Old 03-10-2010, 12:05 AM   #1
Nived
Default HZ Super Cub Duribility Mods
I just ordered a HZ Super Cub LP at my local hobby store. It is supposed to come in on Friday. I'm very excited!
I've been browsing a lot of forums and I've seen a number of suggestions for making the Super Cub more durable for first time fliers (like using packing tape on the wings).
If you have any suggestions for durability mods or mods that would be helpful for a beginner, please post them here. I'll edit this first post with a lists of mods after I hear a few.
Also, what tools and parts should a beginner have handy for crash repairs?
Mods I plan to use:
  • I applied packaging tape to the center of the wing (where the rubber bands hold the wing to the fuselage), wing tips, leading edge of the wing, the inside of the cowl, and along the tail of the fuselage.
  • I used a Popsicle stick and 5-Minute Epoxy to reinforce the rear wing seat.
  • I used paper clips to attach the wing struts to the fuselage.
Other Suggested Mods:
None Yet
Nived is offline
Old 03-10-2010, 01:44 AM   #2
groundrushesup
groundrushesup's Avatar
View groundrushesup's Gallery45
Club: Hill Country Wattheads
Send a message via AIM to groundrushesup
1kW
Friends: (20)
Mods I plan to use:
None Yet
None Yet
I have seen some folks line the inside of the cowling with packing tape, nice and neat - that way if you nose it in you have a bit more shock absorption.
Spare props - these are for the non-LP version (I recommend http://www.rcslot.com for their good prices)
While your at it maybe a spare shaft w/ spur attached
Need nose, a good screwdriver set, packing tape, hrmm my toolbox has become so full of stuff its hard to think of what I use most... wattmeter is a good thing to have as you get more into the hobby
Poly glue (Gorilla, Sumo - either is great
CA (superglue, always good to have)
I dunno man, its all about how well you want to be prepared
Everybody's Somebody at The Hill Country Watthead's Thread!
Stop in and see what we're up to!
Visit Our Youtube Channel, too!
groundrushesup is offline
Old 03-10-2010, 01:55 AM   #3
1320fastback
1320fastback's Avatar
Club: Fallbrook R/C Flyers and Oceanside Quiet Flyers
WAA-08 Pilot  AV Contest
Mods I would do:
Tape the leading edge of the wings
Tape the sides of the fuselage at the tail
Replace wing seat on fuselage with light balsa
Things to buy:
Rubberbands from Staples
Larger tires
Extra props and gear boxes
Classic Sig Kadet/ OK Models SupraFly45/ Eflite SU=26M/ Ritewing TL50/ FPV Twin star/ Pheonix Strega .45/ Nitroplanes Bobcat .75 / Cox .049 Pilot Baby/ AMA#1,000,000
1320fastback is offline
Old 03-10-2010, 01:56 AM   #4
cisc0box
Curious Owl
cisc0box's Avatar
View cisc0box's Gallery15
Originally Posted by 1320fastback View Post
Mods I would do:
Things to buy:
Larger tires
That just about sums it up. Clear packaging tape is your friend.
cisc0box is offline
Old 03-10-2010, 06:22 AM   #5
Nived
Thanks for the input.
Props
- How do I know what props can be used with the HZ Super Cub LP? Do they have to be 9x6? Would other sizes give a better performance?
Glue - I have some Devcon 5-Minute Epoxy and Loctite Super Glue. Will these work on the Super Cub? Which glue do other Super Cub owners use?
Nived is offline
Old 03-10-2010, 06:26 AM   #6
Nived
Mods I would do:
Things to buy:
Larger tires
What are the rubber bands used for?
Do gear boxes break frequently?
Nived is offline
Old 03-10-2010, 07:04 AM   #7
C130 Load
C130 Load's Avatar
This guy has some great videos on modifications to the SC.
There are about 25 of them. I have followed and done most of them and they really help with strength and durability.
Start with this one and click on more from him on the right panel and see the list of others.
Hope this helps.
C130 Load is offline
Old 03-10-2010, 03:29 PM   #8
cisc0box
Curious Owl
cisc0box's Avatar
Rubberbands are to attach the wings to the fuselage.
cisc0box is offline
Old 03-10-2010, 03:30 PM   #9
constantCrash
prefectionist
constantCrash's Avatar
Send a message via AIM to constantCrash
Yeah, you'll probably go through a few gearboxes just starting out. best to have 1-2 on hand.
I wanna be a pirate. Arrrrr
AMA - 885997
constantCrash is offline
Old 03-11-2010, 05:45 AM   #10
groundrushesup
1kW
Friends: (20)
Props
Props - The non-LP Super Cub swings a 10x8 because of the NiMh battery's lower voltage (9.6v as I recall). The LP version has an 11.1v 3S battery so to keep from over-taxing the brushed motor, they propped down to a 9x6.
Glue - Sounds like you have what you need. Poly glue (gorilla or sumo) works well for non-field repairs because it foams as it sets and is not as brittle as an epoxy bond, but I say non-field because it can take hours to set. I persist on mentioning it because IMO it works especially well with the Z-foam of Parkzone planes.
Old 03-13-2010, 02:25 PM   #11
cbatters
cbatters's Avatar
Friends: (4)
First durability mod - simulator. First 5 crashes should be on a simulator not your plane.
Second durability/convenience mod - easy strut attachment
http://www.wattflyer.com/forums/show...cub#post135232
Current - Ventura, HZ SuperCub-Freedom-Swift-AB3, PZ Typhoon, T-28 Trojan, Radian, AeroAce Biplane
Maiden - F-27C Stryker
10 years Ago - ElectroSoar 2M Glider, 2M Foam Glider, Mirage 550
Retired - Sky Fly, Red Hawk, Extreme, Challenger
cbatters is offline
Old 03-14-2010, 03:01 AM   #12
Airhead
Redneck Member
Airhead's Avatar
View Airhead's Gallery23
Globetrotter Pilot  Ambassador Award
Friends: (29)
yup Clint,
Way better than tearing up the battery box..
Bruce
AMA 873912
Project Globetrotter participant
If it ain't broke, I'll fix it till it is.
Airhead is offline
Old 03-16-2010, 03:41 AM   #13
Scarface26
People seem to favor the GWS 10 x 6 prop (EP1060) as a slightly more powerful replacement for the stock 9 x 6. Also the Parkzone 10 x 8 prop for the Parkzone P-51 airplane. The Super Cub optional float kit includes a 10 x 8 prop for extra power needed for water takeoffs. These are mounted to the stock gearbox BTW.
Scarface26 is offline
Old 03-16-2010, 10:10 PM   #14
cbatters
cbatters's Avatar
Friends: (4)
Note: 10 x 8 is pulling a lot of amps through the ESC/motor so you may want to avoid running wide open throttle except when you need it.
cbatters is offline
Old 03-16-2010, 11:54 PM   #15
Scarface26
Smile
Thanx. I hope to get a watt meter someday so I can check such things out.
Old 03-17-2010, 12:26 AM   #16
Airhead
Redneck Member
Airhead's Avatar
Friends: (29)
hey,
I think tower Hobbies has one for about $50.00..
Bruce
AMA 873912
Airhead is offline
Old 03-17-2010, 12:43 AM   #17
Nived
Does anyone know a good good website to buy inexpensive props and other Super Cub parts?
Nived is offline
Old 03-17-2010, 12:56 AM   #18
groundrushesup
1kW
Friends: (20)
"I recommend http://www.rcslot.com for their good prices"
Old 03-25-2010, 01:27 AM   #19
Nived
I received my HZ Super Cub on March 12th. The next week I went home for spring break and unfortunately I didn't have room in the car for my Super Cub. It's too bad because there was some good flying weather that week. Now I'm back and I'm just waiting for a good day to make the maiden flight.
Here is a list of the mods I made:
ID:	123922   Click image for larger version
ID:	123923   Click image for larger version
Nived is offline
Old 03-25-2010, 06:28 AM   #20
1320fastback
Good job, even with a blurry pic I can tell you did a great job.
I waited to mod mine as things broke and I think its a good idea to do them now before things have a chance to get damaged in the first place.
Old 03-28-2010, 07:46 AM   #21
Nived
My Super Cub had it's first flights today. I crashed it a few times but the damage was pretty minor. Nothing that glue and tape can't fix. I'll post more detail later.
Nived is offline
Tags
durability , modifications , mods , super cub
HZ Super Cub with LED's flyer88 ParkFlyers 3 03-07-2009 02:15 AM
L19 HZ Super Cub C130 Load General Electric Discussions 31 01-21-2009 07:30 PM
HZ Super Cub…what next? MarK6565 Beginners 11 11-08-2008 01:45 AM
HZ Super Cub Vidoes CubFlyer Video Parking lot 0 08-05-2008 05:32 AM
HZ Super Cub Range! barlowe General Electric Discussions 4 01-23-2008 07:44 AM
Page generated in 0.67011 seconds with 65 queries
