Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 02-11-2011, 05:39 PM   #1
pauljdimauro
Default Sig Riser 100 electric
Hi Everyone, I'm building a Sig Riser 100 with modifications.
Does any one have some info on electric motor offsets?
Pics will follow.
Thanks,
Paul
pauljdimauro is offline
Old 02-11-2011, 06:42 PM   #2
MaxAdventure
AMA 198798
MaxAdventure's Avatar
View MaxAdventure's Gallery2
Send a message via Yahoo to MaxAdventure
3kW  1kW  2kW
Friends: (7)
Pics will follow.
Thanks,
Paul
When dealing with a powered glider, you may or may not care how it pulls during a climb. E.g.; my Powered BoT I didn't worry about any motor offset as I am only under power for 45-60 seconds at which point I start hunting thermals. Sure, it want's to loop under full power with 0 down-thrust, but I'm happy flying it up and was more concerned with trying to keep things as streamlined as possible with the power off. That's when it's REALLY flying. I suspect the larger/slower prop would require more than a smaller/faster prop - what do you plan on using? FYI, when I am doing offset for planes like this I generally start with 2-3 degrees down and 3-4 degrees right. Again, I do like to climb under power - not keep level at full throttle.
I've seen several sig riser 100" e powered builds/conversions on RCG, you may want to check the sailplane section there. Great aircraft, that riser!
There is ALWAYS room for some levity in your brevity!
MaxAdventure is offline
Old 02-11-2011, 07:35 PM   #3
pauljdimauro
Thanks MaxAdventure,
I will take your advise. Pics will follow soon!
Old 02-12-2011, 01:47 PM   #4
riverrat
circa: 1946
riverrat's Avatar
Club: NRA Life Member
Friends: (22)
Subscribed!!
Good advice from MaxAdventure!!
Don't forget the spoilers, you'll need them!
Regards!
Jimmy
Name:	RISER100AUW 54 oz..jpg
riverrat is offline
Maryland Electric Day Spectacular June 4, 2011 weathervane Events, Shows and Fun Fly's - Electric Airplanes 7 06-12-2011 09:31 PM
40 size electric cub hybrid General Electric Discussions 16 02-12-2011 09:35 PM
conversion of J3 cub to electric hybrid General Electric Discussions 6 01-23-2011 09:43 PM
Sold sig lil rascal arf w/ servos Ebay no reserve. Last Hours! 1987tc Airplanes - Electric For Sale & WTB 2 01-07-2011 03:46 AM
Page generated in 0.32378 seconds with 28 queries
