Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Beginners - Helis
Old 10-13-2010, 02:06 PM   #1
NickMcEnjoy
NickMcEnjoy's Avatar
Default Missing Sticky Thread: Radio setup for Beginners :D
Hello everyone!
I am brand new to helis searching for basic information for helis. I think we need a sticky thread called "Basic Setup for Heli Beginners" or at least something similar to "Radio setup for Helo Beginners"
I spent some times looking around but I could not find one here!
Thanks & regards,
Nick
NickMcEnjoy is offline
Old 10-14-2010, 01:00 AM   #2
UBHSTRY
eltiT resU motsuC
UBHSTRY's Avatar
Send a message via Yahoo to UBHSTRY
Friends: (4)
What radio are you using? What Heli?
UBHSTRY is offline
Old 10-14-2010, 02:43 AM   #3
NickMcEnjoy
Hi!
Thanks for replying.
I have the DX6i and the mSR.
Regards,
Nick
Old 10-14-2010, 02:09 PM   #4
UBHSTRY
eltiT resU motsuC
UBHSTRY's Avatar
Friends: (4)
I dont have an MSR, but I do have the DX6i. Let me look around, ill see if I cant get some settings for you. Do you know how to program your radio if I can get you the settings?
UBHSTRY is offline
Old 10-14-2010, 02:42 PM   #5
NickMcEnjoy
Wonderful!
Yes I know how to change the settings.
I watched these clips:
I will try them soon. But I would like to learn some 101 first so I will know what I'm doing. I also read some parts of the mSR manual. I noticed Erwin (Youtube) did not mention the reverse of the channel 5 as the mSR manual required. Maybe that was something I supposed to know. That's why I need the basic!
I appreciate your help!
Best,
Nick
Old 10-17-2010, 03:51 AM   #6
NickMcEnjoy
I first followed HorizonRC's instruction on binding and trimming the bird. After few packs, I bound the mSR to the DX6i using the heli mode and copied Erwin's setups. I don't know whether I got better, or the Erwin's setting was better, but I could keep the bird in the air for some times now
One typical newbie thing was I kept trimming the Tx did not know that when the battery went low the bird would act differently. Now I know
I put about ten packs on it tonight
If you knew I could barely lift my Axe CP up few inches above the ground last year, you would know how great I feel now
Thanks, Don! For stickying this thread
Happy flying!
Old 10-19-2010, 04:50 AM   #7
NickMcEnjoy
Now I could say that both Erwin's and HorizonRC's settings worked fine. I currently use HorizonRc's settings.
Obviously the bird behaves differently at the beginning and at the end of a flight due to the decrease of the power. Some trimming would fix it.
Adding some power made navigating easier
Old 02-20-2011, 08:05 PM   #8
Davethebluessinger
Child of the 60s
Davethebluessinger's Avatar
View Davethebluessinger's Gallery4
Club: Longdon Flying Club
Friends: (8)
Check out helicopterfun.com for "how to get the best out of your mSR" lots of tips including DX6i
EFlight Pulse XT, Durafly Dynamic S, MS Composit Swift II PZ Ember, Multiplex Fox Conversion, Air Rider Epower, Mini Mach racer, Seagull Pilatus PC9 Roulette
Growing old is inevitable but growing UP is optional!
Davethebluessinger is offline
Old 02-20-2011, 09:31 PM   #9
TylerJCooper
TylerJCooper's Avatar
Club: Attempted to start an Omaha Park Club (Aeronuts)
Friends: (8)
I have a MSR and a DX6i. It is the best to leave it on the plane setting because it is a fixed pitch heli. When you get into 3D you will then switch to the heli setting and start working in programming.
Your gear switch is the high/low setting. Toward you is high setting, away is low setting.
Sir Isaac Newton had an apple, I have a plane.
TylerJCooper is offline
Old 02-20-2011, 11:05 PM   #10
Davethebluessinger
Child of the 60s
Friends: (8)
Setting the mSR up as a heli in the Dx6i allows you to program throttle curves but if you're not worried about that feature then yes Acro mode is fine.
Old 06-28-2011, 09:46 PM   #11
JZSlenker
JZSlenker's Avatar
Send a message via AIM to JZSlenker
Dumb question from a fixed wing pilot considering heli. On my sim, what do I assign the actual control sticks too? I mean what does the left stick control (in each direction) and what does the right stick control?
JZSlenker is offline
Old 12-12-2012, 01:27 AM   #12
tryingtofly
waiting and learning
Default ???????
Left stick,throttle and left turn right turn.Right stick,forward and backwards and left and right cyclic(left bank turn,right bank turn).Still waiting on my mjx f47
tryingtofly is offline
Setup for beginners martin_05 Beginners - Helis 44 07-13-2009 05:35 PM
H9 P-51 Thread Missing Flying 442 Support & Suggestions 21 05-29-2007 02:16 AM
Beginners FAQ? Something to sticky... szewczykm Beginners 2 08-23-2005 04:27 AM
Page generated in 0.89307 seconds with 43 queries
