Old 12-25-2010, 11:54 PM   #1
FlyingBrick50
FlyingBrick50
FlyingBrick50's Avatar
Club: Gooney Birds Flo, SC
Friends: (13)
Default Wheel Pants
Anyone out there building their own wheel pants? I have a Fairchild F22 that needs a set!
FlyingBrick50 is offline
Old 12-26-2010, 12:48 AM   #2
tampaflyer
to the skies of tampa
tampaflyer's Avatar
View tampaflyer's Gallery7
Club: trac
Friends: (7)
light ply base.. then build up with foam. sand to shape.. cover or glass
tampaflyer is offline
Old 12-26-2010, 01:50 AM   #3
FlyingBrick50
FlyingBrick50
Friends: (13)
Do you have any pictures and what kind of foam are you using ?
Old 12-26-2010, 03:10 AM   #4
tampaflyer
tampaflyer's Avatar
Club: trac
Friends: (7)
its like an oreo, lite ply on the outside any foam(white, blue) in the middle.
the foam will sand easily to give you a complex shape easily.
Old 12-26-2010, 01:24 PM   #5
FlyingBrick50
FlyingBrick50
Friends: (13)
Exclamation Wheel Pants
Sure would love more information, I know it's out there somewhere,....
See You Up There
Old 12-26-2010, 02:06 PM   #6
FlyingBrick50
FlyingBrick50
Friends: (13)
Default Ms. Millie needs pants
Here's a picture of her.
Old 12-27-2010, 05:50 AM   #7
Thayer
WAA-08 Pilot
I make pants for my electric models out of balsa stacks, sand to shape and cover with film for a perfect color match.
Thayer
Thayer is offline
Old 12-29-2010, 09:39 PM   #8
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery88
Club: rcg staff
Friends: (17)
For simple parts, you can easily make a balsa mold, and hand pull sheet plastic over the mold to make half-parts, using a heat gun. Join them at the center after trimming. If you join them with a perfect butt seam, you can add CA or epoxy to the inside of seam, to give you some sanding latitude. I've done this for numerous molded parts.
It the edge of the pants can have a bit of thickness, I would sculpt them from balsa. You can coat them with a layer of CA or epoxy afterward, to add a bit of toughness.
ID:	141095   Click image for larger version
ID:	141096   Click image for larger version
Bill G is offline
Old 12-30-2010, 12:14 AM   #9
FlyingBrick50
FlyingBrick50
Friends: (13)
Smile
Thanks Bill G really am glad you put some pics on here helps alot,....'Thanks again
See You Up There
Page generated in 0.24086 seconds with 39 queries
