Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Power - Batteries, Chargers, ESCs and More > Brushless Motor Construction
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 07-02-2010, 01:08 AM   #1
roberted5r/cnut
Default Need advice on winds for Kv
I'm going to do a CDrom wind on a GBv™ 22.7mm Brushless Outrunner Kit from gobrusless.
I understand how to wind it but don't know how many turns or winds to get the right Kv rate.
If anyone has built this motor could they reply with some specs with respect to prop size,effeciency and thrust.
thanks,Robert
roberted5r/cnut is offline
Old 07-02-2010, 05:10 AM   #2
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
Suggest you look at the StrongRCMotors and page down and look at the winding chart.
http://www.strongrcmotors.com/Instru...ng%20Motor.htm
It's essentially the same motor.
Here's my few winds experience:
GBv: 15T/24g newbie wire - Y
KV with faux prop:
1767/1773/1774/1770 – Pretty good consistency.
GBx: 25T 26g newbie - Wye (GBx uses the same stator but has more room front to back).
10350/9.86v=1050KV
I also tried this and still fly it on a small stick plane with success:
GBv: 35T / 28g newbie Y = 750KV (x 1.73 > 1300KV)
10890/7.91 = 1376 delta measured
15870/11.56 = 1372 measured
I terminated it delta and fly it with an GWS 8x4 HD on 3S.
You can only get 2 layers on the GBv or you end up rubbing on the can. That's why I tried the high wind # of 28g. You can put a tiny spacer in there and maybe get 3 layers of fatter wire (26, maybe 24) in.
Don't have efficiency or thrust data. There used to be a discussion forum with that data at GoBrushless but I couldn't find it. It wasn't very active anymore.
Have you seen this thread?
http://www.rcgroups.com/forums/showthread.php?t=878258
fly
flydiver is offline
Old 07-15-2010, 03:09 AM   #3
roberted5r/cnut
KV with faux prop:
10350/9.86v=1050KV
Thanks,
I'm going to try 15-20 winds,the most I can get on in 2 layers and see what happens.
lower kv bigger prop, or higher kv smaller prop? Forge Power Systems 15 01-16-2010 07:03 PM
Need Advice Rewinding BL Motor To Get Higher KV phupper Brushless Motor Construction 27 10-28-2009 12:38 AM
AP in very high costal winds. zoom505 Aerial Photography 2 08-05-2008 08:15 AM
20 MPH winds... JasonInAugusta Video Parking lot 0 10-12-2007 03:04 AM
winds? airfoilz or balsa? Septic_shock General Electric Discussions 5 03-27-2007 08:53 PM
Page generated in 0.05671 seconds with 23 queries
