Jack Doherty
Or even better two PowerLabs joined Master/Slave.
Old 01-19-2010, 08:49 PM   #11
everydayflyer
Southern Pride
Yes parallel charging required same chemistry,same cell count same as any single channel(out put ) charger.
As per specs. from above
Up to 21 cells Ni. peak detection , sensitivity user programmable 1-25 mV, Default Presets include Fast charge with trickle for both Ni cad and Ni cad 24 Hr. trickle. At present Max. charge rate for Ni is limited to 6 amps. which many feel is high enough.
This charger is so versatile that it is difficult to find a logical situation which can not be programed into it.
I should add that I have not tried the full range of mV settings . I have charged numerous NiMH cells and packs from 600 to 3300 mAh and it has done extremely well with the supplied Presets.
I have also charged a selection of Pb 6-24 volts and once again it has done an excellent job.. It has a Preset for Flooded cells and also one for Sealed AM /Gel and I have used all three types.
The selection of LiFePO4 I have charged range from 1100 to 2300 mAh 1-8 cells up to 4ea. 4S 2300 in a 8S 2P configuration. The selection of LiPoly charged has been from 120 mAh single cells up to the 4 ea. 4S 3300 2p (8S6600) mentioned above .
I have averaged over 10 hours per day for the past 7 weeks with it now and I am duly impressed.
Charles
Old 01-19-2010, 09:11 PM   #12
MaxAdventure
AMA 198798
Club: LEAF, BAS
3kW  1kW  2kW
Default Power Supplies
Being exited about the product, I started hunting things to feed it:
http://www.capovani.com/iinfo.cfm?itemno=79446 @ $675US
http://cgi.ebay.com/NEW-CONDOR-GPMP-...item439c3eb82f close @ 37A
http://wattsupply.com/s.nl/it.A/id.569/.f closer @ 41A and $260US
http://wattsupply.com/s.nl/it.A/id.2236/.f and it's big enough @ 62A/24V and $377US
Old 01-19-2010, 09:31 PM   #13
SteveM732
SteveM732's Avatar
Club: BCRCC
Charles and Jack have done some impressive things with very inexpensive server power supplies. It's a very DIY type of project and not for everyone, but you can't beat the price.
Also look into Mean Well power supplies, I have a 600W 15V unit that is enough for most tasks. Mine came used from eBay at a reasonable price ($60-70 for two of them I think). They also make 24V supplies of higher wattage which is what you'd need to run the PL8 at full power from 120VAC. But at that point you best be making sure you're not going to start blowing fuses or tripping breakers.
Old 01-19-2010, 09:32 PM   #14
Jack Doherty
Don't over look the input requirement on the ID.2236, it is of 180V - 264V. Most flight fields only have 110v available.
Jack
Old 01-19-2010, 10:00 PM   #15
MaxAdventure
AMA 198798
Club: LEAF, BAS
3kW  1kW  2kW
- Two of my current charger power supplies are computer system take-outs that I've modified for use. Thanks for the heads-up on 'Mean Well'.
Jack
My thinking is that if I were to purchase this tool, I'd expect to use it at it's full capacity at home and would need to feed it well. Product like the CellPro10 and Multi4 would be good to take to the field. Honestly I'm still surprised to hear anyone even as A/C at a flying field! I have yet to see a field here in Colorado with that (although my primary club did put in Solar D/C supply last year).
Old 01-19-2010, 10:41 PM   #16
Jack Doherty
The local field I attend has electricity. I attended 10+ helicopter fun fly this past season and all but one had electricity. Most were in the Texas area and one in Louisiana and one Oklahoma. Some even provided RV/camper hook ups.
I just took it for granted that most RC fields had electricity these days.
Jack
Old 01-19-2010, 11:03 PM   #17
SteveM732
SteveM732's Avatar
Club: BCRCC
Jack
I don't know about most fields, but my club's field doesn't have any electricity and probably never will since we don't own the land.
Old 01-19-2010, 11:17 PM   #18
Jack Doherty
Steve,
If there a any electrical lines close by, the electric companies can sometimes be very accommodating. Every flying site is different however and has it's own set of unique problems.
Jack
Old 01-19-2010, 11:52 PM   #19
ggcrandall1
8000' and going down fast
ggcrandall1's Avatar
<snip>
Jack
The field where I fly here in the Atlanta area not only has 110v but also two 12vdc 30 amp power supplies. On top of that the county pays the power bill.
Glen
ggcrandall1 is offline
Old 01-20-2010, 01:31 AM   #20
everydayflyer
Southern Pride
CCRC has a great site facilities wise. Relief rooms with hot and cold running water,flushing thrones, nice concessions area, covered pit area/ benches with AC outlets ,spectator bleachers, nice graveled parking area, separate flight areas for fixed wing and helis, asphalt and sod runways. just wish they had more usable air space. Years ago when I was a member for close to 20 years we (they) had lots of flying space and a runway and that was about it.
I fly mostly from what was a hay field and still is all around it but it is close.
I have a 24V 55A power supply for home use and two 125Ah deep cycle for field use. They are setup to be used paralleled or on series as needed.
While the PL8 will only do up to 500 watts on 12V that is still not to shabby..
Sorry for being OT but us old timers digress at times.
Charles
Old 01-20-2010, 01:45 AM   #21
SteveM732
SteveM732's Avatar
Club: BCRCC
I don't think it is too big a digression to explore power sources available at the field. I had assumed very few had access to 120VAC at the field but it sounds like the norm in some parts of the country.
For some of us a lead-acid battery is the only option at the field. Others either have 120VAC, solar DC, or run generators. Each one needing a different means to power the PL8, which is a problem to be addressed before balance tap adapters, parallel charging and other such details.
Old 01-22-2010, 02:03 AM   #22
EpoweredRc
3D Flyer
EpoweredRc's Avatar
View EpoweredRc's Gallery47
Club: Paulding County Model Aviation
Send a message via Yahoo to EpoweredRc
This is not on the most recent topics WOW the biggest hottest charger anyone has for now, and Cheap.....
"I'ld rather be flying"
"B&D 1100 Cells and A123 2300 cells are my
best friends."
_______________
My Personal RC website:
http://chrissrcplanes.tripod.com/
Where I got my edge 540
http://www.fancyfoam.com/
My clubs Site.
http://pcmaviation.org/NewIndex.htm
EpoweredRc is offline
Old 01-22-2010, 02:20 PM   #23
Friends: (7)
Been thinking about building a tow plane for aerotowing gliders. This would be the perfect charger for those big battery packs.
President, Long Island Silent Flyers www.lisf.org
President, Eastern Soaring League www.flyesl.com
Present on the flying field whenever possible.
AEAJR is offline
Old 01-22-2010, 04:39 PM   #24
jcpylon
pylon
jcpylon's Avatar
For most flying fields?
Suitcase generators?
Honda or honeywell 1000-2000 watts.
jcpylon is offline
Old 01-22-2010, 04:45 PM   #25
darylm44
darylm44's Avatar
Club: Frontier Fun Flyers
Charles
We have a hole in the ground with one of those little houses over it How do you pay for all those amenities? Private donation, part of a public park system, etc??
darylm44 is offline
New foamies-sneak preview EDFrules 3D Flying 43 09-05-2010 05:58 AM
ParkZone 4-Channel Sneak Peek David Eichstedt Indoor & Micro Electric Planes 157 02-21-2010 01:09 AM
Electrifly Nieuport 11, sneak peek Percyflyer WWI Era 1 09-11-2009 07:05 AM
Quique 49" Electric Yak - Review Sneak Preview Maudib 3D Flying 19 04-24-2007 05:10 PM
Superbowl 41 (sneak preview) aviatordave Humor 10 02-02-2007 05:05 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.56453 seconds with 69 queries
