Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > For Sale & Wanted Forums > Motors and Speed Controllers for sale & WTB
Motors and Speed Controllers for sale & WTB List your brushless or brushed motors and speed controllers for sale in here
Old 11-19-2010, 06:40 PM   #1
terrynshed
Default Aluminum motor mount for Parkzone T28 / Corsair 3530/3536/3542 series motors
This is a custom machined aluminum motor mount for the Parkzone Corsair and T-28. It is designed to adapt a range of 3530, 3536 and 3542 size brushless motors to these Parkzone planes for an excellent upgrade in performance.
One of the key features to this mount is that it utilizes the stock plastic mount as a buffer zone in the event of a crash. The very inexpensive and easily replaceable stock plastic mount should take the impact instead of damaging the planes fuselage. No cowl modifications are necessary for the 3530 and 3536 series of motors, simply bolt on and you are ready to fly.
Three step installation (detailed pictures below):
1. Attach new motor to aluminum mount with the motors supplied screws
2. Attach Parkzone stock plastic mount using the original motor screws
3. Attach entire assembly to the planes fuselage with the original mounting screws
For proper cowl to propeller clearance on the 3530 and 3536 motors that utilize the bolt on propeller shaft you will use the supplied prop spacer plus the flat washer that comes with the new motor as shown in the pictures below. If using a standard motor shaft, or pressing the shaft forward on the motors utilizing a bolt on shaft, a standard collet adapter will work. The stock Corsair / T28 spinner nut will typically work to give you more of a scale look if desired. Please note, with the T-28 if using the bolt on propeller shaft style motor you will need to either press the motor shaft forward and use a standard collet (the stock one works great), or slightly enlarge the cowl opening to use the bolt on propeller shaft.
Compatible Motors (3530 Series):
Turnigy 35-30C 1100KV (and other KV options)
Heads Up RC 3530-11
RC Timer BC3530-14 1100KV
and others in the 3530 series with the 19mm x 25mm bolt pattern
Compatible Motors (3536 series):
Turnigy 35-36C 1100KV (and other KV options)
Heads Up RC 3536-10
Exceed RC Alpha 480 1020KV
RC Timer BC3536-6 1250KV
and others in the 3536 series with the 19mm x 25mm bolt pattern
For those that want an extreme upgrade in performance, choose one of the 3542 series motors . The cowl will need to be modified to accommodate these larger motors by slightly enlarging the front opening. The included propeller spacer may or may not be needed depending on which propeller is chosen. Please note that these 3542 motors may exceed the capability of the planes airframe. Special care should be taken when flying at the extreme speeds these planes will be capable of.
Compatible Motors (3542 series):
Turnigy 35-42C 1100KV (and other KV options)
Heads Up RC 3542-10
Exceed RC Monster Power 10 1100KV
RC Timer BC3542-6 1000KV
and others in the 3542 series with the 19mm x 25mm bolt pattern
Propeller Compatibility:
Stock 2 blade T28 / Corsair 9.5x7.5
Stock 3 blade T28 / Corsair 9x7.5
Stock 2 blade P51 9x6
MAS 10x7x3
There are quite a few other options and will continue updating the list as they are tested
The fit and quality of these mounts are excellent. These are manufactured by smallpartsCNC which I own and operate. To reduce cost, these come in bare aluminum as shown in the photos.
Included: 1 Parkzone Corsair / T-28 Aluminum Motor Mount. with propeller spacer. Weight: 7g (3530) and 5g (3536/42)
Price is $14.00 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
Name:	3536 Mount 1.jpg
Name:	3536 Mount 2.jpg
Name:	3536 Mount 3.jpg
Name:	3536 Mount 4.jpg
Name:	3536 Mount 5.jpg
Name:	3536 Mount 6.jpg
Name:	3536 Mount 7.jpg
Name:	3536 Mount 8.jpg
terrynshed is offline
Old 12-16-2010, 02:27 PM   #2
chinaclipper
Default I am interested.....
Do you accept Paypal?
Hello Terry! I am building a scratch foamie (DHC Beaver) and was wondering if I could make one of these motor mounts work for me.
I was going to mount the motor directly to the plastic mount, then to a plywood firewall. (Absent on this picture, but it is fastened to the foam from with epoxy.
I notice Parkzone has a plastic firewall backer that their motor mount is screwed into.
Ideas?
chinaclipper is offline
Old 12-16-2010, 05:00 PM   #3
terrynshed
Hi chinaclipper,
Model looks very nice. As far as the mount, you could purchase the Corsair / T28 stock plastic mount (sell for around $3.00 everywhere), and bolt the aluminum adapter and new motor onto it.
That whole assembly would then mount right onto your firewall. This may be what you already had in mind. Should be nice and solid on your plywood firewall.
The plastic backer that Parkzone uses is typically part of the fuselage. I don't think you can purchase it separately.
Yes I do accept paypal, I'll send you a PM.
Thanks,
Terry
Tags
corsair mount , corsair turnigy , t28 mount , t28 turnigy
Will Scorpian Motors (4020 series) Fit a RimFire (GP) Mount ? BalsaBob Power Systems 7 11-09-2009 06:11 PM
Parkzone Spitfrire from Parkzone t28 mgb Warbird Electrics 9 10-10-2008 01:12 AM
For Sale Parkzone Corsair Motor, ESC and mount NEW tommytorino Motors and Speed Controllers for sale & WTB 1 09-24-2008 03:23 AM
Parkzone P-51 Motor Mount dabsond ParkFlyers 1 03-13-2006 11:11 PM
Machined Aluminum 36mm Motor Mount (B-50 etc) punkindrublik Motors and Speed Controllers for sale & WTB 0 08-26-2005 08:10 AM
Page generated in 0.70544 seconds with 33 queries
