Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > For Sale & Wanted Forums > Motors and Speed Controllers for sale & WTB
Motors and Speed Controllers for sale & WTB List your brushless or brushed motors and speed controllers for sale in here
Closed Thread
Old 12-21-2010, 01:46 AM   #1
terrynshed
Default Aluminum motor mount for Flyzone Select Scale Super Cub and 450 size motor
This is a custom machined aluminum motor mount for the Flyzone Select Scale Super Cub. It is designed to adapt a 450 size brushless motor to the Flyzone Super Cub for an excellent upgrade in performance. There are no cowl modifcations necessary. This is designed to be a simple bolt on application.
Two step installation (detailed pictures below):
1. Attach new motor to aluminum mount with the motors supplied screws
2. Attach entire assembly to the planes fuselage with new supplied screws
Compatible Motor:
Heads Up RC Power Up 450 Sport
Propeller Compatibility:
GWS EP9050
APC 9 x 4.7
There are quite a few other options based on the type of flying characteristic you are after.
The weight of the Power Up 450, aluminum mount, and propeller collet is 80g. Weight of stock motor and mount is 64g. This extra motor weight will allow you to remove some of the 'dead weight' that was installed onto the super cub which should put the COG right back to stock. Of course the COG should always be checked per the manual after any modifications are done to your plane.
The fit and quality of this mount is excellent. These are manufactured by smallpartsCNC which I own and operate. To reduce cost, these come in bare aluminum as shown in the photos.
Included: 1 Flyzone Super Cub Aluminum Motor Mount and 3 screws. Weight: 3g
Price is $16.00 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions.
Thanks for looking!
Terry
Name:	Flyzone Super Cub Motor Mount 1.jpg
Name:	Flyzone Super Cub Motor Mount 2.jpg
Name:	Flyzone Super Cub Motor Mount 3.jpg
Name:	Flyzone Super Cub Motor Mount 4.jpg
Name:	Flyzone Super Cub Motor Mount 5.jpg
Name:	Flyzone Super Cub Motor Mount 6.jpg
Name:	Flyzone Super Cub Motor Mount 7.jpg
Name:	Flyzone Super Cub Motor Mount 8.jpg
terrynshed is offline
Old 06-20-2011, 05:21 AM   #2
nwillitts
do you have any for sale?
nwillitts is offline
Old 06-20-2011, 05:22 AM   #3
nwillitts
hello?
Old 06-20-2011, 05:38 AM   #4
terrynshed
Hi,
Yes I am currently selling these. I have sent you an e-mail.
Thanks,
Terry
Old 06-20-2011, 06:06 AM   #5
nwillitts
got it and ordered one-thanks terry-you the man.
i have been trying to mount my 450 motor all day and then i found you.
thanks again.
Old 06-20-2011, 05:38 PM   #6
terrynshed
thanks again.
Thank You! You should have a lot of fun with the extra power of the Power Up 450 sport motor. Installation should also be a breeze and get you flying quickly.
A side note that I also mention on my website is that the recommended setup (motor and prop) will draw around 15A max which will work great with the stock ESC.
If you are upgrading to the Power Up 450 'Speed' motor, or using a larger prop than the recommended 9x5 prop you may need to upgrade your ESC.
Thanks again!
Terry
Old 06-20-2011, 05:54 PM   #7
nwillitts
i also have a new 50 amp esc to go with it.
plus a larger prop.
power-it will have it!
Old 06-20-2011, 06:21 PM   #8
terrynshed
That sounds perfect! Have fun with it.
Terry
Old 06-20-2011, 08:15 PM   #9
nwillitts
here is the motor i am using-
http://www.commonsenserc.com/product...oducts_id=2378
this is the ESC i have-
http://www.commonsenserc.com/product...oducts_id=2437
and this prop-
http://masterairscrew.com/9x4gfseriespropeller.aspx
what do ya think?
Old 06-20-2011, 08:36 PM   #10
terrynshed
Hi,
The ESC and Prop should be a good match for that motor. Probably won't draw near the max amps, so that is good, and your ESC is well rated for more current.
As far as the motor, I do not know much about that particular motor and have not test fit it with my mount or on the plane.
Couple things to double check. The aluminum mount I sell is designed to attach to a motor bolt pattern that is 16mm x 19mm meaning two holes will be 16mm across and the other two holes will be 19mm across from each other.
The motor diameter should be 28mm (max diameter of the can), and the overall length of the motor (from bolt holes in the rear to the front of the motor not including the shaft) should be 34mm or less. If your motor happens to be a bit longer, that would be OK, but you may need to enlarge the opening on the front of your cowl. I would say the most important thing is the 16x19mm bolt pattern and the outside diameter of the motor.
If your motor meets these specs, then it should fit nicely. If you have the motor with you and want to take some measurements I can double check for you as well.
Thanks,
Terry
Old 06-20-2011, 09:09 PM   #11
nwillitts
trying to measure motor mounts now-all other specs are in line.
not sure how to convert inches to mm.
gonna order motor you suggested just in case.
thanks for your help.
Old 06-20-2011, 09:17 PM   #12
terrynshed
To convert inches to mm simply take the inches and multiply it by 25.4.
To go from mm to inches, take the mm value and divide it by 25.4.
You're motor should be really close if not a perfect fit. I did see that it is a 28mm diameter on their website. Just not sure what the bolt pattern is.
If you measured in inches from center of hole to center of hole, it should be (16mm) .630" (or just over 5/8") and the longer dimension would be (19mm) .748" (or 3/4"). Your measurement does not need to be exact either.
You will most likely have a 16x16mm, 16x19, or 19x19mm bolt pattern. But most common I have seen on these 450 motors is 16x19mm.
Also, since you have upgraded your ESC as well, you could go with the Power Up 450 Speed which will give you higher KV and more speed.
Hope this helps.
Terry
Old 06-20-2011, 09:22 PM   #13
nwillitts
Sir,you are awesome.
thank you so much.
plenty info you have given me.
i am fairly new at this great hobby as i am sure you can tell.
again,Thank You.
Old 06-20-2011, 10:05 PM   #14
terrynshed
I am happy to help anytime.
Plus, if your Topstar 2815 450 motor fits well, I will add it to my list of options for others to consider. I know there are a lot of motors out their that will work, I just haven't had the opportunity to test fit all of them.
Let me know how it all goes together and if you have any other questions.
Thanks!
Terry
Old 06-20-2011, 10:08 PM   #15
nwillitts
Thanks!
Terry
will do.
Old 06-24-2011, 06:09 AM   #16
nwillitts
ok-got it Thursday-thanks.
two holes fit my motor-the other two are further out.
but two is enough!
thank you very much.
the motor you suggested was out of stock.
but my motor fits fine.
you the man.
Old 06-24-2011, 05:20 PM   #17
terrynshed
Thanks for the update. I'm glad that it is working out for you.
You mention that two of the holes are further out. Are those two further spaced holes on the mount or on the motor?
Just trying to figure out what your motor spacing is. Sounds like it might be a 16mm x 16mm or 19mm x 19mm bolt pattern.
My mount has two holes 16mm apart and two holes 19mm apart. Let me which it lines up with.
Also, how does the motor fit under the cowl, any issues with rubbing in the front or on the sides of the cowl? Did you have to modify anything, or did everything just bolt on nicely.
I may make a small change to the mount and include a 4 slots ranging from 16mm to 19mm. This will allow for 16x16, 16x19, and 19x19mm bolt patterns.
Let me know.
Thanks,
Terry
Old 06-24-2011, 06:48 PM   #18
nwillitts
the two are spaced further out on the mount.
lines up with the 16mm.
motor fits perfectly-only had to widen prop hole on cowl.
Thanks Again!
Old 06-24-2011, 07:11 PM   #19
terrynshed
Thank you for the info.
Terry
Old 06-26-2011, 02:03 AM   #20
nwillitts
OH.MY.GOD!
TALK ABOUT LIMITLESS VERTICALS-I HAS IT!
so much power now.i use less than a quarter stick to fly-less than half for allmost instant take off.
unreal.
next mod?
Thank you for the motor mount!
Old 06-26-2011, 06:58 AM   #21
terrynshed
That's great! Ya, those 450 motors are a pretty big improvement over the stock tiny little motor they stuck on their. Guess they were going for really scale like flying. Slow...
Enjoy!
Terry
Old 07-15-2011, 02:58 AM   #22
nwillitts
ok-got new motor today-an e-Flight park 450-part number EFLM1400 fits on your motor mount PERFECTLY!
Thank You for your support.
Old 07-15-2011, 03:07 AM   #23
terrynshed
That's great!
Quick question. With the E-flite park 450 you have, would you still need to cut the cowl opening at all, or do you think it would have fit perfectly with any modifications. It should fit perfect, but wanted to confirm with you first.
Also, let us know how it flies? I like to hear it has unlimited vertical. People are always asking me about this plane.
Thanks,
Terry
Old 07-15-2011, 03:10 AM   #24
Tbearable
new to electrics. what does 28-35-900kv on electric motor mean
Tbearable is offline
Old 07-15-2011, 03:11 AM   #25
Tbearable
35-48-900kv
Closed Thread
Page generated in 1.37559 seconds with 76 queries
