Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Indoor & Micro Electric Planes
Old 12-12-2010, 07:11 PM   #1
BOBWRC
Default Question regarding Spektrum AR6400 micro receiver
How do you assign the function of the rudder servo that is a fixed part of the PC board, to the aileron channel on the transmitter when you intend to use this receiver in a 3 channel airplane without ailerons?
(Using a conventional receiver, where all of the servos just plug in; itís just a matter of plugging the rudder servo into the aileron position on the receiver.)
I suspect that this is a simple task; but this is my first Spektrum transmitter, and Iím not familiar yet with programming it, so Iíd sure appreciate a ďbeginner 101Ē explanation concerning how to do it.
Thanks,
Bob W
BOBWRC is offline
Old 12-12-2010, 07:32 PM   #2
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Go into the mixing section and Mix the Aileron and Rudder 100%
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is offline
Old 12-13-2010, 04:02 AM   #3
BOBWRC
Thanks very much for your reply to my inquiry, and for your input
I did as you suggested, but it took me a while to figure out how eliminate the rudder stick movement from also controlling the rudder. Finally figured out how to set the proportional mix ratio for the rudder stick to zero.
"All's well that ends well" so your input did put me on the right track, and was much appreciated!
Thanks again,
Bob
BOBWRC is offline
Page generated in 0.06232 seconds with 22 queries
