Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > FMA Direct
Old 01-22-2010, 05:25 PM   #26
Jack Doherty
PowerLab 8 beta tester
Jack Doherty's Avatar
Default Assorted PL8 Graphs:
Just for anyone and everyone's. Attached you will find seven screen shots of a 10 cycle Charge/Discharge of a new RevElectric Platinum 2200 3s batter pack that had 3 previous charges on it. As you can see the PL8 is a great tool for analysis, maintenance and documentation of batteries. And did I mention how easy it was, push a button and walk away letting the PL8 do the work for the next 8 hours.
Jack
Name:	Cell Internal Resistance.jpg
Name:	Cell Voltage vs. Capicity Overlay.jpg
Name:	Cell Volts.jpg
Name:	Pack Capacity.jpg
Name:	Pack Current.jpg
Name:	Pack Fuel Level.jpg
Name:	Pack Volts.jpg
Jack Doherty is offline
Old 01-23-2010, 02:11 AM   #27
everydayflyer
Southern Pride
everydayflyer's Avatar
View everydayflyer's Gallery13
Default FMA cellPro Power Lab 8 Power Supply Screen
Here is the screen on the CCS where you select power supply options.
Beside selecting between DC Power Supply or Pb there are options for limiting volts and amps. as well as regenerative options with Pb.
Added a screen shot of 6 of the Users Presets (25 total) and 50 more in the Library. Also some of the Tabs for the many different chargr,discharge,balance ,termination etc. are shown.
The CCS is similiar to the one used with the Cell Pro Multi Charge 4. This one has a lot more options however.
Charles
ID:	118817 Total of 25 User Presets and 50 Library Presets
everydayflyer is offline
Old 01-23-2010, 05:40 PM   #28
Jack Doherty
Default Assorted PL8 Screen shots:
Hi Guys:
I am going to add a couple of post showing some of the screens available on the PL8's CCS (Computer Control Screen). The first post includes screen shots of the seven major tabs that can be selected from the main CCS window. Note also that almost all of the changed that can be made from the CCS windows can also be made directly at the PL8's LCD window.
Cell Tab: Select preset to use and observe status of charge/discharge.
Int.Res. Tab: Observe internal resistance of each cell during charge but not during discharge.
Supply Tab: Observe supply status as well as selecting power supply type and parameters.
Firmware Tab: Used to update FREE upgrades.
Options Tab: Used to select internal PL8 options/behavior.
Presets Tab: Used to select alter/edit presets. 25 User presets and 50 Library presets. Note: all 75 presets are stored in PL8's memory. Additional presets can also be stored on you computer and traded out at anytime.
No Errors Tab: Used to verify that new user presets and edits you make will work correctly with a new firmware update/download. If changes need to be made, they will be flagged automatically on this page and the correction can be originate from this page.
I will follow later with a second post with screen shots of sub-tabs of the main preset tab. This is where you would make the majority of edit and changes to presets.
Jack
Name:	Int Res tab.jpg
Old 01-24-2010, 05:13 PM   #29
Jack Doherty
Default Assorted PL8 Screen shots:post 2 of 2
Hi Guys:
This is post 2 of the Assorted PL8 screen shots.
The post will focus on the sub-tabs of the Presets main window tab. Each setting has its own drop down window for easy minimum and maximum allowable value selection.
General tab: The current preset can be exchanged for other presets in the Library or your custom presets.
Detection tab: Defines the way cell are recognized by PL8.
Charge tab: One of the most powerful and important of the PL8 screens. Here you set charge amps and charge to voltage of cells.
Discharge tab: Maybe the second most important and powerful screen. Her you set the discharge amps (up to 30A regenerative), discharge to voltage and number of cycles one to infinite.
Balance tab: For setting the speed and timing of cell balancing during a charge. PL8 does not balance during discharge.
Termination tab: Here one can alter how PL8 ends a charge based of different battery chemistry.
Screens tab: Allows you to add to, remove, hide or reorder the LCD screens that appear on the PL8's LCD screen. If a window is ghosted out, it can not be altered or removed.
Fuel tab: Each type battery chemistry, and capacity can effect the indicated fuel level. FMA supplies many generic fuel tables, and some specific to a brand of battery. But IMO one of the most significant feature of the PL8 will be a fuel wizard that allows you the user to create a fuel gage that meets the exact parameters of a particular battery you own. If you chose to, you could have a fuel gage created for each and every battery you own. An accurate fuel gage will also allow PL8 to perform a much more accurate AUTO xC charge whether it be 1C-5C or more to accommodate future battery technology advances.
Safety tab: Allows you to adjust how safety issues are handled.
Hope this is helpful,
Jack
Name:	9 sub tabs.jpg
Old 01-24-2010, 06:38 PM   #30
View Don Sims's Gallery3
WAA-08 Pilot  Globetrotter Pilot
Friends: (38)
Any of you beta testers planning to be at SEFF?
Take care and thanks for posting at WattFlyer!!
Don
Old 01-29-2010, 02:25 AM   #31
heymac
heymac
Guys,
Check the FMA web site!
PL-8 is up!
heymac is offline
Old 01-29-2010, 03:05 AM   #32
ggcrandall1
8000' and going down fast
ggcrandall1's Avatar
Here is a link to FMA's PowerLab 8.
http://www.fmadirect.com/new_applica...powerlab8.html
Glen
ggcrandall1 is offline
Old 02-22-2010, 09:53 PM   #33
Tim Marks
President FMA, Inc.
Default News about adapter support
We have completed our evaluation of the new Safe Parallel Adapter (Safe Adapter for short) concept. It works very well. This concept replaces the former Smart Parallel Adapter or "SPA" concept. The new solution offers the following benefits:
1) The revised solution incorporates a carefully selected polyfuse to be installed on each line between the pack and the pigtail of the adapter.
2) The solution is therefore, much lower parts count than SPA which greatly reduces cost and vastly improves reliability.
3) Due to lower parts count/higher reliability coupled with simple setup and operation, the new Safe Adapter concept is equal to, if not better in terms of safety than the older SPA concept.
4) Safe Parallel Adapters can be daisy-chained. There is no electrical limit to how many packs can be paralleled using these adapters. There may be practical limitations with regard to actually connecting large numbers of packs to the PowerLab 8.
5) Safe Adapters will not support node-only charging. They require the use of both the node and discharge leads to be connected to the charger. Therefore, FMA/REVOLECTRIX will be offer both single pack adapters (1s-6s) or the Smart Adapters (1s-6s) for parallel charging via nodes and discharge leads.
6) As noted before within this thread, stackable, safety banana plug cables will be available to facilitate a simple method for paralleling discharge leads of batteries charged in parallel. We will also be making a change to these cables to add a 35A blade fuse to the positive (red) wire. In the event that polarity is ever reversed during connection, this will prevent the risk of fire.
7) With this solution, we are also adding additional firmware features in the charger to help automate the process of parallel charge setup. To the start menu, one additional screen will be added asking for the number of packs being charged in parallel. In firmware, up to 9 packs can be selected for parallel charging. Subsequent screens will be altered to show total current as well as current available to each pack connected. This will make it simple and convenient to determine how much charge current is going to each pack. No need to calculate the correct charge currents externally.
8) Safe Adapters are intended for use only with Lithium chemistry packs.
9) As most in the industry are aware, lithium batteries represent a volatile potential. Always follow appropriate cautions with regard to the proper charging and maintenance of lithium batteries. Parallel charging offers a safe and effective means by which to make the most out of the power available in the PL8. The new Safe Adapters will provide added protection when charging in parallel. Polyfuses will protect the small pins of the adapters in the event of human error; e.g. reverse polarity. Fusing the discharge leads will prevent fire. But parallel charging does require diligence on the part of the customer to observe a few key rules to assure safety and prevent damage to his battery packs:
When Parallel Charging using Safe Adapters:
ALWAYS OBSERVE PROPER POLARITY
CONNECT ONLY PACKS OF SAME CELL COUNT
CONNECT ONLY ONE PACK PER ADAPTER
Tim Marks
Tim Marks is offline
Old 02-26-2010, 10:12 PM   #34
Jack Doherty
Default PowerLab 8 update:
Hello to all interested in changes and improvement in the Cellpro PowerLab 8:
The beta testing team just received the latest version to test yesterday. I though some of you might be interested. One of the major changes or improvement is in the the Fuel Wizard. It has been automated and enhanced from the previous version.
I am attaching a screen shot of the new Fuel Table Wizard to accompany the text.
Let me begin by explaining that a well developed/accurate fuel table will improve the quality, safety and accuracy of your charge as well as improving the Fuel Gage accuracy. By using the Fuel Wizard you can be assured that the fuel table matches you particular battery pack regardless of its brand, cell count or capacity.
After going to the Tool menu and clicking on Generate Fuel a window open with several questions to answer regarding your battery pack. Answer these and click on the Generate Fuel button and your done. All the work of saving the fuel table to a new preset is automatically done for you.
Another feature was also added to the Start charge window to aid the parallel charging of multiple packs. The charger does the math for up to 9 parallel packs. This way, you don't have to figure all the rules for parallel charging in your head. See the attach screen shot of this new feature.
Jack
Name:	Fuel Wizard.jpg
Name:	Parallel Charge.jpg
Old 03-12-2010, 04:27 PM   #35
SteveM732
SteveM732's Avatar
Default Overlays
In the latest version of the CCS FMA added the ability to export voltage vrs Ah plots into the bt2 format used by the WMR CBA. This permits the use of the CBA software to do overlays and compare data from the PL8 with existing data you might already have from a CBA.
I decided to test and see if FMA's 950mAh Revo Red pack performs as advertised or not. It is also worth noting that all discharges were regenerative with 80-90% of the energy going back into the deep cycle RV batteries and the little heat that was generated was passively cooled by the massive heat sink so the cooling fans never came on.
ID:	122920 FMA's published battery performance data for the 950mAh Revo Red packs.
ID:	122921 My results using the PL8 and exporting the average cell voltage and exporting into the WMR CBA bt2 file format then using the overlay feature of their software.
SteveM732 is offline
Old 04-07-2010, 09:02 PM   #36
Tim Marks
President FMA, Inc.
Default PowerLab 8 Adapters Update
Hi:
We have completed the development of all the new adapters coming for the PowerLab 8 Battery Workstation. These items have been released to manufacturing. Within 2-4 weeks we should have all of these up on the FMA Direct website as well as various PL8 combos we will be offering. As promised, at that time, customers having already placed on-line orders for PL8 will have the option of stepping up their existing orders to combos at equivalent introductory pricing.
So, please check the admittedly crude PR document to get the skinny on the various adapters:
http://www.fmadirect.com/support_docs/item_1315.pdf
Tim Marks
Old 04-16-2010, 02:46 PM   #37
Howard Matos
Production Supervisor
Howard Matos's Avatar
View Howard Matos's Gallery12
Club: Frederick Model Aircraft Club
Send a message via Skype™ to Howard Matos
First Production Run Delivery Update
FMA has received an update from our manufacturing partner on the delivery of first production run orders for the Cellpro PowerLab 8, PL8 combos and adapters. There has been a slight delay of about 3 weeks. The worldwide recession has created a situation in which allocations of certain raw materials, especially microcontrollers and FETS, have moved lead times out considerably. The result is that projections for receipt of these parts have been difficult to meet. With the latest scheduled date approaching quickly, we wanted to notify all those with orders that the schedule is now moved out to mid June for first production run. Because the new scheduled date is so near, our partner has assured us that the delivery of certain long lead time items is solid. In fact, most materials are in house now to complete the run. For those customers with orders on the second production run, you can expect about a two week delay to July 1. We know that everyone with an order is anxious to get the new PL8 work station in their hands, as is FMA. We appreciate your patience and commit to keep you posted with news over the next few weeks that may impact your orders.
Fly More, Fly More Often!!!
Howard Matos is offline
Old 06-08-2010, 09:08 PM   #38
Tim Marks
President FMA, Inc.
Default PL8 Manual
Hi:
The PDF version of the manual may now be downloaded from the FMA Direct website at the following link: http://www.fmadirect.com/support_docs/item_1322.pdf
Old 06-10-2010, 01:29 AM   #39
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Any updates on lead time?
If I ordered one next week, when could I expect to receive it?
I think I need a signature.
Larry
Larry3215 is online now
Old 06-11-2010, 04:26 PM   #40
Howard Matos
Hi,
Orders placed now will be delivered in late July.
Old 06-11-2010, 04:45 PM   #41
Larry3215
Larry3215's Avatar
Thanks!
Larry
Old 06-16-2010, 07:02 PM   #42
Tim Marks
President FMA, Inc.
Default PL8 Charge Control Software (CCS) is available!
The PL8 Charge Control Software (CCS) is available for download and install at the following link: http://www.fmadirect.com/new_applica..._software.html This Windows program does not require that you have the PL8 in order to install and run the software. Check the on-line help with direct access to pertinent information by clicking the "?" buttons throughout the various tabs.
Old 07-30-2010, 04:59 PM   #43
everydayflyer
Southern Pride
Default POWERLAB 8 Monitor mode
For the few who do not visit RC Groups here is a PL8 Monitor screen shot of a test I ran this morning on a new LiPoly I am testing.
Charles
Old 07-31-2010, 08:00 PM   #44
Larry3215
Larry3215's Avatar
Interesting that the knuckle where the voltage drops off steeply is much higher with these new gen cells than the older cells.
Another good reason to increase LVC with these newer cells.
Larry
Old 10-27-2010, 07:25 PM   #45
Tim Marks
President FMA, Inc.
Default PowerLab 8 Power Calculator Spreadsheet
Hi:
We updated the PL8 Power Calculator Spreadsheet to support v1, v2, and new Custom Parameters. The new version is available at the 2nd link off of the PowerLab 8 "Resources" tab at the following URL:
http://www.revolectrix.com/pl8_links_tab.htm
Download the zip and then access the archived spreadsheet. Note, there are now 3 sheets within the workbook.
Tim Marks
Old 11-11-2010, 01:47 PM   #46
Howard Matos
I posted the first 2 videos for the PL8, Installing the CCS & Running the CCS, They can be found here: http://www.revolectrix.com/pl8_video_tab.htm Please let me know if you have any questions, thanks.
Old 04-18-2012, 08:42 AM   #47
qateye86
Default *.ps8 file for powerlab graph request
Dear fliers,
thanks for all the helpful posts and info, I'd like to ask anyone if has a log file or graph file of type *.ps8 that I can see for charging any kind of battery, I need it to compare with other Japanese device that I have, so please if anyone can help providing this I will appreciate it, please send it to mqatouni@gmail.com
thanks in advance >
qateye86 is offline
Old 06-08-2012, 03:50 AM   #48
WildManDriving
I've two question that I have been unable to find answers to, though both I could assume I'll ask to know for sure.I'm keen on the data graph features and per cell IR test to compare readings between brands and monitor pack depilation. My questions are as follow and Thank you in advance for the help.
Are the PL8 v2 CCS features only for the PL8 or are they available on all CellPro chargers?
Also in the Presest Charger tab what drop down options are there for "Charge Voltage"?
WildManDriving is offline
Old 06-08-2012, 04:21 AM   #49
Tim Marks
President FMA, Inc.
The PL8 v2 and the PL6 CCS are virtually identical. The Cellpro 10s and Cellpro 10XP CCS are similar but have limited capability compared to PowerLab series.
this depends on the chemistry the preset supports. If you mean for LiPo presets, the range is 3.000V through 4.300V. If you mean other chemistry, please specify.
Additionally, you can always install the CCS application on your PC and run it without actually having the charger. Set the COM port to something other than AUTO after you install. Go here to install PL8 v2 CCS:
http://www.revolectrix.com/new_appli...ftware_v2.html
You might also be interested in the CCS Tour here:
http://www.revolectrix.com/CCS_Tour.htm
Tim Marks
Old 06-08-2012, 05:57 AM   #50
WildManDriving
Thank you, I've downloaded the softwares and am I right in saying the CellPro10 range don't have Charge Voltage adjustment but still have IR testing and data graph?
I also cannot see the differences between the PL6, PL8 and PL8 v2 other than cell count and wattage. What am I missing there? Either way I think I have found my charger.
New foamies-sneak preview EDFrules 3D Flying 60 01-15-2012 03:29 AM
ParkZone 4-Channel Sneak Peek David Eichstedt Indoor & Micro Electric Planes 157 02-21-2010 01:09 AM
Electrifly Nieuport 11, sneak peek Percyflyer WWI Era 1 09-11-2009 07:05 AM
Quique 49" Electric Yak - Review Sneak Preview Maudib 3D Flying 19 04-24-2007 05:10 PM
Superbowl 41 (sneak preview) aviatordave Humor 10 02-02-2007 05:05 PM
Page generated in 0.44418 seconds with 69 queries
