Old 03-21-2011, 12:30 AM   #1
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
View HeliScRapYard's Gallery3
Send a message via AIM to HeliScRapYard
Default $100 Scratch Build Contest: X-41 DeltaStorm
So, I've decided to go into my first Wattflyer Contest, Went through a bunch of plans and this one caught my eye. The X-41 DeltaStorm. I will Have three objectives with this build,
A: Enjoy Building a new Plane.
B: Lose a Contest
C: Go For 100Mph under $100.
Lets See How it Goes!
Link to Plane and Plans which this plane will be built from, Below:
http://www.rcgroups.com/forums/showthread.php?t=779331
Price List:
1 Sheet of Foam: $1.50
1 3mm Square CF Tube: $3.80
2 SG90 9g servos @ 2.70 ea.: $5.40
1 Corona RX and Crystal: $16
2 1/2A Control Horns: $.99
1 3.17mm Prop Adapter: $3.19
1 HobbyKing BlueSeries 40A esc: $18.22
1 HXT 2845 2700Kv Inrunner: $12.66
1 11.1v 2200mah lipo: $9.99
1 APC 5.5x4.5: $2.19
1 Roll of Strapping Tape: $4.99
1 12" 2-56 pushrod: $.99
4 Solder on Clevis: $2
1 3\8" basswood stick: $.89
small piece of ply for motor mount: $.50
Gluesticks: $1
4 Rare Earth Magnets: $.20
4 Popsicle Sticks: $.10
2 bottles of craft paint: $4.98
Grand Total: $89.59
Need More Glue!!!
HeliScRapYard is offline
Old 03-21-2011, 01:53 AM   #2
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
View hillbillynamedpossum's Gallery5
Club: Is under the seat
Friends: (8)
WELCOME WELCOME WELCOME!
Looks like you and Steve are gonna have to race!
Glad to have you on board.
Possum
Founder, Chief Builder, Head Designer, an Lead Test Pilot of Possum Holler Aircraft Company. (A made up company that transforms styrofoam into packing peanuts, and balsa wood into toothpicks)
hillbillynamedpossum is offline
Old 03-25-2011, 10:11 AM   #3
jungmann1
electron deficient
That looks pretty cool! Watching. Is that fan fold?
jungmann1 is offline
Old 03-25-2011, 11:24 AM   #4
HeliScRapYard
Foam Junkie
Yes it is, I've always liked building with the fanfold, and mine probably wont look as pretty, but its ok. I'm off to a slow start, but will get there.
Need More Glue!!!
Old 04-17-2011, 06:53 AM   #5
View CHELLIE's Gallery13
Friends: (327)
Subscribed,
Old 04-22-2011, 04:27 AM   #6
HeliScRapYard
Foam Junkie
Here Are All My Parts Cut out, and all the electronics i will be using in this bird.
ID:	147059   Click image for larger version
Need More Glue!!!
Old 04-22-2011, 04:48 AM   #7
HeliScRapYard
Foam Junkie
moved price list
Need More Glue!!!
Old 04-22-2011, 04:51 AM   #8
HeliScRapYard
Foam Junkie
Assembled the Bottom and Sides of the Fuse with Hot Glue.
Need More Glue!!!
Old 04-22-2011, 04:55 AM   #9
HeliScRapYard
Foam Junkie
I Have Decided to Go with Fixed Canards on this Version, the Next Deltastorm i Build will have functional canards. I just wanted to save weight on this one since i will be using a Heavy Motor and Battery. I Glued them parallel to the wing.
Need More Glue!!!
Old 04-22-2011, 04:57 AM   #10
HeliScRapYard
Foam Junkie
I Have cut one CF tube into two pieces and embedded it into the wing. I Am Using 3mm Square CF Tubes in the wing. Used the Square as it does not flex as much.
Need More Glue!!!
Old 04-22-2011, 05:02 AM   #11
HeliScRapYard
Foam Junkie
Hinged The Elevons with the strapping Tape.
Need More Glue!!!
Old 04-22-2011, 05:21 AM   #12
HeliScRapYard
Foam Junkie
I've got the Vertical Stabilizers glued in place and dry fit the fuse. will have to decide how i will mount the motor before i continue further. thinking about the stick mount with a plywood plate notched mounted on the stick to bolt the motor up to.
ID:	147067   Click image for larger version
Need More Glue!!!
Old 04-23-2011, 01:08 AM   #13
Rode the short bus
Friends: (8)
Lookin good Scrapper!
Old 04-24-2011, 06:10 AM   #14
HeliScRapYard
Foam Junkie
Alrighty, so the idea is to stick with the stick mount. I believe this one will do. if not, it should be one spectacular crash Oh, and yes.. It is ugly, after all i made it
ID:	147228   Click image for larger version
ID:	147229   Click image for larger version
ID:	147230   Click image for larger version
Need More Glue!!!
Old 04-24-2011, 06:24 AM   #15
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (169)
Hi
Shes coming along quite nicely
Very nice work
Take care
Yours Hank
kenchiroalpha is offline
Old 04-24-2011, 10:50 AM   #16
Friends: (327)
Hmmm that looks like a 2700KV motor, good motor by the way when you get it done, let me know so I can Do The maiden Flight On it LOL, JK, Take care, Chellie
Old 04-24-2011, 01:59 PM   #17
HeliScRapYard
Foam Junkie
it is the 2700kv. I've only had about 6-7 flights with it on the previous plane but it does seem like a well built motor so far.
Need More Glue!!!
Old 04-26-2011, 02:31 AM   #18
Rode the short bus
Friends: (8)
I like the new avetar.....I must be a nerd, cause I know thats the multiple universe episode!
Possum
Old 04-26-2011, 04:21 AM   #19
flyboy_fx
flyboy_fx's Avatar
Club: Western carolina rc skyhawks.
WHere you get that foam?
flyboy_fx is offline
Old 04-26-2011, 05:16 PM   #20
HeliScRapYard
Foam Junkie
I Buy It at lowes or Home Depot. it is the 1/4 in fanfold. i buy the kind with the plastic on one side. they stopped selling it at our lowes store to a new kind so when they clearanced it out i bought 4 bundles. our home depot now sells the kind i like kind but its in pink. May be different in your area. it costs about $37 for 25- 24x48in sheets. Cant Beat It!!! IMHO
Need More Glue!!!
Old 04-26-2011, 05:24 PM   #21
HeliScRapYard
Foam Junkie
OK, So a little more got done I Mounted the motor to the plane, Glued the fuse on and Glued in the top piece. Next i have to cut the canopy and rear hatch for electronics.
Ready to get this Bird in the air!
ID:	147377   Click image for larger version
ID:	147378   Click image for larger version
Need More Glue!!!
Old 04-26-2011, 06:19 PM   #22
flyboy_fx
flyboy_fx's Avatar
So should I pick up some of it for 15$ a bundle at lowes? :O It's kinda beat up though so I will pass. I will look for the pink stuff than!!!!
Thanks for the help.
Old 04-26-2011, 06:21 PM   #23
flyboy_fx
flyboy_fx's Avatar
I'm thinking of building a funbat. I have never actually set up Elevon(?) mixing before. I have two JR servos just waiting for me to do it too. lol
Great looking bird ya got there!
Old 04-26-2011, 11:30 PM   #24
HeliScRapYard
Foam Junkie
Thanks, yea, it is hard to find a good bundle of foam luckily we have three lowes around here to pick from.
Need More Glue!!!
Old 04-28-2011, 04:15 PM   #25
HeliScRapYard
Foam Junkie
Sanded the top of the fuse and mounted servos control rods for the elevons.
ID:	147475   Click image for larger version
Need More Glue!!!
Dornier 212/Spruce Goose/Blackurn B44 & B49B Clydesman/C2A nacelle/Saro-53 HO-229 Scratch and Kit Built Aircraft 225 07-19-2014 11:39 AM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 107 08-27-2013 12:23 AM
$100 Scratch Build Contest: Simple Pylon Racer Stevephoon Scratch and Kit Built Aircraft 57 01-19-2012 02:27 AM
$100 Scratch Build Contest - Blohm und Voss BV 141 offtom Scratch and Kit Built Aircraft 17 05-11-2011 02:40 AM
DISCUSSION OF $100 Scratch Build Contest hillbillynamedpossum Scratch and Kit Built Aircraft 44 03-12-2011 05:31 AM
Page generated in 1.35392 seconds with 86 queries
