Old 01-20-2011, 10:38 PM   #1
KenSue
Default HELP, Turnigy Plush 40 amp ESC
I have reecntly received my Turnigy Plush 40 amp ESC. I have a Spektrom DX6I bound to a Spektrum AR6200 receiver. plugged in the Turnigy Plush 40 amp esc, a 1000 Kv Turingy 35-42C Aerodrive motor and 02 HXT900 servos.
The esc does it's usual start up tone, then just beeps once every 02 seconds. The manual for the esc says this is "possibly" an abnormal throttle signal. But nothing works, not even the servos and I don't have a spare esc to check it against.
Has anyone had this kind of problem, or one similar, that might have some advice for someone who has never done this before?
KenSue is offline
Old 01-20-2011, 11:06 PM   #2
weathervane
Needs more LED's
weathervane's Avatar
View weathervane's Gallery14
Club: Wright Flyers
Globetrotter Pilot  1kW
Friends: (12)
You might need to bump the throttle after the first start up tone. Mine do the same thing. If it does not get a signal it goes into some kind of fault mode.
Good luck, Andrew
1 mile of road will take you a mile,
1 mile of runway will take you any where.
Wrightflyers, club treasurer
http://www.wrightflyers.org/
weathervane is offline
Old 01-20-2011, 11:09 PM   #3
View CHELLIE's Gallery13
Friends: (327)
your Throttle on your Radio Might be Reversed, also make sure that the Throttle trim is set to 0 or all the way down, and the throttle stick is all the way down, check your radio for any abnormal programed throttle settings, Hope that helps, Chellie
PS, Also, you might need to reset the ESC throttle end points
Club: Arizona WingNutz
Friends: (20)
Ken,
Here's the basics for setting your throttle end points in an ESC:
1 - Turn radio on and move throttle to "full".
2 - Plug in your battery to the ESC.
3 - Your ESC should emit a series of beeps. You should initially hear two long beeps, followed by two short beeps. After the two short beeps move the throttle to fully closed (don't mess with the throttle trim at all, leave it at the center position).
Your ESC should then be set to your transmitters throttle end points.
Pat Gagnon
Owner -
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Turnigy Motor SK 3548 / ESC help foamjetpilot Power Systems 11 01-25-2011 03:58 AM
HobbyKing Swarm: Turnigy Plush 60A ESC radialarm Basement Bargains 4 01-16-2011 07:48 PM
Question regarding HobbyKing & Turnigy (1 cell, 3 Amp) ESCs BOBWRC Indoor & Micro Electric Planes 3 01-07-2011 12:39 AM
Turnigy 80A ESC Help Bluefronted Power Systems 3 12-15-2010 07:55 PM
Page generated in 0.06793 seconds with 23 queries
