| Hi-Performance and Sailplanes RC hotliners, electric pylon racers, F5B, F5D, sailplanes and gliders |
#1 | ||
I am new to the electric powered planes. I have flown glow plug planes in my teens in the 80's and also AAA target drones in military in 1990 (those were quite fast ones with overpowered motor for hand launch in rough terrain). Currently I have a Hobbyking Fox EPO 2.3m electric glider but I want something faster and more powerful. I received the Orion V3 ARF kit from Modellbau Lindinger in Austria so this is the airframe to be used. It should be reasonably slippery with thin airfoil. No high end though but no high end needed or required. Reasonably good performance is wanted with effortless vertical climb. I have one Turnigy Plush 80A ESC from 500 heli which will be used. I also have several 2200mAh 3s and 2650mAh 6s lipos from 450 and 500 class helis which I also fly. There must be a very good reason for not to use the existing batteries. The frame fits single 6s or parallel 3s just fine. I also have leftover Turnigy 3632-1500kv motor. CC Ecalc with 10x6 prop gives something like 50A, 2300g static thrust and 117 km/h pitch speed. What kind of real world performance does this mean? Motor will overheat but will be used with short bursts only. For more power I thought about turnigy 3648-850kv Parallell 3s lipos with 14x10 prop gives 3400g thrust, 107km/h pitch speed and 60 amps. 6s lipo with 10x6 prop gives 3900g thrust, 145km/h pitch speed and 50 amps. I have no idea if these numbers are correct but they are given by the eCalc. Motocalc gives less thrust but otherwise similar numbers. What is expert opinion about these combos? Will the 6s setup rip the Orion apart? Turnigy 36xx fits the nose of the Orion just fine. On paper blue/red 3648 range beats other similar size Turnigy models (SK/TR) hands down. Budget combo is my goal so Kontronic & Co is definitely out of question. Sorry for no links to products but: ![]() ![]() ![]() The following errors occurred with your submission:
#2 | ||
Friends: (281)
Hi B12 and Welcome to Wattflyers
here is some info that i saved for a Hotliner, maybe it might be of use to you you just need a few more post to be able to post pics, the system helps to keep the Spammers out of here ![]() ZIPPY Flightmax 2650mAh 5S1P 40C http://www.hobbyking.com/hobbyking/s...idProduct=9949 Hobbyking SS Series 190-200A ESC http://www.hobbyking.com/hobbyking/s...dProduct=14500 KD36-74-06XL 2800kv motor: http://www.hobbyking.com/hobbyking/s...idProduct=6677 apc 6x5.5 2900 watts w/ a 6x4 and 170amps! all for $86.69! 179 mph pitch speed |
#3 | ||
Friends: (281)
and another set up from RC Foam Fighters 1600 Watts
#4 | ||
Friends: (281)
Also look at the 100 MPH club on the 1st page post #1 there it shows what others pilots have used as far as power systems to go fast
![]() http://www.wattflyer.com/forums/showthread.php?t=26852 |
#5 | ||
Friends: (281)
1. you can use your 80 amp ESC
2. your 3648-850kv motor is only rated for a 3 cell lipo max. 3. the 6cell 2650mah can be used 4. your 3632-1500kv is only rated for a 3 cell lipo max. 5. the 3648-1450kv motor is rated for a 6cell, you might want to Buy that motor. http://www.hobbyking.com/hobbyking/s...idProduct=8485 6. use a UBEC dont rely on the bec in the ESC. http://www.allerc.com/castle-creatio...ak-p-3219.html 7. get a wattmeter, its a must have, you will need it big time to check and save your power system http://www.hobbyking.com/hobbyking/s...dProduct=100808. use a 7x5 APC prop with 6 cells and the 3648-1450 KV motor, this will draw 90 amps, use in short wot burst with your 80 amp Esc. http://www.allerc.com/apc-7-x-5-thin...ler-p-508.html 22 volts x 1450KV = 31900 RPM + 7 pitch prop= 151 MPH prop pitch speed http://www.rcpro.org/rccalc/PitchSpeed.aspx Hope that helps, Chellie |
#6 | ||
Originally Posted by CHELLIE
Thanks for the reply!
2. That is an error in HK specs. The original data from motor manufacturer states 3-6s lipo. On the other hand performance numbers with 6s & 10x6 are not that much better from 3s with 14x10. Plus the 2650 6s battery is HUGE and heavy compared to two 2200 3s's. I am leaning towards 3s setup for starters. It would be easy to upgrade to 6s by swapping the battery and prop blades only. 3. The plan was to use two parallel 3s lipos and 10x6 folding prop Anyway I am not after the world speed record just some entertaining performance for fun flying moments.
#7 | ||
Friends: (281)
Originally Posted by B12
your right, i had to do some searching
![]() http://www.electriflite.co.uk/store/...t3648-850.html More Views Turnigy 3648 Brushless Motor 850kv Be the first to review this product Availability: In stock.£27.65 Add Items to CartQty: Add to Cart OR Quick Overview For 1500~2500g airplane & 500 size helicopter. Specification RPM/V850Number of cells3~6 LiPolyResistance0.0185 0hmsNo Load Current2.8AMax. efficiency current45~50AMax. Amps55A/20SSize51mm x 37mm, 70mm(with shaft)Weight136gShaft diameter5mmRecommended Prop Size11"~15"Recommended for Model Weight1800~2500g |
| MPJA Power Supply | kyleservicetech | Batteries & Chargers | 0 | 02-15-2011 02:02 PM |
| Advice on Flexible Power System | EZglider | General Electric Discussions | 6 | 01-12-2011 03:52 PM |
| little advice needed please | lee84 | Beginners - Helis | 9 | 12-30-2010 01:20 AM |
