Old 01-29-2011, 11:47 PM   #1
FlyingBrick50
FlyingBrick50
FlyingBrick50's Avatar
Club: Gooney Birds Flo, SC
Friends: (13)
Question rx power
Here a question I hope someone can help me with?
I have a JR SportRS6500 reciever which comes with a 4.8volt 1100 mah batt for power.
The question is this, I would like to run the rx with the flight batt already on board and not the 4.8 volt one. The problem comes in when I hook up the speed control wires (+, -, Signal) to the throttle plug on the rx nothing happens because the rx does not have power to it. Switching the wires coming from the esc to the batt plug on the rx all servos work great no motor! Can I make a jumper from spare servo wires to power the tx while still sending a signal to the esc for the motor
FlyingBrick50 is offline
Old 01-29-2011, 11:53 PM   #2
philipa_240sx
View philipa_240sx's Gallery83
It would be helpful if you can post some information about which brand and model of ESC you are using. Reason: some ESC models do not have a BEC (battery eliminator circuit) to power the radio.
There are many ways to power the RX. Once we know what you have, it will be much easier to suggest a solution.
philipa_240sx is offline
Old 01-30-2011, 12:33 AM   #3
FlyingBrick50
FlyingBrick50
Friends: (13)
Exclamation
The bec is built in
Old 01-30-2011, 12:42 AM   #4
FlyingBrick50
FlyingBrick50
Friends: (13)
Default bec
The esc is a 60 amp e-max w/3amp bec
The rx is powered by the esc on the same plug as the throttle on the old rx, with the new rx it has throttle and a power plug?
Old 01-30-2011, 01:08 AM   #5
Shrikered
Send a message via AIM to Shrikered Send a message via Skype™ to Shrikered
So your RX has separate power buses for the servos and the RX itself. Unusual - does the RX manual explain why? Does it caution against connecting them? If not, should be fine to connect both to the BEC.
Be careful, though, about RX current and voltage requirements. A "3 Amp BEC" may not have enough current to drive all servos at full load without voltage drop. Voltage drop ==> RX will reboot. Test the RX at full load on the servos. The new Hitec Aurora 9 and other telemetry radios are more prone to this because they contain transmitters with high load. Fortunately my T-28 floats great.
Shrikered is offline
Old 01-30-2011, 01:27 AM   #6
FlyingBrick50
FlyingBrick50
Friends: (13)
let me try again, hmmmm the old rx was powered by the esc and the throttle/power plug were on the same plug that pluged into the rx, the new rx has only one power plug in(servos work great), and the throttle is just another plug going out back to the esc. I need to power the batt plug on the rx and still have throttle?
ohh and no manual,.....will cutting the red wire coming from the esc to the throttle splicing it into the power plug and powering the rx that way (ground wire as well)?
as long as theres power to the rx all the throttle plug would need to do was send a signal,.......................
Old 01-30-2011, 02:23 AM   #7
As others have indicated, you've got to be careful when using the built in BEC (Battery Elimination Circuit) on a standard ESC (Electronic Speed Control). Problem is, most of these ESC's use a standard linear voltage regulator for providing the 5 volts DC for the receiver. These linear regulator work by dropping the voltage from your motor battery to the 5 volts for the receiver, they can get hot doing this. If they get to hot, they are designed to shut off the 5 volts DC, protecting the 5 volt regulator, and crashing your plane.
Oh, and by the way, when you get to your model, the regulator has cooled off, and is now working again.
Another option is to consider a uBEC (Switching power supply BEC), that will connect directly to the INPUT of your ESC, and its output connects directly to the battery input of your receiver. Castle Creations makes them, Common Sense makes them, I've used both for three years in kilowatt sized models with zero problems. These uBEC's run about $20-25 or so.
And, another, nother option is the Castle Creations ICE ESC's. The CC and a few others use a switching power supply in their BEC, so overheating is not a problem.
Switching power supplies are nothing new. The computer you are using to look at this thread likely has several of them. And those cell phone chargers have them, printers have them, they are used all over the place.
Old 01-30-2011, 03:17 AM   #8
FlyingBrick50
FlyingBrick50
Friends: (13)
Default ubec
the built in bec handles the servo load fine (2 standard, 2 micro)
I just don't want to feed power into the rx from the esc throttle/power plug as is the case with the old rx(no response @ all), if the new rx is powered by its own battery plug from the built in bec connection then all that is needed is to send the speed control a control signal for motor control simply taking the power off the esc power/throttle plug and plugging it into the new rx power plug
Old 01-30-2011, 04:07 AM   #9
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
View HeliScRapYard's Gallery3
Send a message via AIM to HeliScRapYard
hey, is this the one i sent with the radio or a different rx?
Need More Glue!!!
HeliScRapYard is offline
Old 01-30-2011, 04:25 AM   #10
FlyingBrick50
FlyingBrick50
Friends: (13)
the one you sent
Old 01-30-2011, 04:37 AM   #11
HeliScRapYard
Foam Junkie
Hmmmm, I've flown that one on electrics just as you are trying to do. the 4.8v pack is more for gas planes than an electric plane. although it could be used as well. did you plug the esc and the 4.8v pack in at the same time? if so i think that could damage your bec. so i've heard.
Need More Glue!!!
Old 01-30-2011, 04:38 AM   #12
HeliScRapYard
Foam Junkie
on my planes the power worked fine going in through the throttle port.
Need More Glue!!!
Old 01-30-2011, 04:41 AM   #13
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Boy I can't even find a listing for a JR 6500 rx on JR's site.
If this is like most JR and Spektrum rx's, they all have a separate battery socket on the rx. It's only used to plug in an rx pack or in the Spektrum units to use the bind plug.
Plugging in your esc lead to the throttle socket will feed all the sockets on the rx, if you have a working bec on the esc.
If you have to plug the esc lead into the battery socket to power up the rx it sounds more like you have a bad rx throttle socket.
Or you had the esc lead plugged in backwards.
Glacier Girl is offline
Old 01-30-2011, 05:01 AM   #14
HeliScRapYard
Foam Junkie
it is a JR rs600 like this one.
Need More Glue!!!
Old 01-30-2011, 06:01 AM   #15
View CHELLIE's Gallery13
Friends: (327)
Maybe I can be of some help here, If its a 72MHz radio, Dont use the 72 MHz JR Receiver with E Power, Most JR Receivers will Glitch Like Crazy with E Power, they work Fine with Nitro, but the RFI from e Power upsets JR Receivers Big Time, Do Yourself a Big Big Favor, and get a 7 Channel Castle Creation Berg Receiver, its almost like having a 2.4 radio as the Berg receiver will lock onto your transmitter, and you will have a solid radio Link, and only use a Berg Crystal too, Berg Receivers are the best of the best for 72 MHz, its cheap insurance, hope that helps, Take care, Chellie
PS. I lost 2 planes Due to Using 2 different JR Receivers with E Power, Dont do it IMHO, I learned that the Hard Way.
http://www.amazon.com/dp/B000NC6N1U/...SIN=B000NC6N1U
http://www.castlecreations.com/suppo...user_guide.pdf
Transmitter Signal Recognition (TSR) process:
The receiver "learns" the characteristics and specific signal signatures of your transmitter when you power it up. After that, the receiver will only listen to your transmitter*.
Note: If a similar transmitter on the same channel is powered up and is CLOSERto your receiver than your own transmitter, loss of signal/fail safe may be experienced.
True Digital Signal Processing (TDSP):
TDSP is a proprietary process developed by Peter Berg. In addition to highly advanced triple-tuned RF filtering hardware, Castle Creations’ Berg receivers use a microprocessor and sophisticated software algorithms to filter the incoming signal. The system decides which signals are valid and which are not. Most standard FM receivers simply pass on the invalid signals to the servos as a "glitch".
TDSP receiver technology essentially eliminates glitches and provides a new level of confidence that you will
only get with Berg by Castle Creations.
Old 01-30-2011, 07:02 AM   #16
The center pins and bottom pins of all receiver servo connections are usually all common. So, any receiver "servo" pin connection can also be used as a battery plug. The third pin is the servo signal wire. Since the battery plugs do not use the third wire, plugging in a battery into the servo plug has no effect on the receiver's third wire. (Unless you plug in the battery backwards, that is.)
This can quickly be verified on your specific receiver by running a quick continuity check with one of those inexpensive digital multimeters. All the "Black" pins should be common, all the "Red" pins should be common.
If you're not familiar on how to use those handy multimeters, take a look:
Digital Multimeters, How to use them
http://www.wattflyer.com/forums/showthread.php?t=52821
Old 01-30-2011, 11:04 AM   #17
slipstick
So lets try again.
Your RS600 SHOULD be powered normally if you plug the wire from the ESC into the throttle socket. If it doesn't work like that then there's something wrong with the receiver...it's bad, broken, not working right.
Given that fact, any messing about you do with odd wires could do absolutely anything, possibly something really unpleasant.
slipstick is offline
Old 01-30-2011, 12:22 PM   #18
FlyingBrick50
FlyingBrick50
Friends: (13)
Originally Posted by slipstick View Post
So lets try again.
The rx comes with a batt for the battery power to the rx and has its own plug in on the rx and plugs for 6 channels well!
I think chellie has gone down this road before and I'm think I'm going to change the rx to a corona rx 4 ch I already have in stock!!!???
Old 01-30-2011, 12:41 PM   #19
Friends: (327)
With That receiver, use a UBEC plugged into the Battery port, remove the Red battery wire from the ESC to Receiver, use a pin to remove the wire out of the plug, so you dont have to cut it, and it can be reused later on, you may be able to make a jumper/y connection and use your esc/bec, you will just need the pos and neg to feed at the battery port, you will need to get the center signal wire to the throttle, and maybe a ground wire, but thats a lot of hassel, WHY do that, use a UBEC, remove the red wire on the ESC/BEC plug and your done, check the JR Receiver very close for glitching, and good luck to you, Did i mention that i dont Like JR Receivers for E Power I think the reason that receiver comes with its own battery, is to try to eliminate glitching by not allowing a BEC to power the Receiver, because the voltage from a bec is somewhat Dirty with RFI, and the voltage comeing from a Battery is Clean with no RFI, I think your going to Have glitching problems using a BEC or even a UBEC with a JR receiver IMHO, If you do, Get a BERG Receiver,Take care and Have fun, Chellie
Old 01-30-2011, 08:13 PM   #20
FlyingBrick50
FlyingBrick50
Friends: (13)
Default rx power
Well I'm back to square one got my original setups back working as they were prior to the changes, cannot seem to get anything working as it should with the new equipment, ,,,,,,,,,,,
man this is depressing
Going fishing!!!!!!!!!
Old 01-30-2011, 10:07 PM   #21
FlyingBrick50
FlyingBrick50
Friends: (13)
Talking OK OK OK Biting the bullet
Well UBEC looks like the way to go, should solve the issue at least on the Fairchild F22 (Ms.Millie) and thanks to Chellie I got the answer I was looking for in regards to the wiring, it can be done just not the best.....why fight it breakdown and send the money! HK has them real cheap just don't want to wait up to 45 days for it!
Thanks everyone Happy Trails
PS: caught half a dozen or so pretty redbreast (fish) LTR
Old 01-30-2011, 10:57 PM   #22
HeliScRapYard
Foam Junkie
i use the ones from RCTimer.com cheap and get here in about a week. but i will send you an RX from headsup to replace it.
Need More Glue!!!
Old 01-31-2011, 03:07 AM   #23
FlyingBrick50
FlyingBrick50
Friends: (13)
Have not heard RCTimer.com
Old 02-02-2011, 12:55 AM   #24
FlyingBrick50
FlyingBrick50
Friends: (13)
Default rx power
Well, waiting on my ubec, very excited and looking forward to checking out my new/used TX with the upgraded components!!! Going to revamp the ailerons not happy with the way they are acting, concerned about flutter!
Old 02-03-2011, 01:25 PM   #25
Friends: (19)
I don't know of any Rx that doesn't have a power and other sockets for servos ... and I don't know of any that cannot be powered via any servo socket ....
BUT you should never plug in BOTH batt and ESC BEC at same time - in theory they should parallel - but they have been known to fry internals in the RX.
Sorry to say this - but you have nothing strange in your Rx layout and many replies have already answered that you can choose ... battery to Batt in OR ESC supply BEC to throttle servo position.
IF you want to use battery AND ESC .... then remove the RED / +ve lead of the ESC plug to Rx ... then it will not try to power Rx ....
If above doesn't work - you have a problem with your Rx .... and as I assume that having another person ask if it's one he supplied you - appears it worked when it left his hands ... so what did you do ? Plug in wrong way ? Connect both ESC and battery ? Somethings wrong .....
There is one other little matter ... if you plug in ESC ... switch on ... Tx and Rx ... you have to arm system before motor will work .... some brushed have a press button on plane ... brushless is usually via the throttle stick.
Sneak Peek at the NEW Cellpro PowerLab 8 Tim Marks FMA Direct 63 09-21-2012 06:09 AM
For Sale Thunder Power TP-1010C Lipo charger and Thunder Power TP-210V Balancer flyingbumma Batteries and Chargers Forsale/WTB 5 10-22-2011 12:51 AM
Help with power setup crobar Power Systems 19 01-26-2011 05:01 AM
For Sale Rx crystals-Berg-Gws-Hitec $4 each gone2fly2 Radio Equipment For Sale & WTB 0 01-14-2011 05:30 AM
Tx & Rx general info please? Red Baron RC Radios, Transmitters, Receivers, Servos, gyros 2 01-07-2011 10:59 PM
Page generated in 0.56989 seconds with 70 queries
