Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 06-23-2010, 10:34 PM   #1
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
Default Profile pusher jet construction techniques/tips
I did this thread over on RCGroups, and figured it would be good here too.
I'm often asked about techniques I use to build these profile pusher jets, so I thought I'd start a thread that describes many of the techniques I use and tips I've discovered in the past few years in order to have all the information in a single place.
Keith Sparks has a wonderful book called "Building With Foam" that has many tricks and tips, and it is a highly recommended read. As well as all of the build threads that Steve Shumate has done for his wonderful parkjets. But these builds are typically for built-up foam planes, not the profile jets (although most of the techniques can be applied to the profiles as well).
My thread will focus more specifically on the profile mid-mount motor pusher jets like the Nico Hobbies Mini Pusher Jets, the 6mmflyrc Quick-Build Series, the Yardbird RC jets, the designs by Tomas Hellberg, and the planes and plans posted by people like "nac", "jetcaptain" and "rc cal" on RCGroups.
I will make a separate post for each technique/tip.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 06-23-2010, 10:42 PM   #2
crxmanpat's Avatar
Friends: (24)
Default Building materials
First I'll talk about a list of materials that I typically use for these builds. If you are downloading the plans and building from scratch, then you will need to buy foam. Most of these are done with 3mm or 6mm depron, and a good source is www.rcfoam.com. However, most hobby shops now carry sheets of depron as these planes have become more popular over the last few years.
There are other sources of foam that can be used, such as paper backed foam board that can be found at most craft stores (but you'll have to soak the board and peel the paper off), or fan-fold foam (or "FFF") which is normally found at home improvement stores. But personally, I like depron the best as it needs no prep.
Most builds typically have a carbon fiber tube for the wing spar. For my 6mm builds, I usually buy Midwest Products Item #5821 as that is what my LHS sells, and it has an outside diameter of 4mm, giving me 2mm of working room for epoxy when using 6mm foam. There are also times when using CF strips or smaller diameter tubes may apply, like my 3mm planes that use a 1mm x 3mm CF stick. The LHS may have a supply of various sizes of both tubes and strips.
The final material needed is lite ply for the motor mount. I use 1/8" lite ply (and I also have a source for laser cut ply mounts which are also 1/8"). If you buy a kit from 6mmFlyRC, Grayson Hobby or the like, you will most likely get the ply mount included (as well as a CF spar and control horns, etc). For my 3mm planes I use 1/16 ply for the motor mount.
For cutting the foam, I use a standard Xacto knife with a No 11 blade. I buy these in bulk as the blades go dull after a short period of time. And for anyone whose worked with covering, you know that when the blade goes dull it tends to tear the covering. The same goes for foam. Once the blade dulls it will tear the foam on the bottom side. So change that blade often. I typically use 2 blades per plane.
There are several types of glue that can be used. My favorite is UHU Por. This stuff is very strong and holds up well over time. The only problem is that it's kind of expensive for such a small tube of glue. But as far as foam glues go, this stuff can't be beat!
My second favorite glue is Beacon 3-in-1 Advanced Adhesive. You can find this stuff in 4oz bottles in most craft stores like Michael's or Jo-Ann's (not sure if it's available anywhere else except the US though). The only caution is that this stuff has some acetone in it. A test of a glob on a piece of scrap depron revealed that it would actually eat the foam. But if you just put on a very thin bead, squeeze the parts together, separate and then press together again, you get a good bond. Dry in 20 minutes, fully cured in 24 hours. Great stuff.
And I have also used tubes of leftover GWS glue, but only as a last resort.
But the trick to ALL of these glues is that they must be used properly in order to work. These are all "contact cements", which means that you apply glue to the surfaces to be joined, press the parts together briefly and separate, allow the glue to get "tacky", then rejoin the parts. All of these cure within 24 hours, so I like to glue a plane up in a single sitting, then allow it to cure overnight before removing any tape or continuing with construction.
Pat Gagnon
Old 06-23-2010, 10:54 PM   #3
crxmanpat's Avatar
Friends: (24)
Default Installing the wing spar
The first step to almost every build (once all the foam parts are cut out) is to install the wing spar. You will need:
Flat, level working surface
Knife
CF spar
Straight edge (I use a 36" metal ruler)
Tape (low tack 3M painters tape is best)
Glue (I use 5-minute epoxy)
Scraper (any straight edge scraper will work, I use old credit cards and such)
First, determine the length of your CF spar and cut as needed. Then, using the straight edge, cut your spar slot in the foam. Be sure to cut the slot a few milimeters longer and wider than the CF spar so that the epoxy can work around the edges.
Next, take a length of tape and entirely cover the slot, then flip the wing over. Now use some tape to "frame out" the slot opening. This is to prevent excess epoxy from sticking to the foam and creates a nice clean install. Before mixing your epoxy, be sure you have a nice flat and level surface to work on, as well as something to weigh down the foam. I use a couple thick heavy books to make sure the foam stays flat while the epoxy cures.
Now mix your epoxy and run a thick bead into the slot, making sure it fills the entire opening and is about 4mm deep (DO NOT fill the entire opening, just enough to fill the bottom). Insert the CF tube and press down firmly so that the epoxy runs all around the tube. This should eliminate any air bubbles on the bottom. Finally, fill in the top of the spar with epoxy as needed so that the entire opening is completely filled with the spar and epoxy.
Use the scraper to "smooth out" the top layer of epoxy so that it is flush with the top of the opening, being careful not to get overflow on the foam. This is where the tape framework helps. Place your weights on the foam so that it remains flat during the curing process.
After the epoxy has set up, but BEFORE it fully cures, remove the tape from both sides of the foam. You will now have a smooth and solid install of your spar.
Name:	Nico Eurofighter Build Pics 002.jpg
ID:	130815 Cover one side of the channel with blue painters tape.
Name:	Nico Eurofighter Build Pics 003.jpg
ID:	130816 Flip it over and outline the other side with tape. Fill with epoxy, insert spar, level with a scraper and remove the excess epoxy.
Name:	Nico Eurofighter Build Pics 014.jpg
ID:	130817 After the glue sets up, but BEFORE it hardens, remove the tape. This side is the one that was fully covered by tape.
Name:	Nico Eurofighter Build Pics 015.jpg
ID:	130818 This was the open side where the spar was inserted.
Pat Gagnon
Old 06-23-2010, 10:57 PM   #4
crxmanpat's Avatar
Friends: (24)
Default Basic construction
Most of the parts on these planes are tabbed or slotted for ease of contruction and alignment. However, some pieces such as intakes, dividers and vertical stabilizers may require installation at an angle (for example, the vertical stabs on an F-22). Since you want to have as much surface contact as possible between the two pieces of foam, it's a good idea to sand the necessary angle in the contact surface as needed.
Before I begin gluing parts together, I always do a dry fit of the parts to ensure I cut the tabs and notches correctly. Now is the time to make any adjustments needed. You don't want to put glue on a piece only to find out it doesn't fit properly.
These jets typically go together in the following manner:
- Glue in wing spar
- Hinge/install control surfaces
- Glue on vertical stab(s)
- Glue on upper forward fuse
- Glue on lower forward fuse
- Glue on intake sides
- Glue on belly pan
- Install electronics
Once you are satisfied with fit, apply glue to one of the parts to to be joined, then press the two parts together and immediately separate again. Rejoin the parts after the glue becomes tacky. But also read the directions for the type of glue used to make sure you are using it properly.
And of course, use tape where needed to ensure parts stay together until the glue cures. Scotch tape does not stick well to depron over long periods of time. Packing tape works better for this.
Pat Gagnon
Old 06-23-2010, 11:10 PM   #5
crxmanpat's Avatar
Friends: (24)
Default Motor Mount
OK, mounting the motor has probably been one of the most challenging items that I've encountered on these builds, but I think I have it down to a science now. If you are cutting your own plane from scratch, DO NOT cut out any of the slots for the motor mount (just cut out the prop canyon). Instead, leave that foam in place until you get all parts cut out and can do some measurements.
My motor mounts consist of:
- 1/8" lite ply motor mount with 6mm notches cut in at each polar location
- 6mm depron disc cut to match the ply mount
Step one is to measure the dimensions of the notches in your mount so you will know how wide to cut the slots in your foam. Next you will need to take your motor and attach the cross mount and prop adapter/prop to it. Then take the depron disc, ply mount and assembled motor and determine the cut distance needed so that the prop hub winds up in the middle of the prop canyon when looking from front to back. Once you have all your measurements, cut the necessary foam from the parts.
After the plane is fully assembled, check to see that the area where the depron disc will glue to is completely straight and level. These jets do not require you to add any thrust angles on the motor due to the fact they are in a pusher configuration aft of the CG.
First, using the cross mount from your motor, mark the mount holes onto the ply mount. Then tap the holes with a 1/16 drill bit. Then thread the holes by installing the moutning screws. Next, glue the ply mount to the depron disc with epoxy. After the epoxy cures, remove any epoxy run out from the holes and tap the holes again. Then mount the motor.
Normally you can glue the mount in with the motor already attached, but with the prop removed. If you can do this, then that is the preferred method. If not, you will need to mount the motor after gluing in the mount.
The biggest problem with the motor mounts is that they tend to break loose after a while due to prop strikes on the ground. It helps to inspect the mount on a regular basis. To help prevent breakage, I actually use high temp hot glue to secure the foam mount the the airframe. Hot glue stays slightly flexible, and is not as susceptible to vibration as epoxy is.
Name:	Motor Mount 1.JPG
Name:	Motor Mount 2.JPG
Name:	Motor Mount 3.JPG
Name:	Motor Mount 4.JPG
Name:	Motor Mount 5.JPG
Name:	Motor Mount 6.JPG
Pat Gagnon
Old 06-23-2010, 11:14 PM   #6
crxmanpat's Avatar
Friends: (24)
Default Hinging the control surfaces
Most people hinge their control surfaces using packing tape. I used this method for quite a while, but finally got tired of the tape peeling up on me as I live in a very hot summertime climate (it can get to over 120° in my garage in the summer). But to use this method, simply cut a 45° angle on the leading edge of the control surface, then attach the control surface to the plane with a piece of packing tape. Flip the plane over, then fold the control surface back until the 45° angle is lined up even with the trailing edge of the body and add another piece of tape. This will cut down on slop in the control surface.
I then started hinging using the standard method of CA hinges and such, but that never worked out very well. Now I use 3M Blenderm for all my hinges. Works great, holds well, and won't peel up in high heat.
For control horns, I've used everything from old GWS horns, to laser cut ply horns, to homemade horns from 1/32" lite ply, to plastic scrap. Any of these work fine. I will cut a slit in the foam for the horn, then insert the horn and work it back and forth a little to open up the slot some. I'll then use hot glue and fill the slot and insert the horn.
Pat Gagnon
Old 06-23-2010, 11:23 PM   #7
crxmanpat's Avatar
Friends: (24)
Default Power System and electronics
Because of the limited size of the prop canyon, the biggest prop you can use is 7", and in some cases 6" is as big as you can go. Unfortuntely, that limits the choice of motors you can use. However, you do have options.
For the bigger 6mm planes, my absolute favorite setup is a Welgard/Suppo 2212-6 motor, a 30amp ESC and an APC 6X4E prop. This setup will give you unlimited vertical on a typical profile jet, and when used with a 1300-1500 lipo will give a flight of about 5 minutes of very spirited flying. Here are some places to get these motors:
Nico Hobbies - The Combo Deal is $28 plus shipping.
Grayson Hobby - This is the combo deal with the 30A ESC included. These V2 motors seem to hold up better than most other standard motors listed below.
Light Flight RC (search for the Suppo 2212-06) - You can get this with a 30A ESC combo for about $35.
BP Hobbies - You can get this with a 30A ESC for $36.
RC Hot Deals - Scroll down the page to the A2212/6 and the combo is $30 plus shipping.
Model Aero
RCTimer - This is just the motor, but when you add the 30A ESC the total is $22 plus shipping. This same motor is sold on Hobby King as the D2826-6.
If your model ends up heavier that the typical 15 to 20oz, you can step up to either the Grayson Super Mega Jet motor, or the BP Hobbies Ultimate outrunner. These should give you about 32oz of thrust.
For the smaller 3mm jets, I sell a good combo pack on my website that consists of a 1806N 2500kv motor and 10A ESC. On a GWS 4530 prop and a good 3S 850 lipo, you can get about 10oz of thrust.
As far as servos are concerned, any regular old 9g (for 6mm planes) or 5 gram (for 3mm planes) servo will do. I personally prefer HXT series of servos. I've beat the tar out of these and they keep on trucking. I've also used the cheap TowerPro or TP servos that you can get from Hobby City or RC Hot Deals, but they have a higher failure rate than the HXTs. And I also like the GWS Naro and Pico servos too, but they are more expensive than the HXTs. I sell both sizes of the HXT servos on my website.
Pat Gagnon
Old 06-23-2010, 11:26 PM   #8
crxmanpat's Avatar
Friends: (24)
Default Painting/Finishing/Decals
There are some people who seem to have trouble finding the right paints for foam. In the years I've been doing this, I've used Testors rattle can spray paints more than anything else. I've used it on everything from beer cooler foam (EPS, like on GWS planes) to depron, to Elapor (EPP or EPO, like on Multiplex planes). And it works on blue and pink foams as well. Some people also use Krylon H2O, but I've never seen a need to buy any myself (as I do mostly military scale models and need the colors Testors sells).
The trick with using spray paint is to spray at least 12" away from the surface, and to use light coats. It's not the paint itself that eats the foam, it's the propellant used in some spray paints that is the problem. By staying 12" away, most of the propellant will evaporate before it reaches the foam.
Another good paint is the water-based acrylic craft paints that you can find at places like Michael's (Apple Barrell brand), Jo-Ann's (DecoArt Americana brand), or the craft section at Wal-Mart. Any brand will work well, as long as it's water-based acrylic paint. And even though they don't carry true military colors, you can find just about any shade you require. These can be applied by hand with a brush, or thinned and used in an airbrush.
Most of my planes get water-slide decals applied to them for the scale markings. I use 8.5"x11" sheets of decal paper that I purchased from www.beldecal.com. You can get sheets made for both Laserjet and Inkjet printers, and clear paper as well as white paper (white paper is good for decals that have white in them, such as USAF stars and bars, as printers don't print "white" ). If you have access to a color laserjet, this is the preferred method for printing decals. Because with inkjet, you have to also apply a protective coating after printing to keep the ink from running. Laserjet printers are just much easier to work with.
Most of my decal sheets are made up of Word documents that I create by taking images from the web and the "post scale decals for downloading" thread in the Scale Electric Planes forum on RCGroups, and then sizing them as needed in Paint and pasting on the Word doc. And since I do a lot of USAF builds, I downloaded a font called "AmarilloUSAF" from the internet. This font will allow you to type words and numbers that match the USAF block type font.
Pat Gagnon
Old 06-23-2010, 11:30 PM   #9
crxmanpat's Avatar
Friends: (24)
Default Kit sources
OK, so now I've posted a lot of tips about building with depron, but what if you don't want to cut you own foam planes from plans? Here's a list of places where kits can be purchased:
Nico Hobbies - Great place for mini versions of the various profile pusher jets seen here and other places, as well as everything needed to outfit them for flight. (Disclosure - I'm the owner of the site, so of course I'm going to plug it first )
6mmFlyRC - Specializing in the Steve Shumate ("jetset44" on RCGroups) full fuse builds (called the "Original Series"), and the larger profile pusher jets (called the "Quick Build Series").
Yardbird RC - They have two sets of profile pushers; one in 6mm depron slightly smaller than the 6mmFlyRC planes, and one of planes slightly smaller than the Nico Hobbies planes.
I'm sure there are more sites that offer kits, and many many more that offer plans. But I don't want to make a huge list. If you know of another site that sells kits, please feel free to post it up here.
Pat Gagnon
Old 06-26-2010, 01:44 PM   #10
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
View Alpea42's Gallery59
Friends: (25)
Nice thread Pat.. James is building The Parkjets Bandit. PARKJETS RULE...
THE B-2 Worlds most expensive airplane.
Alpea42 is offline
Old 08-17-2010, 12:51 PM   #11
rctimer
Club: RCTimer hobby Group
RC Hot Deals - Scroll down the page to the A2212/6 and the combo is on $30.
Model Aero
RCTimer is also selling this same combo on eBay, and as of this writing you can find them as low as $22 shipped from China.
If your model ends up heavier that the typical 15 to 20oz, you can step up to either the Grayson Super Mega Jet motor, the Little Screamers Super Park Jet motor (if available), or the BP Hobbies Ultimate outrunner. These should give you about 32oz of thrust.
For the smaller 3mm jets, I sell a good combo pack on my website that consists of a 1806N 2500kv motor and 10A ESC. On a GWS 4530 prop and a good 3S 450 lipo, you can get about 10oz of thrust.
You can view: http://www.rctimer.com/index.php?app=goods&id=153 2212-6
Nina
rctimer is offline
Old 08-17-2010, 08:09 PM   #12
crxmanpat's Avatar
Friends: (24)
Nina,
Thanks for the post. When I originally wrote this, RC Timer had just come on the market with the eBay ads. Nice to see you guys with your own website now. Those are great motors for the pusher jets.
Pat Gagnon
Old 08-18-2010, 02:51 AM   #13
rctimer
Nina,
crxmanpat,
Thanks for your message.
Yes, RCTimer online hobby store opened on 21/Sep 2009.
If you have any further questions please do not hesitate to contact us.
Nina
rctimer is offline
Old 02-29-2012, 11:28 PM   #14
crxmanpat's Avatar
Friends: (24)
So this thread has been sitting out there a while, and I went back through and updated some of the posts with new or revised information.
I also just placed an order with Suppo Model, and will soon be carrying the 2212-6 and 30A ESCs on my site too. I'll also be expanding my line to include mini versions of most of Steve Shumate's planes, as well as larger pushers that I have personally designed over the past few years to include a Concorde, Su-47, Su-50 Pak Fa, J-20 and Su-30MK.
More updates to come!
Pat Gagnon
Old 03-05-2012, 04:23 PM   #15
Lord Vader
Great article, lots of info to take in. Can't wait to get started.
Lord Vader is offline
Old 03-05-2012, 08:37 PM   #16
crxmanpat's Avatar
Friends: (24)
Good luck with whatever you decide to build. If you have questions, don't hesitate to ask. There's a lot of foam building expertise on this forum.
Pat Gagnon
Old 06-26-2012, 11:22 PM   #17
crxmanpat's Avatar
Friends: (24)
So I finally got the 2212-6 motors and 30A ESCs. Not only are those available, but I also now have a full power package that would work for most pusher jets that use only 2 servos. The package includes:
2212-6 motor, 30A ESC, 2 HXT900 servos, a Hyperion G3 3S 1300 25C lipo, two APC-style 6X4E props and a pair of XT connectors (like Deans Ultras).
And new models are coming soon!
Pat Gagnon
profile jet pusher? Theycallmecrash Electric Ducted Fan Jets 7 10-08-2012 09:53 PM
Nico Hobbies Profile Mini-71 Pusher Jet crxmanpat Pusher Park Jets 14 08-04-2010 05:55 PM
Profile pusher jet construction techniques crxmanpat Pusher Park Jets 9 11-02-2009 10:58 PM
Profile F-16 pusher plane with jet-like performance michael7810 Electric Ducted Fan Jets 7 06-01-2008 05:53 PM
profile jet pusher w/thrustvectoring ericthetree Electric Ducted Fan Jets 0 04-11-2007 04:28 PM
Page generated in 0.31390 seconds with 53 queries
