Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Seaplanes E-Powered
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 02-01-2011, 01:02 PM   #1
donjiskra
WAA-08 Pilot
donjiskra's Avatar
View donjiskra's Gallery16
Club: Woodland Aero Modelers, Downers Grove,IL
WAA-08 Pilot
Default Using a push rod for the float water rudder?
Anyone ever tried using a push rod instead of a cable?
I was not satisfied with the flexibility of using a cable, even though it was secured firmly, so I just tried using a metal push rod straight from the tail rudder to the float water rudder arm. This works out much better, now I'm wondering why I haven't seen others doing this.
Comments are appreciated.
Name:	ESCAPADE & MAXFORD WATER RUDDER.jpg
Don Jiskra, "Wings Across America" Treasurer & WAA-08 Pilot, (sometime in 2011)
donjiskra is offline
Old 02-05-2011, 10:25 PM   #2
Bomb Dropper
The Reaper!
Bomb Dropper's Avatar
Just using a pushrod and balsa ply, or even an old credit card, can work quite well on a tight budget.
All you need is a spare pushrod, a little 5 minute epoxy and an old credit card or junk piece of balsa ply.
Excuse the crude drawing below, I just made it up really quick to give you an idea of what i'm talking about.
ID:	142919 It isn't pretty, but it DOES work well.
Bomb Dropper is offline
Old 02-05-2011, 10:27 PM   #3
Bomb Dropper
The Reaper!
But, I have seen people use a pushrod to connect the main rudder to the float rudder at my field when we have our float fly events. I usually use the basic cable method on my planes and haven't had any issues worth mentioning.
Old 02-07-2011, 05:37 AM   #4
2013 President of PSSF
A push rod hooked up as you show will work, BUT there may be problems.
Just sitting on a table, everything should work OK, and in glass smooth water you may be OK, but in rough water, any movement between the floats and the fuselage, will result in a steering effect on the floats as the rudder is held by the servo. Then you make a correction, and then the floats flex the other way and you are over correcting. Gets kind of wild sometimes.
If you use a cable, the flexing of the float mounts has no effect. Mount the outer tube solidly just ahead of each rudder, and tie the cable into a smooth curve.
Or go to the rudder servo inside the plane and allow the cable to come out a small hole close to the float mount, it will be hard to see if your careful.
Dave R, Proud PGR rider.
Wildflyer is offline
Page generated in 0.29434 seconds with 28 queries
