Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Micro Sized Electric Helicopters > E-Flite Helicopters
Old 02-28-2011, 11:02 PM   #1
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Default SR 120 Tx settings.
I would be interested to hear about your Tx settings for this little bird.
I have one and I have it bound to a DX6i transmitter
I have noticed that it wants to drift forward--I have had to add sub-trim for
back stick to about 100. I will have to adjust the pushrod at the swash
to get rid of all the trim, eventually.
I'm running about 90% on the rate and about 25% expo on the right stick.
Has anybody done anything with mixes or any other settings?
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is offline
Old 03-05-2011, 11:00 PM   #2
Thunder
Thunder's Avatar
Location: Littleton, Colorado google voice 315-256-0536 feel free to call!
Did you set your 120 up as a fixed wing or heli? I fixed mine up as a fixed wing and seem to be able to control it nicely from the settings on the transmitter.
G'day, Cheers, hello. :-)
Thunder is offline
Old 03-05-2011, 11:50 PM   #3
Heli Jim
Heli Jim's Avatar
I set mine as a heli. Mainly because I like the throttle hold function.
Heli Jim is offline
Old 03-07-2011, 05:25 PM   #4
Thunder
Thunder's Avatar
The only thing I did was go into D/R&EXPO and change my Aile, Elev, all to 50 %, then in set up list, I selected D/R COMBI, then I changed the selection to ELEV. Now, if I flip the Elev D/R switch on the left side of the DXI to position 1 (toward you), it automatically cuts your Ailerons and Elevator to 50%. Useful if a friend wants to fly or you want to fly inside and your used to flying in wind like I am. You can call it a beginner switch (mind you, I have it set up as a Fixed wing). I would LOVE to get my hands on some good Helicopter settings!
Thunder is offline
Old 03-25-2011, 04:44 PM   #5
buzzbomber
Matt Smith
buzzbomber's Avatar
View buzzbomber's Gallery11
Did you set up the built-in dual rates? If not, go to the gyro menu and set switch position "1" to 0% and position "0" to 100%. Instant dual rates handled by the 5in1 board. I also have a mix setup which adds left cyclic automatically when adding forward cyclic, linked to the flight mode switch. It's good for compensating for the right turn tendency when in FFF, and can be switched off for hovering.
Matt
Down with Gravity!
buzzbomber is offline
Old 05-15-2011, 12:40 AM   #6
dacaur
dacaur's Avatar
I used ot have a mix linked to a flgiht mode to compensate for the right drift in FFF, but I rarley used it, after a while I just compensated automaticaly, so I got rid of the mix....
Definatly set it up as a heli slot, then you can play with the throttle curve to either give you a wider "hover band" or if you plan to move on the CP someday, you can make it so it hover around 60-75% throttle, like a CP heli does...
Also throttle hold is good to get used to using if you plan to move onto CP helis too....
dacaur is offline
Old 08-05-2011, 08:51 PM   #7
Heli Jim
Heli Jim's Avatar
One thing that I did, also was to trim out the "lean to the right" that is set so it
will hover decently. If this right is trimmed out, it flies forward a whole lot easier.
I'd rather hold some right aileron when I hover, than have to add some left everytime
I fly forward.
Heli Jim is offline
Old 08-05-2011, 10:32 PM   #8
dacaur
dacaur's Avatar
I fly forward.
If you have a computer radio, a better way to do this is to set up a mix that gives left aileron with throttle... somewhere around 20% should do it....
dacaur is offline
For Sale Four SR "MAX" Flight Packs 2 NEW Packs $308.00 worth of packs All American Batteries and Chargers Forsale/WTB 4 08-31-2011 08:21 PM
Eflight electric Heli Blade Sr 120 wiring cessna Power Systems 2 01-30-2011 06:22 AM
Tx & Rx general info please? Red Baron RC Radios, Transmitters, Receivers, Servos, gyros 2 01-07-2011 09:59 PM
For Sale JR XP6102 6 Ch FM TX HeliScRapYard Radio Equipment For Sale & WTB 5 01-05-2011 04:18 PM
SR Collective Pitch Problem nam6869usmc Micro Sized Electric Helicopters 2 12-27-2010 02:44 PM
Page generated in 0.08208 seconds with 33 queries
