Old 05-11-2010, 01:03 PM   #1
Insomniac
Insomniac's Avatar
Send a message via MSN to Insomniac
Default LED wiring for dummies (Mini how-to)
I happened to buy a whole bunch of cheap LEDs a few days ago and figured I'd use a couple of them as lighting on my scratchbuilt plane. After doing that I've decided to post a very, very basic little how-to for anyone who wants to try their hand at adding LEDs to their plane, but isn't quite sure of how to wire them. To those of you with some electronics knowledge, perhaps you can help me out on the bits that I'm not too sure on .
I'm going to assume pretty much zero electronics knowledge for this, so the over simplification isn't just me being patronizing. I'm not going to explain what series and parallel are though, you can use the internet for that.
First off, I've only got a basic understanding of this myself, so if you follow these instructions and your plane fails to work/catches on fire/looks silly/becomes sentient and steals your car, it's not my fault. You have been warned.
Anyway, here's how I went about doing it:
1: First off, you'll have to get some LEDs. I bought a bunch of 5mm LEDs from Dealextreme, though there are many, many places to buy them cheaply. I'd recommend against getting them from an actual shop, as they tend to be way more expensive. For what you'll be using them for, they don't need to be top quality brand name LEDs. Cheap ones from the miraculous internet will suffice. For this little project I went with 2 bright blue LEDs, for a couple of reasons. Firstly, I didn't have any resistors on hand so the more LEDs I used, the harder it would be to find suitable resistors in the clock radio I'd torn apart for this very purpose. Secondly, my green LEDs hadn't arrived yet, so to do one on each wingtip, green and red in the traditional way wouldn't work. Hence why I went with blue.
2: The second step for me was to lightly sand my LEDs to make them a bit less directional. As they were, there was very little light emmited from the side and a helluvalot emmitted from out the front. Sanding them down a bit makes them look better from more angles.
3: Now you've gotta decide how your going to power them. I decided to make mine plug into a spare channel on my receiver (the batt channel in this case). It seems that my particular reciever is wired with all the neutral pins wired together, and all the positive pins wired to eachother. I'd assume that all receivers are like this but I can't be sure, so it's best to check how your particular set is wired before you do this. Because of this, it means that by plugging my LEDs into the spare channel, I'm basically plugging my LEDs straight into my ESC's built in BEC.
If you decide to power your LEDs in this way, be mindful of the current draw. Each LED only draws about 20-40 ma, and this will all come out of the availabe current the BEC is supplying which also has to run your RX and servos. In my case, my ESC had a 1.5 amp BEC, so seeing as I'm only running two servos from it, my little twin LED system isn't going to be a problem at all.
You do have a couple of other options on where you get the power from. The first is to wire an adapter so that you are using the voltage straight out of your flight battery. The upside of this is the higher voltage you'll get, which means it's easier to wire lots of LEDs and you'll need less resistors to do it. The downside is that the battery voltage will fluctuate, so you risk either running too much current through your LEDs, or having them get very dim as the battery wears down. Not really an ideal solution.
The other option is to use another power regulator, either a standalone BEC or some other circuit to run your LEDs off. It'll add weight, but it means that if you stuff up your LED wiring and they short in midair, you are less likely to come plummeting out of the sky, which is what will happen if your LEDs short out and you're using the same power supply that your receiver is running off.
4: Next up, it's time to start drawing your circuit. You can choose to wire them in either parallel or series, or a combination of both. The basic rules you need to know are these:
Every series string of LEDs needs at least one resistor to limit the current flow. This will prevent the LEDs from entering 'thermal runaway' and burning up. Basically the resistor will limit the current and keep your LEDs safe.
Every parallel circuit needs its own resistor as well. You can't just wire two leds in parallel with one resistor. You would need one resistor for each LED. Think of each LED as it's own little series circuit: You can have as many LEDs in these little series circuits as you want, but you must have a resistor in there too. Essentially, every single LED will need at least one resistor in series with it. So 4 LEDs in series will need only one resistor (as each LED will still be in series with a resistor), but if you broke that circuit up into two smaller ones in parallel, with two LEDs in each, you would need two resistors (so that every LED will still be in series with one resistor) Confusing? That's what happens when I don't proofread and edit for clarity. Moving on...
As you add LEDs in series, the voltage required adds up. When you read 'foward voltage' in the specs of an LED, it just means the voltage that LED runs on. The 'foward' is because current only flows through an LED in one direction. You can't have a string of LEDs with a total voltage requirement which is higher than your supply voltage, as the LEDs won't be able to get the voltage they need to run correctly. It is OK to put LEDs with different voltage requirements in both series and parallel, it doesn't affect anything really.
In any series circuit, the current will be the same through the whole thing. This means that if you've got LEDs with different current requirements, DON'T put them in series, as you won't be able to give each LED the right current. They will all have the same current flowing through them. If you want to use an LED with a different current requirement in your circuit, put it in parallel and give it it's own resistor in series (as we must).
Apparently (I'm not too sure on this myself), you are supposed to make sure your series LEDs require at least 2 volts or so less than what your supply puts out, to make up for the voltage lost across the resistor. I'm not sure if this is accurate though, because it seems to me that the formula used to figure out the resistors we need ought to compensate for this by selecting a low resistence. I dunno. I'll wait until somone who knows what they're talking about posts and then edit this. Until then, try and leave a few volts between the required voltage and your supply voltage.
5: Now you've got to draw a diagram of your circuit, and so do I. As I couldn't be bothered scanning my terrible diagram from earlier, I'll draw up a quick one to show how I wired my circuit. As previously mentioned, I'm running my LEDs from the 5V present at the receiver, and I'm running the two blue LEDs in parallel, with their own resistors.
Aah, there we go. Paint skillz to the rescue:
Ok, that's the diagram of my little circuit. To those of you with utterly no electronics experience, the little bit down the bottom reperesents my power supply, the triangle type things are the LEDs (I've probably drawn them backwards), and the little sqiggly bits arn't where I got the wires tangled: Those are the resistors. We'll find the resistance they need to be in a moment. So lay out your diagram, making sure the series bits don't require more voltage than you've got and ensure you've got a resistor in series with every LED. Now it's time for...
6: Math: There's a simple little formula you can use to find out what resistors you're going to need, though there are also online calculators that will do it. We'll use the formula though.
Essentially, to work out what resistors to use, you do the formula for every series circuit you've got. I've got two series circuits (in parallel with eachother). I'd have to do the formula twice, but it turns out both of my resistors will be the same, as both of my series circuits are identical.
The forumula is this: R= (Vs - Vl)/I
Because I didn't use the proper subscripts there, I'll explain what I've written to avoid confusion. Vs and Vl arn't VxS and Vxl. 'Vs' is the voltage of the supply (hence the s), and 'Vl' is the combined voltage required by the LEDs (hence the l (I know, it looks like an I)) For multiple series LEDs, you add their total required voltages to find the value you need to use for Vl. The I stands for the current, in amps, you want to flow through the LEDs.
So in my case, resistance (R), equals 5V (Vs, voltage of supply) minus 3.4 (The voltage required by my single LED, Vl), all divided by 0.03 (the current in amps I want my LEDs running at). Remember, you'd usually have to do this formula once for each resistor, but seeing as mine will be the same I don't have to.
You'll typically want about 20-30ma (milliamps) for this type of LED, with the voltage pretty easy to guesstimate by the colour. Google it and you'll find charts showing typical voltages in relation to LED colour. Remember, you must put the current into amps for the formula (so divide ma by 1000)
So the result of my formula, R=(5-3.4)/0.03 is 53. So ideally I need a 53 ohm resistor. Unfortunately I don't think 53 ohms is a standard value. So what I should do is use the next highest value (as this will put the actual current just a little below what you wanted). What I actually did was use a resistor of about 50 ohms, for two reasons. One, my LEDs ought to be able to handle a bit more than 30 ma of current. Two, I didn't have any spare resistors on hand and 50 ohms was the closest I managed to find by prodding around in an old clock radio with a multimeter .
7: So now it's time to solder it all up. I used some very thin, enamal coated wire to save weight and increase the risk of short circuiting the whole thing when I inevitably nick the wire with somthing abrasive. I soldered my 50 ohm resistors to one leg of each diode (it doesn't matter which), then soldered those two circuits in parallel. Make sure you get the polarity of your LEDs right: They typically have one leg a bit longer: This is the positive lead. Some others have a little flat spot on the base of the LED's plastic: This side is negative. If you get them backwards, they won't light.
Once I'd soldered those together, I grabbed an old servo extension lead (you can use one of these, or steal the lead from a bad servo). I cut it, and then removed the yellow wire which takes a signal from the RX. We only need the red and black (in my case, red and brown) wires which are the positive and negative leads. I soldered the positive lead to the positive side of my circuit, and likewise with the negative side and put heatshrink all over the exposed bits. The resistors arn't visible in the final product as they are hiding under the heatshrink near the leds. Here's some pictures:
After all was said and done, I grabbed my heaviest, most overweight and unaerodynamic plane, and proceeded to cut holes in it and add some more superflous wiring, and voila! LIGHTS!
Now, I haven't had a chance to fly it but my LED's arn't getting hot (I measured the total current at 65ma), the plane's still working and I've seen no magic smoke, so it would seem that my methods are correct.
There are a few downsides to this though: Firstly, these lights will run a battery down with no regard to the fact that lipos shouldn't get run down too far. Crash in a high tree with these lights and they'll happily ruin your lipo while you ruin the airframe by throwing sticks at it trying to make it fall. You also can't control these lights via the reciever. When the battery is on, so are they. I also didn't wire a switch in so that I could turn them on or off, because as the cable is so short on my setup I'm just going to unplug them when I don't need them.
So yeah, a long winded, confusing explanation of somthing that you all probably knew anyway, but hopefully it'll help somone at some point, maybe. This should also work for making lights for helicopters such as the blade CX, though I'm not sure how many amps their internal BEC is.
A crashed airplane is like a jigsaw puzzle...
Insomniac is offline
Old 05-11-2010, 02:06 PM   #2
ggunners
Send a message via AIM to ggunners
With the low draw of the LEDs, a lot of folks are using a dual tap directly to the batteries or even a separate battery for the lights. Of course, 2 LEDs are not much of a current draw.
Some of the really bright lights we've seen are 12 volts and a small 3 cell LiPo works quite nicely, usually far longer than a nights flying.
-- ggunners
ggunners is offline
Old 05-11-2010, 05:27 PM   #3
pd1
Still Learning
pd1's Avatar
View pd1's Gallery69
Club: Cape Ann RC Model Club
Friends: (53)
Nice write up.
I'll have to try that.
Paul
pd1 is offline
Old 05-11-2010, 10:25 PM   #4
-- ggunners
Still need the series resistors. A direct connection of an LED across the battery risks burning out the LED. Or worse, the possibility of the LED shorting out, and shorting out your receiver battery.
For those that have looked at those AAA sized LED flashlights with no resistors, what they are doing is using the internal resistance of the AAA alkaline cells to limit the current. If you replaced those AAA cells with three alkaline "D" cells, you'd have the same voltage. But the much higher current available from the "D" cells would burn up the LED's. (Yeah, I tried it, measured the current, it was over two Amps.)
Old 05-12-2010, 02:52 PM   #5
mesh
I have also been futzing around with some dealextreme LEDs, resistors I scavenged from an old radio, and even a LED driver. It was annoying trying to find the right resistor
However, on one of my latest shopping sprees at Hobbyking, I added a Turnigy white 60 LED strip to the cart, then promptly forgot about it. (There are other colors as well.)
When it showed up, I was blown away! It is a flexible strip of 60 surface mounted LEDs. It's bright as hell from 3S, and fairly bright on 2S.
There is a resistor for every 3 LEDs, it is designed so that you can cut off any multiple of 3, and there are solder points on each section.
Simple, effective, flexible and cheap. Made me regret the hours I spent fiddling with regular LEDs and resistors
mesh is offline
Old 05-12-2010, 04:20 PM   #6
If you are in the USA, Radio Shack has a whole assortment of resistors.
Old 05-12-2010, 09:33 PM   #7
DragonWeezel
Thumbs up LED's (R U MY twin?) Gemini?
Yesterday, I was doing the exact same thing (figuring out an LED light scheme) for my "new" striker*. I'm going to do my first glassing job on an F-27C, and I'm trying to do it to the hilt. I want lights, and smoking hot chicks to walk up to me every time I fly it.
I'm doing my own version of afterburner lights & landing thanks to one of those cheap led powered flashlights. I also made a purchase yesterday pm for 2x 48 red and green light strips & 2 individual strobes for the top of the fins. I can't decide if I'm going to use the standard fins, or if I'm going to use the SFG's froma typhoon... They look hella cool in there. but I digress... again.
The flashlight gave me a ring of 8 white LED's. I took that and I put 1 jumbo superbright white LED in the center (fits perfect). Tested it out last night, and it's BRIGHT AS THE SUN, but very directional Front light, with a very wide scattered ring around the outside. They will be powered from the main plug, by a 5V regulator soldered to the ESC, and I'm still working out details on switching them, but it will be in the air somehow. (I may use another transistor to do that from aux channel signal lead w/ a small cap. We'll see how that works. If you've done this before, please let me know how I should go about that.
So I'll that 8 LED circle template from the flashlight, or I'll get some circular circuit boards from Rad shack. I found them yesterday! I'll drill a hole through the center for the motor shaft to go through and I'll glue it to the mount. The bad part is I need to eliminate drag, so it will only be as wide as the motor. I'll be putting Surface Mount red and orange LED's for the "engine glow".
While all these lights this may suck some juice, it'll be nothing compared to what that motor eats at WOT. I'm really concerned with it looking good & being fast so the LEDs will be flushed into the glass. Hopefully this will give it a little bit of "glow" through the paint, we'll see.
The landing lights will come out of the cone at a flat angle. I need it bright because I have hard time judging whether or not I'm behind trees at twilight, and I'm sure this will help
It's got some powerful turnigy motor, but I can't remember which one . I know, it's like not knowing what engine is in my car (p.s. it's an LS1 4 the car). A 35c 3s (moving 2 4S when $ comes in), 60A Eflight pro and a 6x5.5 prop.
DragonWeezel is offline
Old 05-12-2010, 10:34 PM   #8
You can buy those LED's directly from electronics wholesalers, such as www.mouser.com or www.digikey.com.
Check out www.mouser.com at http://www.mouser.com/Optoelectronic...d=leds&FS=True
Digikey has thousands of different LED's from simple units to some that warn the user not to look directly at them because of potential eye damage. (These can get expensive, like about $10.00) They also come in "Spotlight" or "Floodlight" configurations with different "viewing angles" available from 3 or 4 degrees, to over 100 degrees.
They come in all different colors from red, white, blue, yellow, green.
Old 05-13-2010, 01:15 AM   #9
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Cool!
I think I need a signature.
Larry
Larry3215 is offline
Old 05-13-2010, 10:56 AM   #10
Insomniac
Insomniac's Avatar
Well, I flew it today. It was getting a bit dark, and the lights definitely helped me figure out which way it was going. They also didn't seem to cause any problems with the plane's electronics. However, they weren't perfect. Even at a distance, the lights were VERY bright when facing me, and the deep blue colour was a little uncomfortable to look at... it had that slight haze around them you see around a blacklight tube, where your eyes struggle to focus clearly on a tiny, bright dot of an odd colour.
Also, when turning the LEDS would overlap, and as they drifted apart it would cause an optical illusion, it felt like my eyes were going a little crosseyed as my brain was seeing it as one light in two slightly different places, rather than two individual lights. Odd.
Old 05-19-2010, 04:04 AM   #11
crshbandit
crshbandit's Avatar
View crshbandit's Gallery1
Club: looking for a good club
Be careful Insomniac! We don't want to hear about you on the news, "man found passed out in field in the dark with glowing UFO nearby!"./\
crshbandit is offline
Old 05-19-2010, 04:49 AM   #12
Insomniac
Insomniac's Avatar
Haha, don't worry, that won't happen till I put a light kit on my circle shaped plane (Nutball).
Oh, and incidently I kinda totalled this one... Went flying with a friend who made the same plane... did some combat, low formation flying, had several crashes (had to glue the winglets back on a few times), flew limbo under a low streamer etc... of course none of this did any real damage... it was when I was just making a simple left hand turn a bit too low to the ground that I got too complacent and nosed it in. Smashed the nose into two seperate bits both hanging from the plane by the wires... hot glued it back together, went to throw it and discovered my elevator servo was stripped, and my motor was screeching and not revving up properly.
I've fixed the servo and will figure out if it's the motor or speed control that's got a bad connection once I get some more bullet connnectors.
The lights still work perfectly though!
Old 05-20-2010, 01:36 AM   #13
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Nice job. Couple of things to mention. I use a separate lipo single cell to run mine.
Great if you have an old weak small pack, or I've even used the lipo out of an old cell phone. As the LED's draw so little, it doesn't take much to run em for a long long time.
Couple of mine have upwards of 50 LED's on them, and they run off of said cell phone lipo, which is about the size and weight of a bec. I've even done one to run off of those tiny lipos from the PZ micros.
Anyhow, now that you got the LED thing handled, look up 555 timers. RadioShack and all the electronics places mentioned above carry em. And making the circuit is a piece of cake. You can then have the lamps blink/stobe/etc. And with just swapping a couple of resisters around you can set how long the LED's stay on or off. I did my very first one on a Slow-V that had tri colored LED bulbs. The 555's were set to blink the different colors so the colors went from red to blue to green while it flew. Took a lot of head scratching getting the timing set up on three separate colors to come on and off at the right time but it was well worth it in the end.
Moving on, I used 555's to build the strobes and beacon LED's in my big 182 Cessna.
Looks pretty cool, rudder lamp flashing on and off, and strobes....well strobing(?) Along with the Nav lamps and landing lamps. Gotta love LED's.
Oh and a warning. Those Super Bright white LED's will give you one heck of a headache if you look directly into them.
Glacier Girl is offline
Old 05-20-2010, 02:02 AM   #14
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
View hillbillynamedpossum's Gallery5
Club: Is under the seat
Friends: (8)
Radio Shak has a clear, blinking led....Im thinking it'll work great for a strobe. Its about a second on and half second off.
Possum
Founder, Chief Builder, Head Designer, an Lead Test Pilot of Possum Holler Aircraft Company. (A made up company that transforms styrofoam into packing peanuts, and balsa wood into toothpicks)
hillbillynamedpossum is offline
Old 06-12-2010, 03:59 PM   #15
Insomniac
Insomniac's Avatar
A while back I made a Nutball (my second scratchbuild), but didn't fly it much as I had made dodgy landing gear and used too small an ESC, making it rather underpowered and only able to run on 2s. I recently put new wheels on it, replaced the tiny 12A ESC a 25A and have been running it on 1300mah 3s batteries as opposed to the 800mah 2s ones I had been using.
Now it hovers at half throttle, screams through the air uncontrollably at WOT (large control surfaces and no expo) and is a helluva lot more fun to fly. Yesterday, I decided to go ahead and add some lights to it (funnily enough I had to refer back to this how-to as I'd forgotten the formula for calculating resistors ).
This time I decided to use the battery to power the LEDS directly, as the higher voltage means I can use more LEDs in series which simplifies the wiring. Rather than solder the lights to the main power plug directly, I've attached them to a modified balance plug. This means that if I don't plug the balence lead of the battery into the plane, the lights are off. If I plug it in, the balance lead acts like a tap directly into the battery's main leads.
I went with three series circuits (each with their own resistor), in parallel with eachother. Two of these have 2 white LEDs and an amber, with the third having the red, green and remaining white LED.
These are positioned to help with orientation as much as possible... Two white LEDs illuminate the underside, two more white LEDs illuminate the top. Two wide angle amber LEDs point fowards, and a diffused red LED is on the left wingtip, and a green on the right. Finally, there is a white LED shining down a drinking straw attached to the leading edge of the vertical stab. I avoided blue to eliminate the problem of the light being uncomfortable to look at due to how they eye focusses on extreme wavelengths.
The end result is pretty conservative as far as night flying systems go, with a measly nine LEDs, but it's very effective. I flew tonight in pitch darkness and was able to maintain complete control until it was at a VERY high altitude. I lost orientation once when low, but managed to recover quickly enough to avoid crashing.
The only downside is that I was VERY messy with the wiring so now it looks kind of ugly . Oh well. Also, the LiPo in the pictures is never used on this plane, I just used it to power the lights for the photos.
It's amazing how such a small number of LEDs can make it possible to fly at times when it would normally be impossibly dark.
ID:	130099   Click image for larger version
ID:	130100   Click image for larger version
ID:	130101   Click image for larger version
ID:	130102   Click image for larger version
Electronics for Dummies Airhead Beginners 116 12-09-2009 07:31 PM
Helis For Dummies Murocflyer Micro Sized Electric Helicopters 32 02-19-2008 10:07 AM
Servo math for DUMMIES TeamTigerPaw Aerodynamics 0 02-02-2008 12:20 AM
AP Dummies stinkweed007 Aerial Photography 12 04-27-2007 04:25 PM
R/C Planes for Dummies? Wind Shear Beginners 26 07-26-2006 08:57 PM
Page generated in 0.71250 seconds with 54 queries
