Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 12-12-2010, 12:15 PM   #1
surfer dude
surfer dude's Avatar
View surfer dude's Gallery17
Club: Tulsa unclub, any open air space above me
Globetrotter Pilot  100mph Speed Demon
Default Addrenaline Rush by Stevens Aeromodel
Any one else flying these? The guys in the Unclub http://www.wattflyer.com/forums/showthread.php?t=45206 have just bought ten of them to pylon race. I just finished mine. 26" WS, AUW 4oz with a 3 cell 500mah lipo, 10amp esc, 5gm servo's, RX less case, Feigo 4100kv motor, and a 3x3 prop. I havn't flown it yet, but Stevens web site says it will hit 65mph with this set up. Other guys will be trying different motors, and batt sizes, so we can see what works best. Here are some pics.
By the way, this is just a $15 kit. There is a very long thread on RCG's, that was very helpful.
ID:	140503 very thin profile, it's gonna disapear.
AMA 729929
ODB3 September 16th & 17th
surfer dude is offline
Old 12-12-2010, 04:56 PM   #2
smokejohnson
smokejohnson's Avatar
View smokejohnson's Gallery22
Club: Independent
Friends: (108)
Looks good Brett. Did you add any dihedral or curve the tips up? Did you seal the balsa with anything?
smokejohnson is offline
Old 12-12-2010, 08:53 PM   #3
surfer dude
No dihedral, and no to the curved tips. I did use two coats of Polycote lightly sanding with 400 grit sandpaper in-between. I shortend all of the wires to the length needed. I saved all of the weight that I could, because I knew that I was going to use the 3cell 500 size pack. Recomended pack size is the 3cell 360, or the 2 cell 480.
AMA 729929
Old 12-13-2010, 05:49 PM   #4
tom1968
Oh, yeah. One of my most-flown planes, and always a kick. You might want to consider more color contrast between top and bottom - you need to be able to tell in a flash which way is up. This plane gets small in a hurry. Good luck with yours.
I meant to do that! Anyway, I can fix it.
tom1968 is offline
Old 12-13-2010, 10:00 PM   #5
surfer dude
Thanks Tom! I Think I will add a few more stripes to the bottom. I like the fact that it's one of your most flown planes. It's nice when you find a plane that's a blast to fly, and cheap!
AMA 729929
Old 12-20-2010, 01:57 AM   #6
Old Tin Man
Old Tin Man's Avatar
I had 2 of these and they are a great little plane. You can build one from scratch in 2 evenings. I lost one to a RX lock up. I am guessing that it was doing 70+ when it hit the pavement. Not much left on that one!
Old Tin Man is offline
Old 12-20-2010, 02:15 AM   #7
smokejohnson
Club: Independent
Friends: (108)
Default Re: Addrenaline Rush by Stevens Aeromodel
What motor was you using TinMan?
Old 12-20-2010, 03:34 AM   #8
Old Tin Man
Hey Johnson,
The one I crashed was using the Emax CF2805 from Hobby King. The other is using a 10 gram outrunner motor from HK also.
I did try a small inrunner but it just got to hot. I think that I may have gotten a bad motor. Any who, the CF2805 made the plane very fast. Not as fast as my hot roded Styker but fast for such a small target.
Old 12-20-2010, 07:03 PM   #9
tom1968
I have a Medusa 12mm inrunner on mine. It's either 4100 or 4300 Kv, can't remember which. That motor is a real screamer - it runs fine with a 3x3 GWS prop and 3s lipo. I had an Electrifly Ammo of the same size and Kv in there and burned it up in one flight. The Medusa just keeps going. Forever I hope - you can't get them any more.
The Medusa does get a bit hot but nowhere near as hot as the Ammo did!
tom1968 is offline
Old 12-21-2010, 10:54 AM   #10
smokejohnson
Club: Independent
Friends: (108)
I'm going to try an outrunner first. I should be able to get mine going this weekend.
Old 12-29-2010, 08:56 PM   #11
surfer dude
Flew the rush. Yep it's fast enough for such a small target. I am pleased with the way it flys. This one will be the hanger for a good long time.
AMA 729929
Old 12-29-2010, 11:34 PM   #12
smokejohnson
Club: Independent
Friends: (108)
That's good to hear Brett. Mine will be ready this weekend. I've been building it and the LiddleRod at the same time so it's taking a little longer than it should.
Old 01-09-2011, 04:16 PM   #13
smokejohnson
Club: Independent
Friends: (108)
Flies great but Scott's is faster. I am going to build another with 6 gr servos and the faster motor. I also like the arrow shaft mount.
AUW 5.2 ounces
AX 1806N 2500kv Brushless Micro Motor (19g)
Hobbyking SS Series 8-10A ESC
SERVO - 9g TP SG90 Sub Micro Servo
GWS 4530 4.5"x3 Prop
GForce 25C 500mAh 3S 11.1V LiPO
Old 01-09-2011, 04:18 PM   #14
smokejohnson
Club: Independent
Friends: (108)
Brett do you have a link to the motor Scott has on his?
Old 01-09-2011, 09:43 PM   #15
franklin_m
franklin_m's Avatar
Club: State College RC Club
I have had one for a couple years now. It's my favorite airplane! I have a feigao 5600kv, a 3x3 prop, but I use 500mah 2S batteries. It's plenty fast on that set up. Motocalc says it would smoke my 6amp speed control if I went to 3S; I like flying it so much I just don't want to mess it up.
Frank
If at first you don't succeed,
...carrier landings are not for you!
"Fly Navy"
franklin_m is offline
Old 01-09-2011, 10:09 PM   #16
surfer dude
http://www.wattflyer.com/forums/show...postcount=3380 Here is a link to the motor and Servo's. Your motor should work as good as Scotts. It's a little lighter, and you have a higher kv. Maybe you need to use a higher pitched prop. I think Scott is using a 5x5.3, or a 5x4.3.
AMA 729929
Old 01-09-2011, 10:21 PM   #17
smokejohnson
Club: Independent
Friends: (108)
Ooops, don't know how I missed that this morning. Thanks
Old 01-10-2011, 12:13 AM   #18
smokejohnson
Club: Independent
Friends: (108)
I was using a 4.5x3, looking on the HK site it looks like guys are running up to a 5x3 on 3S. I will put a 5x3 on it and see how it goes. I know Scott was a lot faster than me.
Old 01-13-2011, 12:16 AM   #19
smokejohnson
Club: Independent
Friends: (108)
Does anyone else want another AR? Kenny is talking about ordering another 6. Along with some other stuff I want we will probably get the free shipping so the cost would be $18.
Old 09-10-2011, 02:21 AM   #20
Court461
E-Starter, Trex450, Yak55
Court461's Avatar
Court461 is offline
Page generated in 1.11638 seconds with 62 queries
