| Seaplanes E-Powered Discuss electric powered seaplanes here |
#1 | ||
The Reaper!
Do you think this will work on the powdery snow? Or probably strictly just on hard stuff like ice and snow that's been sitting long enough to be hardened..? I ask that because I didn't make the front of them swing up like dubro skis are. (see diagrams below) Thanks. |
#2 | ||
The Reaper!
From what i've learned about floats and ski's... i'm betting they will likely grab into the snow if it isn't hard/packed. but it's all I had to work with right now on a free budget.
Everything over here is all hard as a rock so I figured it would do the job until I order my next much larger parkflyer and float kit come spring. If you can consider a 40 size plane still a parkflyer. I'm shooting for Hangar 9's 40 size J-3 cub with matching floats. Probably with an Eflite Power 42 to power it all. Unless maybe i'm better off going with a Power 60 equivalent for extra power to ROW well. I'm open to suggestions on that as well. Thanks again for any input. |
#3 | ||
The Reaper!
Actually... I think maybe the 25 size will be better for me so I can still fly in those smaller spots that a 40 size cant go.
A 65 inch wingspan vs the 80 inch wingspan. Yeah, that sounds more like what I want. And not too bad on the price either. Is the Power 25 good enough for this bird with the fiberglass floats? Or should I upgrade to something with a little more torque? I can always order a motor/esc from hobbycity for a fraction of the price. I already have 12X6 props. |
#4 | ||
The Old Guy Returneth...
That's a nice airplane.float combo but you might want to consider a 32 instead of a 25. Floats are heavier than wheels and have a LOT more drag in the air. In addition, if you do ever fly off water the water's surface tension "pulls" on the floats WAY more that grass does on rolling wheels.
...The Bum |
#5 | ||
The Reaper!
Saddle-
That's what I was thinking as well. I will likely get a hobbycity equivalent of a Power 32. Probably going to get a few Lipo packs in the 3200-3500mah range while i'm at it. I have an E-Max 60A (switch mode bec) ESC that I can use for it as well. Thanks for replying
#6 | ||
Originally Posted by Bomb Dropper
I took a look at the specs on the H9-J3 and that is about an 8 pound airplane with floats.
You ought to be looking at about 100 watts per pound (Sport aerobatic and fast flying scale) to be sure you have enough to get this baby off the water/snow/wet grass on floats. That requirement will need a Power 42 (925 watts), not a 32. This airplane has a lot of room and can carry a bigger battery so you might want to consider a 4,000mAh, 4S. Just be sure the motor you get can handle the voltage. ...The Bum |
#7 | ||
The Reaper!
Thanks for the heads up. I'll be sure to go with the larger brushless and lipo packs then.
#8 | ||
The Reaper!
http://www.hobbycity.com/hobbyking/s...idProduct=4907
TR50-55B 600kv Brushless Outrunner (Eq.4020) Spec. TR50-55B Working Voltage: 8~30 Kv: 600 Weight: 300g Shaft: 8mm Dimensions: Length: 55mm Thrust: 2200 ~ 4600g Stator Size (AXi Measurement): 40-20 Recomended ESC: 80A Suggested Prop: 5cell:14x9 / 6cell: 14x8 Shaft: 8mm Power equivalent : .40 to .60 glow engine Similar to AXi Gold 4120/14, E-Flite Power 46. Roughly equivalent to .46 2-stroke or .65 4-stroke glow engines. Use this motor with 4-6 cell Li-Poly packs and 11-12 inch props on planes up to 8 lbs flying weight. Manufacturer suggests a 12 x 8 prop on 6 cells or 13 x 10 on 4 cells. ----------------------------- Looks like THIS is what I need right here. And only $26! I'm going to need an 80A ESC though so that's an extra $37 And two 4 cell 5000mah packs for $57 (each) So about $120 (plus shipping, if I only get ONE battery) gets me the entire power package. Not too bad. |
#9 | ||
The Reaper!
So now that we have that part all figured out.
Weather permitting, Im going to test my home-made skis on my trainer either tomorrow or the day after. Keep your fingers crossed! ... I know mine will be.
#10 | ||
Excellent choices BD. Let us know how it all turns out.
...The Bum |
#11 | ||
The Reaper!
Just an update,
I'm ordering everything next weekend! ![]() As for the home-made skiis on my trainer, they worked pretty good for take offs, but landings were a pain because it kept wanting to nose over. It did the job though. Now the weather is warming back up slowly but surely, so its all about wheels and floats again until NEXT winter rolls around. |
#12 | ||
Club: C.A.R.D.S. Lansing MI
that power system you orderd is the same one that I've orderd for my h9 ultra stick .60 just so you know I have a power32 motor from heads up rc on a T34 mentor from eflite and w/12x6 4s 5000 mah battery pulling 540 watts just something to think about thanks,chris
#13 | ||
The Reaper!
Originally Posted by cpmalish
They have that Power 32 motor rated up to 840W.
I wish Jeff would get the prop specs up for some of the newer motors he has listed on his site. It's the ONLY thing holding me back from ordering from him right now. I like to have a good idea what i'm working with (electronically speaking) on a build.Normally I do at least 80% of my rc shopping through him. Can't beat his prices and shipping. And his customer service is top rate! I wonder if the Power 46 would be just too ridiculous?
#14 | ||
I agree bomb drop thats why I went HK this time but I think that power 32 is going to fly my t34 well I may have to take it up to a 12x8 prop but we'll see right thanks,chris
