| RC Radios, Transmitters, Receivers, Servos, gyros Discussion all about rc radios, transmitters, receivers, servos, etc. |
#1 | ||
One of the two servos bounces and jitters, especially under small control inputs. (It does better at full extension.) I futzed around with it for a while but got nowhere. So I replaced the servo with another 9g servo. Same problem. I switched the wires for left and right servos. Same problem. I made sure it was clearing the foam around the arm. Same problem. I decided it must be the Rx. Replaced the Rx. Same problem. The control rod goes thru a small tube on its way to the elevon, which seemed to be slightly off to one side, so I cut it loose to allow the control rod to just hang free. Same problem. Seemed to be twisting a bit in its slot, so I went ahead and glued it in place. Same problem. What. The. Heck? |
#2 | ||
Friends: (281)
What Transmitter, receiver are you using, Sounds like a RFI problem on 72MHz to me with a Cheapy Receiver. anyway, Put the receiver as far towards the rear of the plane as possible, away from the ESC, ubec, battery and servo wires, that should help, make sure the antenna wire is away from any servo wiring, things start to get cramped in a wing, and a cheapy receiver May not be able to filter all the RFI out.
#3 | ||
Chellie,
Interesting thoughts. I am using my trusty DX6i, and a HK OrangeRx. The second OrangeRx came from my GWS Bipe where, while it has not been flight tested, it didn't exhibit any weird servo chattering behavior. I just tried it now, with the Rx pulled as far away from everything as possible. I walked into the other room, 20 feet away, and could still hear it chattering. If it's an Rx problem, when I swapped the AIL / ELE plugs, shouldn't that have transferred it to the other servo? If I touch the servo at all, it starts bouncing around and chattering. The other servo doesn't display this behavior. But, if it's a servo problem, shouldn't it have disappeared when I swapped out the servo? I'm confuzzled. |
#4 | ||
Friends: (281)
interesting Problem, do you have the servo on a y connector, the y connector could be bad, or there could be a loose connection on the servo plug or at the receiver, I dont know how good those orange receivers are, do you have a spektrum reveiver that you can plug in, I have heard that 1 out of 3 of those orange receivers are bad.I know i would not trust them
get a spektrum receiver to be on the safe side, I dont think you save any money buying knock off cheapy clone receivers.
#5 | ||
Friends: (281)
this is what i read about the orange receivers from racer paul.
08:17 AM #15 RacerPaul No doors or fenders! Join Date: Aug 2005 Location: Bellport, NY Posts: 662 Thanked 20 Times in 19 Posts iTrader: (5) Friends: (22) Originally Posted by Larry3215 ![]() I followed the links but I dont see anywhere where you say if these are clones or not. Just that you test them.I think this answers that question.... "There is a lot of discussion on here about whether these are clones, knockoffs or overstock from the factory. " I encourage everyone to read all they can on my threads and others regarding these products. As is stated in my other threads... the AR6100 receivers are as sold by oomodels and others and the Orange receivers are made by Hobby King. One of the reasons I offer these is the high rate of unusable receivers experienced by purchasers from Hong Kong. Of my last shipment of Orange receivers, one third of them failed my testing. |
#6 | ||
Crash Specialist
Club: AzWingNutz
Could be one of the other servos is bad also causing the other servo to chatter. Try unplugging all the other servos and see if it still chatters.
What servos? Mike |
#7 | ||
I appreciate the input from everyone.
I've determined that my replacement servo - a TowerPro SG90 9g from HeadsUp - is bad. I got 4 of these from HeadsUp for my TigerMoth 400 build and only used 3 at random. This one's been in its bag for months. I should have suspected the brand new servo! ![]() However, I *think* I've resolved the problem, as the original servo - a T Pro SG90 9g from HobbyKing - now seems to be working. My tentative diagnosis is this: Something was binding, causing the first servo to struggle. The second servo was bad, so continued to struggle even after I'd cleared up whichever problem was causing the issue in the first place. So I thought I hadn't solved the original problem when I had. I hope. There are several morals in here, I'm sure. ![]() As to the OrangeRx issues, I have mixed feelings for sure, which is one of the reasons it's going on a foamboard wing rather than my F-27C.
#8 | ||
Friends: (281)
glad you found the problem
Take care and have fun, Chellie
#9 | ||
That problem is quite often caused by a poor connection. Often just unplugging and replugging in a connector will cure the problem as the action improves the connection by abrading any corrosion on the connectors.
#10 | ||
Originally Posted by mclarkson
Another possibility: Some individual servos require some "burn in". If you have a "servo cycler" device, running the servo back-and-forth, from end-to-end for 5-10 minutes can help "seat" the pot-wiper to the surface of the carbon potentiometer in the servo, and may smooth out the servo operation.
#11 | ||
Hmmm... I may give it a try, if I haven't already chucked it. Thanks.
#12 | ||
Friends: (16)
Even if it starts working OK, being erratic is never a good sign. Would not use it in any critical surface, might be OK as a rudder servo. As for me, I'd sent it to the round filing cabinet located on the floor.
#13 | ||
Every time I throw something away, I regret it in a week or two.
#14 | ||
I have TP SG90's supplied with my 450 .... and one thing I noted with them ...
If a gear strips just a tooth or 2 - it appears to be ok - but when surface connected it jitters, jumps, stalls ... becomes a dog in fact. I bought a set of replacement gears and found that the main output shaft diam has been changed ! I do not buy SG90's now .... the Mystery and other 9grs are cheaper and better !! But the MG90's are in a different league altogether ! |
| servo setup for elevons, flying wing | lakeside1000 | Delta & Flying Wings | 9 | 12-29-2011 04:49 PM |
| Sold WBC #9 9gr. Servo Deal SOLD/CLOSED | Nitro Blast | Radio Equipment For Sale & WTB | 46 | 02-08-2011 11:20 PM |
| SR Collective Pitch Problem | nam6869usmc | Micro Sized Electric Helicopters | 2 | 12-27-2010 02:44 PM |
| I have elevator servo fluctuations. Any ideas? | Catalina | Foamies | 4 | 12-11-2010 01:06 AM |
| For Sale Aluminum Servo Mounts for 5g and 9g Servos | terrynshed | Radio Equipment For Sale & WTB | 0 | 11-19-2010 07:48 PM |
