Old 02-10-2011, 02:26 AM   #1
galant
galant's Avatar
View galant's Gallery1
Default mystery esc problem
hey peoples
im haveing problems with a mystery 50a esc when i plug everything in it just keeps beeping ive tried reversing the thottle and changing the motor wires around nothing seems to work. any ideas would be apprecated thanx..
galant is offline
Old 02-10-2011, 03:41 AM   #2
Saucerguy2
Friends: (13)
Is your TX on and are you sure it's the correct RX? If they are out of sinc, ie. it's not getting a signal, it will keep beeping like that.
Saucerguy2 is offline
Old 02-10-2011, 03:48 AM   #3
View CHELLIE's Gallery13
Friends: (327)
also see that the wires going into the receiver are correct and not turned around, also the Mystery 50 amp ESC might not have a BEC, check for a BEC in the ESC, sometimes larger ESC dont have Becs.
Old 02-10-2011, 04:01 AM   #4
galant
galant's Avatar
its this one if that helpsName:  mystrey 50a.bmp
Size:  26.1 KB its got a ubec
galant is offline
Old 02-10-2011, 12:14 PM   #5
offtom
Megans Servant
offtom's Avatar
View offtom's Gallery6
Club: Maggie Mae's Menagerie
WAA-08 Pilot
Have you calibrated the throttle yet?
Looking through the instructions on the 40 amp kind of sounds like this may be the problem.
http://www.hobbyking.com/hobbyking/s...8X44143X22.pdf
Cheesy poofs are what Yankees get when they eat Southen Food!! bub, steve
offtom is offline
Old 02-10-2011, 09:47 PM   #6
squidger
squidger's Avatar
Make sure your throttle is at idle and the trim is also at the bottom.
squidger is offline
Old 04-07-2015, 08:52 PM   #7
pilot101
HELP BINDING XPS NANO RX"
Bought a new XPS NANO 6 Chan RX I hooked up One of my eight channel XPS same way and it all works. I used 40 amp HURK Speed control with power to #1 #2 is right aileron and #3 is left aileron..
Looking for someone that knows how to bind NANO receiver.. I have used the XPS Manuel it says power to RX thru speed control.. Flashing red plugin bind plug get solid red remove bind plug Then hold button in on Module till green light comes on let go and it is red on module.. I am using JR XP9303 TX with XPS module..
pilot101 is offline
Old 04-09-2015, 03:46 AM   #8
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Check here. XPS has a forum that has all kinds of info and videos on setting up their items.
http://www.rcgroups.com/xtreme-power-systems-483/
Glacier Girl is offline
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 12:45 PM
Parkzone spitfire flight problem! Help! CPomeroy Beginners 30 02-12-2011 08:45 AM
HELP, Turnigy Plush 40 amp ESC KenSue Power Systems 2 01-20-2011 10:09 PM
Hacker X-Pro USB interface unable to connect to ESC Devil_Inside Power Systems 1 01-06-2011 06:03 PM
Page generated in 0.10280 seconds with 35 queries
