Old 01-24-2011, 04:19 AM   #1
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
Cool Just downloaded MotoCalc!
Haven't had time to really dig into it, other than a quick perusal, but DAY-YAM! From what I did see it looks like a really nice program! Easy to use, just follow the step by step "questionnaire" and it gives you your data!
OK, I got my "drone licence"...
When does the season start and what Ammo can I use?
FlyWheel is offline
Old 01-24-2011, 04:21 AM   #2
That it is. Parts I like are the motor efficiency, rate of climb, propeller pitch air velocity, flight time, and power input.
As others have noted, some of the very cheap (China) motors are not very accurate on their specified KV ratings, and so on.
I've found that this program is within about 5% or so, when using my various Hacker A class outrunner motors.
Old 01-24-2011, 05:32 AM   #3
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Motocalc is a great tool but I agree - the data out is only as good as the data in.
Ive found that it works pretty well with name brand motors as far as predicting how a system will perform.
If your using cheep Hobby City stuff, then forget it. The listed specs are most often made up and have no basis in reality.
If you have some decent testing gear, you can come up with your own - accurate - kV, Rm, Io values for the motor your using and it works great.
I think I need a signature.
Larry
Larry3215 is offline
Old 01-24-2011, 03:13 PM   #4
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Yep it's a great program, but like Larry and Kyle have said, use it as a basis only.
Actual measurements will tell you the truth, M/C is educated guessing, and sometimes there are some bugs in it.
If something doesn't look kosher to you on a set up, try using a different motor mfg. with a similar motor to see if it changes anything. There are a couple of motors that for what ever bug a boo, will go off the wall when playing with set ups.
Found one the other day, where just jumping the cell count one cell had the system go from 45 amp draw to 146 amps!!!!!!!
But like I said all in all it's a fun system to play with.
Glacier Girl is offline
Old 01-24-2011, 04:38 PM   #5
Rockin Robbins
Rockin Robbins's Avatar
Friends: (8)
Whar be the link?
Rockin Robbins is online now
Old 01-25-2011, 06:31 PM   #6
Glacier Girl
Kamikaze Ace
1kW
REALLY? LOL!
www.motocalc.com
Old 01-25-2011, 07:16 PM   #7
FlyWheel
FlyWheel's Avatar
Yeah, that's what I do to if someone posts about a product and doesn't leave a link I will just type the name of the manufacturer, all lower case andnospaces then stick a .com on the end. And 90% of the time it works!
The other 10% Google gets.
FlyWheel is offline
Old 01-25-2011, 07:30 PM   #8
Rockin Robbins
Friends: (8)
Well I asked for it with my Captain Obvious graphic!
Thanx for posting the link!
Page generated in 0.13025 seconds with 32 queries
