| Seaplanes E-Powered Discuss electric powered seaplanes here |
#1 | ||
I'm wondering because I have built kayaks and it seems a modified hull would be a perfect pontoon. Anyone try this approach? Also wondering about vacuum formed pontoons. I need something for an 8½ oz airplane, |
#2 | ||
Seaplane Nerd
Club: Florida Float Flyers
Use the GWS floats. Generally about $10at your LHS.
If you want to design and make your own, go here: http://www.flyinglindy.homestead.com/skisandfloats.html Kayaks don't have a "step" that lets them break free of the water. Add that and you've got the basic idea. for such a light plane: styrofoam and packing tape will serve well. |
#3 | ||
Friends: (281)
Originally Posted by RWF
Just take some foam and cut out your pontoons for a plane that lite
with some thin Plywood on top for mounting them, Epoxy the wood to the foam.http://www.rcgroups.com/forums/showthread.php?t=147465 http://www.hooked-on-rc-airplanes.co...oat-plane.html http://www.rcgroups.com/forums/showthread.php?t=493281 http://www.seaplanesupply.com/ http://www.hooked-on-rc-airplanes.co...oat-plane.html |
#4 | ||
Friends: (281)
jimsp
Registered User Join Date: Sep 2002 Location: Sayre,PA Posts: 1,542 FLOAT DESIGN Float Pattern The float pattern I use is based on a RCM article written by Chuck Cunningham. You can find a copy of that article here The dimensions are based on the length of the float which is in turn is determined by the length of the model. Generally the floats should be about 75 – 80% of the fuselage length. For the Slow Stick this worked out to be 25” so that’s how long I made my first set of floats. Later I changed it to 24” because it was easier to simply cut out the starting blanks across the 2’ width of the sheets. My pattern for these floats is shown below. For other size planes you can proportionally change the dimensions based on the float length. In any event don’t worry about getting the dimensions exactly right as anything close should work. Float Width For lighter planes Cunningham suggested a 2” width but for the Slow Stick I found a slightly wider width worked better. Perhaps the lighter and slower parkflyer types benefit from a slightly wider and shorter float. With the method I am using you can make wide floats even though you’re starting with foam that is only 1.5” or 2” thick. Float Shape The floats I will be making a have a pentagon shaped cross-section. They have a shallow “V” for the bottom, sloped sides and a flat top. It’s referred to as the Carl Goldberg shape in this article from which I got my inspiration for this design. http://www.rcgroups.com/forums/showt...hreadid=147465 |
#5 | ||
Friends: (281)
#6 | ||
Thanx for the info and the link - very helpful
#8 | ||
Subscribed...
Club: None (yet...)
Friends: (7)
I think this thread could be a sticky with all the good links. Very helpful/informative.
Hanger: GWS Slow Stick; Nutball
#9 | ||
Only two responses amd very helpful, yes... what is a sticky?
#10 | ||
Retired Master Chief USN
Friends: (168)
Hi
Very good info here http://www.stenulson.net/rcflight/waterfly.htm The main site is awesome as well do check it out http://www.stenulson.net/rcflight/rcflight.htm Take care Hank |
#11 | ||
Friends: (168)
Hi
A sticky means that this will stay at the top of the forum so that it is easier to find http://www.wattflyer.com/forums/forumdisplay.php?f=3 See the stickies at the top of the page Hope this explains it And i vote to make this a sticky as well ![]() Take care Hank |
#12 | ||
Friends: (281)
#13 | ||
Excellant link, Ken. Not only how but why. Thank you!
http://www.stenulson.net/rcflight/waterfly.htm |
#14 | ||
You can bury me after I'm done flying
Club: Just Some Friends
Friends: (28)
Thanks for asking that question RWF.
All the above info is very timely as I'm about to convert my old reliable Twin Simple Stick to a float plane. Seems that plane has been a test platform since I first built it about 4 years ago. It's seen many changes and has been a great test plane. I plan on this being it's final test & once I get it tweaked as a float plane it'll stay that way and I'll build another "Test" plane
Blue Skies, Calm Breezes & A Full Hanger
Makes Me A Very Happy Man
| Splashing from Pontoons to Prop | Hal-i-chopter | Seaplanes E-Powered | 19 | 09-30-2007 05:06 PM |
