Old 12-24-2010, 03:55 AM   #1
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
Default Mountain Models Firestorm Build
Under the better late than never thought I would post a few pics of the Firestorm build I am currently doing. I am finished doing the rough build on the airframe and am just getting started doing the sanding etc
The last balsa build I did was a Guillows B17 that I added in on a few times on the build thread that Park started on his B17 last winter. Before that it had been about 15 years since I did a build. I did a foam F22 I bought from Mountain Models, and decided to buy the Firestorm based on my experience with that kit and reputation Mountain Models has for a high quality product.
The difference in the two kits is nothing short of amazing. Granted my B17 kit was about 15-20 years old before I started it, so I expected this would be easier but even so...
The kit arrived in excellent condition, well packaged and complete.
The parts separate from the boards very easily, fit together with very few minor issues, providing excellent alignment, and stay snapped together for easy gluing at the appropriate time. I do not think I used a knife more than a half dozen times through the build so far. The directions provided are clear and easy to follow.
I decided to do a fixed gear rather than doing a retract set up as I fly from a grass field, and have noticed that I not seen any of the other pilots there, many of which are much higher time than myself, using retracts. I suspect they have learned a bit about what holds up well on our field.
I am planning on using a Heads Up RC 3542-10 for power
http://www.headsuprc.com/servlet/the...lectric/Detail
with the 3S battery and most likely a 11 x 5.5 prop, and a 40-50 a ESC
I have used a number of Jeff's set ups and been happy with them so I am inclined to stick with them. The only thing I am hesitating on is that the firewall in the Firestorm seems to be set up for a 3 point rather than the 4 point motor mount I have seen thus far. If the speced Scorpion motor uses a 3 point that is easier to work with, that may be a point in going that direction instead. Will need to do some more work on that point
Still working out the covering scheme. The base color will be bright yellow to make it easy to see, not sure what I will do with the trim yet
ID:	140891   Click image for larger version
ID:	140892   Click image for larger version
ID:	140893   Click image for larger version
ID:	140894   Click image for larger version
ID:	140896   Click image for larger version
dumo01 is offline
Old 12-24-2010, 04:09 AM   #2
Stevephoon
Stevephoon's Avatar
View Stevephoon's Gallery72
Friends: (8)
Thanks for sharing your build! This is a kit I'm interested in as well. I am looking foreward to hearing about taking off and landing on grass. That's what I need to do as well.
I just bought a HeadsUpRc.com 3542-10 motor for a plane I'm planing to build. I've ran it up on a motor test stand I built and it's definitely a strong motor. Biggest I've tried so far.
Looking foreward to your build. Good luck with it!
Growing the fleet!
Stevephoon is offline
Old 12-24-2010, 04:22 AM   #3
buzzltyr
buzzltyr's Avatar
Friends: (4)
I'm about at the same point you are with my Firestorm. I did do the retracts, using the GP.10 retracts. I fly off of grass some of the time, and asphalt some of the time. The retracts are pretty robust, so I think they should hold up OK. I have mine sanded, but haven't started covering yet. I've got some custom graphics that Callie did for me which I'll apply when I'm done with the basic covering. I'm using the Scorpion that MM recommends, and a Thunderbird 56 ESC. I've got a 3S 2200 battery I'll use, if I can get the CG set with it. I always feel that lighter is better.
When I get her done, I'll post up some pics, although it may be awhile before I finish. I'm really slow building and covering these days.....
Mark
buzzltyr is offline
Old 12-24-2010, 02:37 PM   #4
dumo01
dumo01
dumo01's Avatar
Friends: (7)
I have used a couple of Jeffs bigger motors in projects, used a 3548 in a Hyperion SU-31 that I got in a WattFlyer Buying club purchase and a 4248 in a Tower 40 trainer conversion. Both work very well Hope your project goes well. What are you building?
dumo01 is offline
Old 12-24-2010, 03:02 PM   #5
dumo01
dumo01
dumo01's Avatar
Friends: (7)
Mark
Looking forward to see how your comes out. Please feel free to post on the thread. I am thinking about contacting Callie as well as I hear they do very nice work.
Birddog posted some pics of a Firestorm build he did about a year ago with a very nice graphics package.
http://www.wattflyer.com/forums/show...ight=firestorm
I think I am leaning more towards something along the lines of what Brian has posted on the MM website pics of the Firestorm but have not thought that much about it as yet
Do you already have the Scorpion motor? Is it a three point mount to the firewall or is that a figment of my imagination? It may be that the actual motor mount is a four point and you ahve to drill your own holes to fasten the motor into the firewall
Good luck with the build
dumo01 is offline
Old 12-24-2010, 05:33 PM   #6
buzzltyr
buzzltyr's Avatar
Friends: (4)
I believe the Scorp mount has four arms. I think the motor mount box that Brian provides with the kit is designed around the Scorpion he recommends, so I wouldn't think I'd have to do anything but bolt it in place.
I've used Callie extensively on quite a few builds. Her graphics are always outstanding. There is no way I could do what she does with covering. Basically, I'm covering the plane in white Solarfilm. Callie's done up some purple flames outlined in gold for me (my take on the "Firestorm" name).
Mark
buzzltyr is offline
Old 12-25-2010, 02:23 PM   #7
park
Clear !
park's Avatar
Friends: (4)
dumo01,
Looking forward to how it fly's ! I want to build the P-51 next but I must admit when this model came out it got my attention.
AMA 1124147
park is offline
Old 12-31-2010, 09:22 PM   #8
dumo01
dumo01
dumo01's Avatar
Friends: (7)
Mark
Finally getting back to working on this again, and figured out what Brian had in mind. I don't think he specifically mentions building the motor box in the directions and I thought he wanted to mount the motor directly on the plywood piece that bolts to the firewall. When I started looking through the parts I had left and found the pieces marked "MM" i understood what he had in mind. I suspect it will work much better than what i was coming up with.
Anyway time to get back to the sanding
ID:	141195   Click image for larger version
ID:	141196   Click image for larger version
ID:	141197   Click image for larger version
dumo01 is offline
Old 01-26-2011, 01:17 PM   #9
dumo01
dumo01
dumo01's Avatar
Friends: (7)
Default Mixing covering types?
Working on covering the Firestorm, using yellow Solar Film for the most part, was going to do black on the belly and lower 1/3 of the fuse and the leading edges of the wings.
I was going to use a ro0ll of black Ultracote Park Lite I have. Anyone ever have any problems using the UltraCote over the Solar Film? I had thought their temperature ranges were a little different, but looking at the specs I can find they look pretty similar. The yellow Solar will be on overlap the black on the fuse, on the wing I was planning to do the whole wing in yellow and then lay down a 1 inch or so band on top of the wing behind the leading edge, with just enough to cove the leading edge of the bottom of the wing.
dumo01 is offline
Old 01-27-2011, 12:53 AM   #10
CB Flyer
Hey guys,
Could you tell me what servos you will be using for the firestorm?? mine is on the way and was wondering whether there is enough space for a larger servo than they recommend. The total length of the servo is 32mm and has a width of 11mm.
thanks.
CB Flyer is offline
Old 01-27-2011, 01:45 AM   #11
dumo01
dumo01
dumo01's Avatar
Friends: (7)
CB
Glad you asked that question, it made me go back and look again at what I was planning
I actually have not ordered them yet but was going use these for all:
http://www.headsuprc.com/servlet/the...2g-EMAX/Detail
When I was measuring to answer your question I realized the servo slots are different sizes, the fuse slots for the rudder and elevator are 24x11, the wing slots for the ailerons are 29x 11. I do not recall the directions saying specifically,b ut it might suggest using a bigger servo for the ailerons. The recommended servos on the website are the HiTec HS 65 and 82. I took that to mean either would work well, but my thought now is that the ailerons need the bigger omph the 82 would provide and lo and behold, the dimensions of each will fit the slots as built.
So to make a long story short I will most likely use:
for the rudder and elevator and
http://www.headsuprc.com/servlet/the...g-Hitec/Detail
for the ailerons.
The servo boxes on the wing should not be too tough to modify to fit the 33 mm servo and the forward box on the fuse should be OK as well. The rear fuse servo box might be more difficult as there is a bulkhead right in front of the box. To make the box bigger toward the tail may have issues with the servo depth fitting in the tail as the tail widths is decreasing there. My best guess is you will not be able to get any deeper servo than about 21mm unless you add spacers above the level of the fuse
Good luck with the plane, it has been a fun kit to build so far. Will get some more pics up in a few days. Has been kind of slow going, I seldom seem to get more than about an hour to work on it on any given night.
Please use the thread to put up some pics of your build, always good to see what ideas others have.
dumo01 is offline
Old 01-27-2011, 06:57 AM   #12
View CHELLIE's Gallery13
Friends: (326)
Your plane is looking great, Subscribed the 3542-10 and the servos you linked to will do a wonderful job for you, Nice and strong Take care and Have fun, Chellie
Old 01-29-2011, 11:50 AM   #13
CB Flyer
thanks for that great info. I'm looking forward to seeing some more pics. The Firestorm will be my first balsa build ever so i may take it slow
CB Flyer is offline
Old 01-30-2011, 10:46 AM   #14
Eberwein
Mountain Models
Hey guys,
You do use HS-82 type servos for ailerons and HS-65's on the tails.
Sorry if I didn't put that in the instructions. I'll get that added, along with the motor mount build pictures, in the next batch.
Brian
Eberwein is offline
Old 01-30-2011, 10:41 PM   #15
dumo01
dumo01
dumo01's Avatar
Friends: (7)
Originally Posted by Eberwein View Post
Hey guys,
Brian
Brian
It really is a nice kit and a fun build when I have time to work on it, Glad you are able to catch up on it via the thread.
One question I had:
On the full scale plans it looks like the hinges for the ailerons are spaced in between the ribs. My inclination would have been to anchor the hinges into the ribs so there was more wood for the glue to adhere to. In talking to one of the more experienced builders in my club, he said that the reason you show it off the ribs was to avoid issues trying to cut the hinge slot into the hardened CA adhesive. Is that your intent in the design? I guess with the number of hinges you have per side, there should be no issues keeping the aileron with the wing. I have not covered the wing yet so I could add some wood at the hinge spots to build them up, but if it does not need it why add the weight so....
dumo01 is offline
Old 01-31-2011, 10:51 AM   #16
Eberwein
Mountain Models
Your friend is correct about the location of the hinges. I've had mine at 70 MPH with no issues on the aileron hinges, and a friend has had his up to 89 MPH, so no worries there.
Brian
Eberwein is offline
Old 02-10-2011, 09:46 AM   #17
CB Flyer
Hey dumo01,
i received the kit only 2 days ago and since i've had 2 days off, i've nearly finished all of the building. I just couldn't stop working on it. I was wondering if you could post some pics of the hinges (How you attached the ailerons to the Main wing, and how you attached the rudder and elevator to the stabalisers) if it's not too much trouble. This is my first ever kit build and i'm just a bit confused even after reading the instructions.
thanks. Also, i'll post some pictures of mine soon
CB Flyer is offline
Old 02-10-2011, 10:33 AM   #18
Friends: (326)
Originally Posted by CB Flyer View Post
Hey dumo01,
Hi CB Flyer most people use CA Hinges on Balsa. hope that helps, Chellie
http://www.rcuniverse.com/magazine/a...?article_id=55
http://www.rcuniverse.com/magazine/a...rticle_id=1180
Old 02-10-2011, 10:34 AM   #19
Friends: (326)
Old 02-10-2011, 10:36 AM   #20
Friends: (326)
and here is how you make Tape hinges for Foam Planes.
Old 02-10-2011, 10:39 AM   #21
Friends: (326)
CA Hinges & use thin CA Glue
http://www.hobbypeople.net/index.php...4-3-4-x-1.html
Old 02-10-2011, 01:26 PM   #22
CB Flyer
thanks so much for those links chellie. Much appreciated.
CB Flyer is offline
Old 02-10-2011, 02:03 PM   #23
dumo01
dumo01
dumo01's Avatar
Friends: (7)
Hey dumo01,
CB
Sounds like yours is going well. Looking forward to the pics.
Would be happy to post pics of the aileron attached to the wings... as soon as I do that. Looks like Chellie put up a number of links on hinging which will probably hit what you are looking for, I am not planning anything unusual, CA hinges for all surfaces. The only thing I did a little different which may or may not turn out to be useful was to cut the hinge slots for the elevator and rudder before I sanded and covered the tail surfaces. I was hoping that having the square edge on the wood might help to get the hinge slot square and centered which I problems with on my last build. I also used the Dubro hinge slotting kit:
http://www3.towerhobbies.com/cgi-bin...?&I=LXE230&P=0
a knife works, but for me at least I thought I got a better result with this tool set. I think it is better, I guess time will tell.
I have had a number of other things going on and have not had the time to sit down and make a lot of progress on the plane. Just finished with the covering and that took me about two weeks to get the time in to do that.
Bright yellow with black trim, I have a black spinner I am going to use and am trying to decide if I want the cowl yellow or black, leaning toward the black but not sure.
I think getting the control surfaces hinged will be the next step, but I may do some of the trim things I have in mind next , some of those might be easier to do while the stabs are not fastened on the fuse.
My goal is to have the plane done for our club show March 19 which I think will be very doable. I will be taking a weeks vacation the last week in Feb and the wife will be out of town so with just me and the dogs I should be able to get a lot done on the plane.
Will try to post a couple pics this evening when I get home
dumo01 is offline
Old 02-10-2011, 11:24 PM   #24
CB Flyer
Thanks so much for that. I might just use an x-acto knife and do a few tests on a few bits of scrap. So for those ca hinges, all you have to do is peel off the little covering right? then slot them in to place like in that video above and use a few drops of 5 minute epoxy?
I can't wait to see how your covering looks. I haven't chosen what design i'll use for the firestorm but if i can't think of anything good, i may go with the design that mountain models has on their firestorm page which looks pretty awesome.
Sorry, i have one more question. When you build the two elevators, there is an elevator joiner which is made out of basswood. There seems to be two slots on either side of the basswood joiner which lines up with two other slots on the elevators. I was just wondering what those two slots are for???
I'll get some pics up tonight (I live in Australia)
Name:	DSC_0285.jpg jjbjb.jpg
CB Flyer is offline
Old 02-11-2011, 12:23 AM   #25
Friends: (326)
You Want to use Thin CA or Thin Super Glue, not epoxy, epoxy wont wick into the wood, use 3 to 4 drops or more if needed,
New to flying, couple of foamie Build Questions Brown7 Beginners 5 12-16-2010 02:01 PM
rcsuperhero build photos and a vid rcsuperhero Foamies 0 12-13-2010 06:18 PM
Page generated in 1.53889 seconds with 84 queries
