Old 02-04-2011, 04:26 PM   #1
JBdiver
Default Standard to 3-Blade Prop
I'm running a 9x4 prop, what would be a good 3 blade replacement for this prop. I would be doing it for the pure look of the prop only.
JBdiver is offline
Old 02-04-2011, 04:45 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
8x4 to start. GWS makes owe in that size.
Old 02-06-2011, 12:30 AM   #3
Bomb Dropper
The Reaper!
Bomb Dropper's Avatar
GWS 8040X3 <-- 8 inch 3 bladed prop
GWS 9050X3 <-- 9 inch 3 bladed prop
What plane is this on? And what motor are you using?
Bomb Dropper is offline
Old 02-06-2011, 12:35 AM   #4
Catalina
I think I heard a 3 bladed prop was less efficiant than its counter part 2 bladed type. I may be wrong here, but you may need to go up a pitch or 2.
Catalina is offline
Old 02-06-2011, 12:49 AM   #5
JBdiver
I have a slowfly 28 that I think would look good with a 3 blade instead of a standard prop.
JBdiver is offline
Old 02-06-2011, 02:15 AM   #6
Bomb Dropper
The Reaper!
Your SloFly 28, does it look like this picture below?
Also, what motor are you running on it?
That way I can better say if the 8 or 9 inch would be better for you.
And Catalina is correct, the 3 bladed props are usually less efficient than the 2 bladed ones. But if you aren't maxing out on your brushless, the difference isn't going to hurt you.
Ex: HeadsUpRC 400 (sport)
GWS EP8040:24 ounces of thrust at 10 amps.
GWS 8040 3-blade:25 ounces of thrust at 12 amps.
So in this case, you gain 1 ounce of thrust at the price of 2 more amps drawn.
The question is.. Will YOUR motor still maintain the performance that you're getting with the 2 bladed 9X4 prop? And, if you go up an amp or two, is that going to kill your motor? Because you would probably want to consider the 9050X3 prop as long as you aren't going to over-amp your motor, esc or battery.
That's what we need to figure out. That's why I want to know what motor you're using with that model.
Old 02-06-2011, 02:24 AM   #7
JBdiver
Yes, my slofly looks like those...
Brushless Motor Specs:
No. Of cells:2-3 Li-Poly, 6-8 Ni-Mh/Ni-Cd
RPM/V:1800 RMP/V
Max. efficiency current:8-20A (>80%)
No load current / 10 V: 0.8 A
Current capacity:24A/60 s
Internal Resistance: 90 mO
Dimensions:27.5x26 mm
Shaft diameter: 3.17 mm
Weight:36g /1.27 oz
Recommended model weight: 600 - 1000g
JBdiver is offline
Old 02-06-2011, 02:55 AM   #8
Bomb Dropper
The Reaper!
Do you use a 3 cell Lipo? Or a 2 cell?
I would recommend a 2 cell with the 9050X3 prop if you have one handy. But if you have a wattsup meter, you could see exactly whats going on with both props on a 3 cell pack, and then determine if you NEED to go to a 2 cell pack when using the 9050X3 prop.
I'm assuming you're using something equivalent to the "blue wonder" (CDRom style brushless) motor? If so, at 1800kv, I would DEFINITELY go 2 cell with the 9050X3 prop.
There ARE 2 different versions of it 1300kv and 1700kv
I would go with the lower kv version if you want to use a larger (9050X3) prop on 3 cells.
Hope this helps you out somewhat.
Old 02-06-2011, 03:07 AM   #9
Bomb Dropper
The Reaper!
But, if you're just in this for the looks of the prop, then I would just grab a GWS 8040X3 and go for it!
Old 02-06-2011, 03:24 AM   #10
JBdiver
I'm real old school and have an 8 clerk NIMH pack.
JBdiver is offline
Old 02-06-2011, 03:31 AM   #11
Bomb Dropper
The Reaper!
Yeah... just go with the 8040X3 prop then.
Actually, seeing that a 3 cell Lipo is 11.1V, and you're only using 9.6V with your nimh battery, you could probably use the 9050X3 prop without worrying about a thing.
But I would definitely recommend using a wattmeter to properly test output and amp draw while cranking it at WOT. Nothing beats being sure.
Old 02-06-2011, 03:38 AM   #12
Bomb Dropper
The Reaper!
PS: I don't blame you about having the nimh batteries. Lipo batteries can get pretty darn pricey. I've probably invested over $500 in Lipo batteries over the past few years. And that's doing it in moderation, lol.
Old 02-06-2011, 12:37 PM   #13
WAA-08 Pilot
Friends: (9)
While this used to be the case it is no longer true. LiPo batteries are the cheapest, lightest and highest energy density of all our batteries.
We can thank they influx of Chinese vendors selling for much lower rates. There are a number of US business that carry those packs for budget prices as well.
Old 02-06-2011, 03:19 PM   #14
Bomb Dropper
The Reaper!
True.. thanks to hobbycity.com and a few others.. otherwise, prices would still be a bit overwhelming to a lot of folks out there on a tight budget, myself included. Especially when having to often buy packs from 2200mAh and up.
But yes, it could be a lot worse.
What does a motor's watt rating represent? starfire73 Beginners 40 03-24-2017 09:29 PM
Scratchbuild of an Extra RC Fan Chris Scratch and Kit Built Aircraft 36 07-31-2012 07:21 PM
Hacker A60 18L Prop? gdwyer General Electric Discussions 5 01-18-2011 04:36 AM
Best motor / prop for HL F18 conversion foamjetpilot Pusher Park Jets 3 12-21-2010 04:04 AM
Page generated in 0.51684 seconds with 48 queries
