Old 02-26-2011, 04:48 AM   #1
jap71173
BigWatts.shutterfly.com
jap71173's Avatar
Friends: (8)
Default General Help Question
Sorry, i wasn't sure where to post a general question thus the new thread...
Here’s my question:
What does "38mm from leading edge of wing at fuselage" mean exactly?
Is this 38mm from the front face of the wing or back end of the wing, or something else completely?
jap71173 is offline
Old 02-26-2011, 05:07 AM   #2
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
"Leading edge" means the very front edge of the wing, the one that "leads" the way through the air.
The rear edge is called the "trailing edge". Same reason.
Hope this helps.
OK, I got my "drone licence"...
When does the season start and what Ammo can I use?
FlyWheel is offline
Old 02-26-2011, 06:44 PM   #3
eflight-ray
eflight-ray's Avatar
Usually it relates to a model that has a swept back wing, where the measurement is taken at the point the wing touches the outside of the fuselage. Not the center line of the wing.
Also with some mid wing models it's impossible to actually see the LE and the center, so the measurement has to be from the visible LE where it exits the fuselage side.
Always check the plan or instructions though, as some manufacturers/designers may mean the dimensions are to be from the most forward part of the LE at the center line.
Ray in Wales
As I get older I think more and more about the hereafter.
I walk into a room, and think, 'now what was it that I'm here after?' :o
eflight-ray is offline
Old 02-28-2011, 05:26 PM   #4
constantmotion
That is correct.
constantmotion is offline
Old 02-28-2011, 07:43 PM   #5
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Yep as stated. You need to pay attention to the spot they tell you to measure from.
Some may have a specific distance from the fuse. Like eflight-ray stated on a swept wing it's right up against the fuselage.
Now on the PZ Trojan which has a nearly straight LE, the specs say to measure the CG point 1" (one inch) OUT/AWAY from the fuselage.
Why? Because at that point the wing goes from being straight to a swept forward design. Measure against the fuse and your CG would be off by an easy 3/4", and you would have a VERY nose heavy bird.
One last thing. If you are dealing with a non name brand bird, like something form Hobby King, NitroPlanes, Banana Hobby, etc. Take the CG point with a grain of salt. Many of them are so far off you'll be lucky if the plane lasts one flight.
If you don't know the CG point or question it, check it. CG point is almost always within 25 to 35% of the wing chord.
Chord is the length of the wing from front to back. So say you have a 3" chord, your CG point will be right around 1" back on the LE.
Also there are quite a few web based CG calc programs. All you do is input your plane's stats, and it will spit out a good starting point for the CG.
Glacier Girl is offline
Old 02-28-2011, 09:04 PM   #6
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (169)
Hi
For an accurate CG location with any aircraft give one of these a go
http://home.mindspring.com/~the-plum...%20Machine.htm
Take care dear friend
Yours Hank
kenchiroalpha is offline
Tags
edge , leading
Tri-Motor setup question KnowAceHere General Electric Discussions 9 02-08-2011 09:39 PM
R/C transmitter mods question sschevel Beginners 11 01-07-2011 05:21 AM
New member question?? Don Sims General Electric Discussions 12 12-31-2010 12:16 AM
Parkzone Radian battery question.. Fulanito_uk Beginners 3 07-05-2009 12:28 AM
Page generated in 0.08201 seconds with 29 queries
