Old 08-11-2010, 08:07 PM   #1
Friends: (16)
Default Soldering A123 Cells
I've just purchased a total of 30 A123 cells direct from China. These were ordered without tabs and need to be soldered into place. I know, you are not supposed to directly solder these (or any types) of cells, but it works OK if done properly.
First attempts to solder with plain rosin core solder did not work well. The solder joints were typical of a cold solder joint.
Next, an 80 watt soldering iron was purchased, Weller model #SPG-80L. And some rosin soldering flux, Radio Shack # 64-022, and some 120 grit emery cloth, available from the hardware store. (Sand paper may not be a good idea, it can leave bits of abrasive on your work.) Last but not least, a squirt bottle of pure denatured alcohol, (Not the drugstore type, that is 20% water) some paper towels, and some rubber gloves to keep the flux off of your hands.
First, place a small amount of flux (about twice the area of the intended soldering spot) directly on the cell to be soldered, and scrub the flux and battery with the emery cloth for a second or two. No need to overdo it. When scrubbing the battery through the flux, apparently that flux keeps the battery surface clean before you hit it with the soldering iron.
Then using the Weller's 1/4 inch iron plated tip, very quickly place the iron and solder on the battery and "wet" the surface of the battery with a bit of rosin core solder. And, last, pre-tin your copper jumper strap, heat it up with the soldering iron til the solder melts. Then press the jumper strap with the hot soldering iron against the batteries pretinned area until the batteries' tinned area melts. Should not take more than two seconds or so. It helps to have an 1/8 inch diameter wood dowel or similar item to hold the strap down on the battery for a second or two after removing the soldering iron, to make certain the copper jumper strap does not lift off slightly.
And, after the soldering job is done, immediately wipe that soldering job clean with a piece of paper towel with alcohol on it, both to remove the soldering flux, and to cool down the soldering job on the battery.
Obviously, with pure alcohol, be careful of the fire hazard. And, use proper ventilation with the soldering fumes from the rosin flux.
I've tested these cells before and after soldering in this manner, and noted no difference in Milliampere Hour Rating, or voltage under load. Perhaps long term life might be affected, that remains to be seen.
My three 6S2P Dewalt DC9360 batteries are now in their third flying season, with some 300 Ampere Hours cycled through each of them. And they have the same exact performance as when new, in 2007.
OK, the pair of 6S2P A123 battery packs are now complete. As for soldering, I'd purchased some all purpose flux from this company. It worked far and above better than the Radio Shack flux. Don't know what this stuff is, so the cells were cleaned three times in pure alcohol after soldering, just in case!
http://www.cheapbatterypacks.com/?me...CD6B&sid=95995
Old 08-11-2010, 08:31 PM   #2
MaxAdventure
AMA 198798
MaxAdventure's Avatar
View MaxAdventure's Gallery2
Send a message via Yahoo to MaxAdventure
3kW  1kW  2kW
Friends: (7)
Thanks for the tip. I wouldn't have thought of using the flux to shield against oxidation.
I just picked up one of these for doing battery tabs and large connectors:
http://www.hobbyking.com/hobbyking/s...dProduct=10803
I didn't understand the issues with overheating because of a small tip before, I'm looking forward to trying this out.
There is ALWAYS room for some levity in your brevity!
MaxAdventure is offline
Old 08-12-2010, 12:33 AM   #3
Friends: (16)
I made one of those with some copper bar stock on my lathe some 10 years ago. Works well, and still use it. But, IMHO, that 80 watt Weller soldering iron does work better.
Old 12-15-2010, 03:42 AM   #4
Friends: (16)
http://www.cheapbatterypacks.com/?menu=GF132BCD6B&sid=95995
Old 01-08-2011, 02:11 AM   #5
70sflyer
View 70sflyer's Gallery2
Club: Quiet flyers
Default a123 batterys
Can some one put some light on the A123 battery. is it a step up from the li-po .It it worth it.Do you receive longer flying time with less charge time.
70sflyer is offline
Old 01-08-2011, 03:44 AM   #6
Friends: (16)
Nope, for raw ampere hours to weight ratios, Lipos have it over the A123 cells. But, A123 cells have a very long life, and have zero fire hazard. Some of the Lipos can be fast charged, but this has been true for the A123 cells since they came available.
My three 6S2P A123 packs each have over 200 flights on them, they are three years old, and have the same exact performance as when they were brand new. I'm pulling 50-60 Amperes out of them at full power.
Take a look:
http://www.wattflyer.com/forums/showthread.php?t=47965
A123 2300 mAh soldering bars? e-sailpilot86 Batteries & Chargers 17 07-21-2009 08:20 PM
Do A123 cells need a break in period? constantCrash Batteries & Chargers 3 01-20-2009 11:20 PM
For Sale A123 cells, 2300 size JWilliams Batteries and Chargers Forsale/WTB 11 01-14-2009 05:25 PM
A123 cells and suitable ESCs MK Dave Power Systems 2 06-26-2008 03:37 AM
A123 cells hit the road! dimadee Batteries & Chargers 1 08-24-2007 02:11 AM
Page generated in 0.19603 seconds with 29 queries
