Old 12-15-2010, 02:18 PM   #1
Brown7
Default New to flying, couple of foamie Build Questions
I have been flying foamies for a little while now(month) so i decided to buy the motor/esc/battery etc to build my own. Well Long story short I have built a p38. Before you say, "brown p38s are not for noobs". What i have done is put a pusher prop on it and plan to fly it that way. I know not historically correct, but i only have 1 motor and do not want to over complicate things at this time.
My original plane was a nighthawk i planned to learn on, but after crashing it several times and the V-Tail mixer dying on me i scrapped it.
My p38 isnt really a profile type plane, i actually took the time to form it, so hopefully its not too heavy. if it is i will scrap it and build a profile type.
Now were done with the background, my question is how do i apply the aileron linkages? my original thought was to do it like everything else and have 1 servo moving both sides but the angles are all wrong and they do not move as much as i want. Im either thinking too much into this and not seeing the obvious.
Im using an alpha 250 2200kv brushless outrunner, 2cell, and i think a 25a ESC, but i could be wrong and it might be lower.
Brown7 is offline
Old 12-15-2010, 04:15 PM   #2
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
Little difficult to know what to suggest based on the information you gave. Probably would be helpful to know how big the plane is you are building and how you formed the ailerons, where you are trying to locate the servos etc. Are the servos able to move through the full range or are they binding up only part way through the normal range of movement. Pictures might be helpful.
Good luck with it, sounds like it could be a fun project
dumo01 is offline
Old 12-15-2010, 04:31 PM   #3
Brown7
Duh, sorry
Attached is a crude picture, My concern is where im going to put the aileron Servo or if im going to have to use 2 servos. In the past i have used metal rods in a push/pull setup to move everything, but this is different because its not that easy.
Brown7 is offline
Old 12-15-2010, 06:54 PM   #4
gramps2161
gramps2161's Avatar
View gramps2161's Gallery9
Friends: (18)
Myself I would go with 2 servos for this plane. I am doing up a P-38 and the servos are mounted in the wing, and I am joining the servos with a Y connector.
John
gramps2161 is online now
Old 12-15-2010, 08:20 PM   #5
dumo01
dumo01
dumo01's Avatar
Friends: (7)
I agree with John, two servos. I would mount them so the control horns are in the inner third of each aileron. The method you use to secure the servo to the wing surface will depend on how thick your wing is; you can either cut a pocket into the wing or surface mount using double side tape. The size and torque of the servo will be determined by how big the airplane is and how much it weighs.
dumo01 is offline
Old 12-16-2010, 02:01 PM   #6
Brown7
I thought the 2 servos as well would be the best idea looking at it yesterday. I really want to fly it out this weekend weather permitting so i may get creative and try to make my own harness.
Brown7 is offline
Page generated in 0.24318 seconds with 31 queries
