Old 03-11-2011, 04:09 AM   #1
maccountrypilot
Default Determine EDF?
OK .. I am still confused. In the world of electric prop planes ... a motor should be roughly 100 watts in size for each pound of weight of the plane it is going in. There certainly must be a rule of thumb for EDF aircraft. I do all my own design and it would be nice to know what the general rule of thumb would be. Can Anyone please help??
maccountrypilot is offline
Old 03-11-2011, 10:59 AM   #2
View CHELLIE's Gallery13
Friends: (304)
Because EDF are low on Thrust and Power, use the biggest Dia. EDF that will fit into your Plane/Jet use a EDF Motor thats about 3500KV to 4000KV any higher KV on the motor will just be turned to Heat and more AMP draw, Just My 2 cents worth Take care and Have fun, Chellie
the above info does not apply to mini 30mm edfs, there you will need lots of KV to get them going
http://www.rc-electric-jets.com/Elec...uidelines.html
give these people a call, they can answer all of your questions, they are the EDF pros
Old 03-12-2011, 01:57 AM   #3
2014 President of PSSF
Friends: (7)
On my F-16 (unknown brand) it has a 64mm fan and pulled about 240-250 watts, and weighs just under 18oz, it flies pretty nice, but I don't know how fast, or how it compares to other EDFs like the Habu and many others.
Dave R, Proud PGR rider.
Wildflyer is offline
Old 03-12-2011, 01:48 PM   #4
babylon5
In addition I may add that unlike propeller driven system, EDF do suffer from diminishing return when you try to increase power. It depends on the volumetricity of the EDF. Small EDF like the 55mm and smaller diameter have very small volume, When you try to increase the setup power from 250watts to 400 watts you don't see very significant improvement in terms of vertical climb or speed. That is because as you try to increase the rpm up , there is so much the air can exit the EDF(being small) than the amount the air in getting into the chamber. As a result pressure built up quickly in the chamber and work against the rotating blade.
Diminishing returns set in (sometimes known as saturated state) because you can put alot of power into the motor but very little useful work is converted to thrust or e-fflux because that is so much the air can exit the outlet. Under this situation pound per watt become meaningless.
Therefore bigger diameter EDF performs better and can handle much more power before saturation state occur.
Cheers and welcome to the "duct side.'
babylon5 is offline
ELERC Micro A-10 Warthog 30mm EDF Beta Test Joe 1320 Electric Ducted Fan Jets 13 02-02-2012 01:15 PM
EDF Dilemma tarheal63 Electric Ducted Fan Jets 11 02-28-2011 09:28 AM
EDF Size maccountrypilot Electric Ducted Fan Jets 1 02-20-2011 01:03 AM
How to Balance a EDF Impeller CHELLIE Electric Ducted Fan Jets 15 01-23-2011 04:07 PM
Changing out an EDF motor & fan Hernthehunter Electric Ducted Fan Jets 3 01-07-2011 07:02 PM
Page generated in 0.19025 seconds with 25 queries
