Old 03-08-2011, 10:14 PM   #1
cpmalish
Club: C.A.R.D.S. Lansing MI
Default will spektrum servos work with futaba fasst system?
I just bought a hanger9 ultra stick .60 that I'm converting to electric my ? is it came with spektrum servos in the wing and it's set-up with flaps I'm pretty sure I've gotta get one servo rev switch for flaps but the alierons seam to work a little at differnt rates when I activate left to right and oppiset or is that how digital servo's work? any ansewrs are greatly appreciated thank you ,chris
cpmalish is offline
Old 03-08-2011, 11:08 PM   #2
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
Got your message about this Chris. I'm not familiar with that system but hopefully someone will have an answer for you. Sorry I couldn't help.
Tom
Grasshopper is offline
Old 03-09-2011, 12:13 AM   #3
Question:
What brand of radio are you using? If memory is correct, Spektrum has a dim view of those servo reversing cables. One of my club members nearly lost a 1/4 scale 80 cc gas engine model when one of those servo reversers gave him full down on one of his flaps without a flap command. He contacted Spektrum, who responded to use a standard and an Aux channel on the receiver, and program the transmitter to operate the flap servo by a mix command.
Old 03-09-2011, 12:22 AM   #4
cpmalish
yeah I'm using a futaba fasst radio and 7channel rx so on the 6 ex radio I don't think it has a mix ablity but thank you for your response
cpmalish is offline
Old 03-09-2011, 03:27 PM   #5
Rodneh
Club: Moonport Modelers
All servos are quite similar in input requirements and all I have seen have been completely interchangeable between systems. One possible exception is some of the very early (20 years or so ago) that require a slightly higher input voltage than some of the 2.4GHz systems output. In most of the modern receivers, the magnitude of the pulse to the servo is only a bit over 2 volts, some of the old DAD servos required a bit more amplitude than that.
Rodneh is offline
Old 03-11-2011, 05:52 PM   #6
cpmalish
thanks everyone got the problem taking care of.
cpmalish is offline
Futaba S3114 Servos. flyboy_fx General Electric Discussions 4 01-27-2011 02:19 AM
Heads Up: OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver in stock bob4432 RC Radios, Transmitters, Receivers, Servos, gyros 26 01-03-2011 10:43 AM
Sold Futaba Ultra Micro Flight Pack R124F RX and three S3110M Servos All American Radio Equipment For Sale & WTB 0 07-02-2010 04:47 PM
Page generated in 0.07493 seconds with 29 queries
