Old 03-01-2010, 12:10 AM   #1
Maximus
Club: Tri-City Flyers
Default Fly Fly F-100 Build
Hi all, new to the forums and I’m a n00b when it comes to jets and electrics! It’s interesting after being in this hobby so long and then starting something so new, it makes me feel just as I did when I started RC as a kid so long ago, pretty unsure of what I am doing!
My goal in this thread is to receive advice when I need it so that I’m not building this thing alone, and if I run a build thread it will make me feel a certain obligation to finish this project and not leave people hanging that may be following along. I’ve already started the build, but I will post pictures over the next few days until I catch up to where I am now.
I will be heavily modifying the plane, building is where it’s at for me, we have all seen many of the stock ones fly already, so I’m going to be doing something different.
Please feel free to step in at any time and comment or ask any questions you may have, thanks!
ID:	121973 I will be filling all the very large panel lines with light weight spackle.
ID:	121974 Wing sanded down
ID:	121975 I was able to make the trailing edge very thin.
ID:	121976 Trying to figure out my power set up
ID:	121977 Fuselage filled and sanded
Maximus is offline
Old 03-01-2010, 12:17 AM   #2
Maximus
Next mod will be to fix the landing gear. This is pretty easy really, the full scale F-100 had the gear facing out, the Fly Fly model has the gear facing in. I used a strip of PC board to strengthen the center section after cutting the new wheel wells. The wheels are in the same location as the stock kit because when the gear legs are moved in the wheels are facing out, so they are not any narrower.
ID:	121978 Wheel facing out as per full scale
ID:	121979 New scale wheel well
ID:	121980 PC board
ID:	121981 Wheels retracted to scale location
ID:	121982 I'm playing with the idea of gear doors
Maximus is offline
Old 03-01-2010, 12:20 AM   #3
1kW
Friends: (7)
Hi Maximus. Looks like you may have done some modeling before! Subscribed.
I know that you believe you understand what you think I said, but I’m not sure you realize that what you heard is not what I meant
-Rob
Old 03-01-2010, 12:24 AM   #4
Maximus
Next I glued the stock ailerons back on and then cut them out at the scale location. I will then move the aileron servo closer to the center section eliminating about 14” of servo wire. I also fixed the smashed wing tips by cutting a slot and inserting 1/32” ply, then I added foam as needed to fill the void.
ID:	121983 Scale aileron cut free
ID:	121985 Fixing the wing tips
ID:	121986 The landing gear mounts I forgot to show
Maximus is offline
Old 03-01-2010, 12:35 AM   #5
Maximus
Hi BirdDog, thanks for your comment, nice to have you along! I've been messing around with models for a while I guess you could say!
I’m not sure what the stock ordinace is really, but I wanted something a little bader (?)! So I carved the things into the awesome Martin/Maxon GAR-8 Bullpup. I will be making the inner racks to hold these bad boys also.
ID:	121987 Just cut it down and added 1/32" ply fins
Maximus is offline
Old 03-01-2010, 12:41 AM   #6
Maximus
I picked up the lighting system from EJF by RCLander, it says it’s for the Mig-17, but I got it to fit. I cut a groove 2” forward from the stock tail pipe and glued the lights in.
Maximus is offline
Old 03-01-2010, 12:48 AM   #7
Maximus
I sanded the fin to a nice shape, relocated the aileron servos and fixed the nose intake.
ID:	121995 Got a nice sharp edge on the fin
ID:	121996 Added 1/32" ply so that I could add the balsa ribs
ID:	121997 Some foam was needed to fix the fin on the fuse
ID:	121999 This shows the new aileron servo location and gear mounts
ID:	122000 Nose cut off and 1/2" balsa added to the intake
Maximus is offline
Old 03-01-2010, 12:53 AM   #8
Maximus
I used a mixture of water putty, water and light weight spackle painted on the parts to smooth the surface in preparation for glassing. It works very well and actually stiffens the foam quite a bit and it sands very nice.
Maximus is offline
Old 03-01-2010, 12:58 AM   #9
Maximus
This is how she looks so far, I’ve also finished the cockpit. I ordered the cockpit from Skylake models, the pilots are not correct but they look cool anyway!
ID:	122006 How it looks now
ID:	122007 The only change I made to the cockpit was to extend it by 1"
Maximus is offline
Old 03-01-2010, 02:36 AM   #10
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
Nice looking model
Subscribed
dumo01 is offline
Old 03-01-2010, 05:33 PM   #11
Maximus
Originally Posted by dumo01 View Post
Nice looking model
Subscribed
Thank you dumo01, and it's nice to have you along with my build.
The little details always take up tons of time, it just nickel and dimes you to death! I am making the tanks droppable using the old Vortac bomb drops, I bought tons of these when they were available because I liked them, so I have enough for several more models. I've made the inner and outermost racks just for carrying stuff around that looks cool, I will be able to manually attach whatever I want.
I'm not really impressed with the lighting system, I could not get the radio shut off to work, they are just always on. So I will have to do without the landing light. I burned a hole from the wing tip to the aileron, then cut a slot in the back of the wing to bury the wire for the lights, then the wire just follows the servo wire trough.
ID:	122107 The lights are very bright and look cool
ID:	122108 Light wire
Maximus is offline
Old 03-04-2010, 08:50 PM   #12
Maximus
I thought I’d give my loyal readers an update, I’ve been making progress but I just have not been taking the time to post or take a lot of pictures, I’m making an extreme effort to get this thing done! Don’t worry though, I’ll keep you posted.
I finally finished the ordinance, just some final finishing and fins on my drop tanks. I’ve added the low drag dumb bombs with fuse extenders to the outer racks, I just carved them free hand out of foam, added 1/32” fins and aluminum fuses. I will detail them after I get the finish mostly done. So now everything is removable and I have the option of dropping whatever I attach to the middle racks.
Now, back to work!
Maximus is offline
Old 03-18-2010, 02:16 AM   #13
mustangpilot
mustangpilot's Avatar
Awesome job Maximus! I'm on board. This is going to be my next winters project. But your going to make it tuff on the old man Hugh. You have some pretty slick scale upgrades. I'll be watching. Jim
No,No dear I've had that for a while now!
mustangpilot is offline
Old 03-18-2010, 02:22 AM   #14
capn chaos
capn chaos's Avatar
Club: no pack-lone wolf
Friends: (20)
Maximus,
Amazing stuff. Some of these kewl planes get bypassed with all of the "hot" items, F-16, F 18, Mig 17 etc...
Super job and have been watching from the "wings". Don't think I'm ready to tackle one like this but had to subscribe just for future reference.
Keep on "keepin on"
CC
capn chaos is offline
Old 03-18-2010, 03:37 AM   #15
Maximus
Thank you very much for the encouragement gents! I have been really working on this baby!
I had to add one more detail, the very prominent and interesting refueling boom. She is now ready to glass...
ID:	123255 Made a refueling boom
ID:	123257 On her wheels
Maximus is offline
Old 03-18-2010, 03:49 AM   #16
Maximus
For glassing a bird like this where weight is critical, you must use a light weight method. None better than thinning the resin about 40 percent resin to 60 percent denatured alcohol. It really simplifies the application and there is no need to do anything during or after the application. All you are doing is bonding the glass to the foam, but it really does make it much more ding resistant, no need to pile the resin on, it also stiffens the foam quite a bit. You have to fold it over on the parts, you don’t want to go around and cut the glass off with sandpaper, because then you would leave some rough edges, because no more glass is used. I then fill the weave with a mixture of spackle, putty and water as we did before, this sands very easy and then you are ready to prime. I prime with regular water based house primer, wet sand and then she is ready for paint.
ID:	123262 Notice how I cut the glass, so that it will just wrap around the part.
ID:	123263 Here you can see that the cloth is overlapped on the other side about ½ inch.
ID:	123264 Your author braving the 75 degree temps to get the job done, notice the larger auto detail gun.
ID:	123265 All done priming, ready for paint after wet sanding
Maximus is offline
Old 03-18-2010, 03:52 AM   #17
Maximus
Time for colors! I used Model Masters paints, first the basic colors then the weathering. I’m going to try my hand at detailing the aft aluminum skin with some burnt effects, we’ll see how I do!
Maximus is offline
Old 03-18-2010, 03:55 AM   #18
Maximus
Forgot to add some pictures!
Maximus is offline
Old 03-18-2010, 04:04 AM   #19
Maximus
I’m a little behind on the wing, just getting it painted now. I used CA hinges filled with 5min epoxy for my ailerons in case you all want to know. I also have my various air brushes that I used for this job there for you to see. The first one I’ve had for about 15 years, it’s an old Testers external single action brush, it works great for larger areas. The next one is a much more precise air brush, good for the edges of your camo pattern and small details but not larger areas. The last one is my auto detail gun, used for priming. Tomorrow I’ll finish painting the wing and maybe start on the weathering.
Maximus is offline
Old 03-20-2010, 05:05 AM   #20
Maximus
Made my decals, just printed them out on clear and some on white decal paper.
I’m getting all the servo’s and stuff installed now, so it won’t be long!
ID:	123479 Creating the decals on the PC
ID:	123480 After printing they need to be sealed
ID:	123481 Protester's Protector almost ready for the skies again!
ID:	123482 The Fly Fly F-100!
ID:	123483 Looking ready for combat!
Maximus is offline
Old 03-20-2010, 07:09 AM   #21
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
View Alpea42's Gallery59
Friends: (25)
Nice looking model.
THE B-2 Worlds most expensive airplane.
Alpea42 is offline
Old 03-21-2010, 04:43 PM   #22
mustangpilot
I like what I see. You said the pilots are not correct? Are you saying they are to small? Because in the pic's so far they look fine. I've been on the fence for a while now about doing one of these. But seeing your jet I'm about ready to jump off and get one coming. Keep the pictures coming. Jim
Old 03-23-2010, 03:04 PM   #23
Maximus
Thanks Alpea42!
Thanks Jim, I should have clarified that a bit about the pilots. I just meant that the pilots helmets are of the wrong era, not 1970 Vietnam style, they are modern. I liked the way they looked and decided to not sand them down and modify them, so I guess they could be accurate if my plane was of a modern restoration! As far as getting one of these, I say do it! I love the Hun but I did not want to spend thousands of dollars or spend a thousand hours building one from scratch, it’s a perfect size for me also.
While I wait for my new rotors to get here I decided to start on the weathering. This really is the most artistic point of any build, it can be extremely easy to over do it. I wanted to start with the aluminum rear section, it should look burnt to a degree. I stared by drawing on the panel lines with an ultra fine permanent marker. Next I mixed black with silver, masked off individual sections with electrical tape and lightly sprayed the panels. Not much paint is used so I just use a few strips of tape, over and over again.
Next I mixed some tan with yellow and white. Then I added some metallic blue, and then finally highlighted that with some metallic purple. I used a internal mix double action airbrush and had to go over the areas several times because so little paint is coming out, you want to add it in fine layers. I still want to touch this up a bit, and the lighting distorts the colors, but I wanted to give you an idea of how it looks.
Maximus is offline
Old 04-01-2010, 06:03 PM   #24
Maximus
I may fly this thing this weekend, so wish me luck! I have not finished my drop tanks and bombs, but I will have time for that after the maiden.
Maximus is offline
Old 04-14-2010, 09:38 PM   #25
f82fan
D Master O' Disasters
Club: Several
Thumbs up F-100
VERY NICE!
Thanks for doing this bird.
My dad flew 'Huns in England & F-4s in Viet Nam, so I have a soft spot for them both.
Looks like I need to get one of these... I just don't have the time to beautify one like you've done.
Here's wishing you the best on the maiden and the future!
Wally
BTW... Hope you can bring some EDFs and a bunch of friends to our All-Electric-Jet-Festival on September 11 at the NWRCC Field just outside of Houston!
www.nwrcc.com
It is the weekend before Bomber Fields B-17 fly-in.
f82fan is offline
What's a good first plane to build and fly? phupper Hi-Performance and Sailplanes 10 04-12-2008 11:25 AM
How To Build A ParkFlyer That Will Fly Across The USA Murocflyer ParkFlyers 27 04-07-2008 10:18 PM
High Altitude E-Starter Build - Will she Fly? fishmaniam General Electric Discussions 5 10-11-2007 03:31 PM
RCU Bipe Flatout - Build and Fly Maudib Foamies 9 03-06-2006 04:06 PM
AVA E build and fly... kepople Hi-Performance and Sailplanes 44 01-05-2006 05:30 PM
Page generated in 4.36410 seconds with 138 queries
