Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Night Flying
Night Flying Discuss night time aircraft illumination, methods and equipment.
Old 03-22-2011, 07:57 AM   #1
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
View CrimzonRider's Gallery18
Friends: (14)
Default Diffuser for Nav Lights..?
I am looking for a way to be able too see my nav lights a little better. The lights that I have are extremely bright, if you are looking lateral at the end of the wing.
The navs from the front are barely visible at best. I am not a Black Night flyer yet lol just love flying at dusk and some of my flights have been a little long.lol
Its kinda like seeing two mini spotlights on the tips, and i am looking for a better way of using some sort of plastic or something that diffuse that light better to a wider(maybe closer to 180degrees) pattern. Any cheap or scratch built ways or ideas would be appreciated.
thanks
cr
CrimzonRider is offline
Old 03-23-2011, 12:30 AM   #2
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Have a spare LED? Take some 400 grit sandpaper to the plastic on it. Just enough to make the lens look dull instead of shiny.
Also you can take the sandpaper and slightly flatten the end of the LED. This changes the spot light effect to more of a flood lamp. The curved end acts like a lens to concentrate the light, flattening it will reduce the directional beam to a spread pattern.
This will change the LED from directional to diffused. Will increase the light emitted from the sides.
Also for the next time, LED's come in different viewing angles, order ones with a wider angle.
Glacier Girl is offline
Old 03-23-2011, 01:08 AM   #3
CrimzonRider
Friends: (14)
Thank you GG, the nav lights came with the plane stock. Had no idea that you could buy led's that produce a "flood light" pattern.
I will do a lil searchin on tha net and see if I can find them, if I need some more. Thanks again.
cr
Old 03-23-2011, 02:59 AM   #4
MustangMan
MustangMan's Avatar
WAA-08 Pilot
Friends: (15)
This is probably not for you, but last year I made a pair of wing tip caps using vacuum forming. I used plastic milk jugs for the stock material and used a plug carved from a block of balsa. I've attached a couple of photos of the result. When glued over the wing tip the LED's ( I used two at each wingtip ) make the cap light from the inside. It was VERY visible in flight.
Name:	Wingtip Cap 1.JPG
Name:	Wingtip Cap 2.JPG
MustangMan is offline
Old 03-23-2011, 03:14 AM   #5
CrimzonRider
Friends: (14)
Yeah probably not for me right now, but I can see how it would work well.....
but thanks always wanted to try vacuum molding, kinda interesting..
ltr
cr
Old 03-23-2011, 05:03 AM   #6
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery38
100mph Speed Demon  3kW  1kW  WAA-08 Pilot
Friends: (67)
CR,
Try the Drinking Straw trick. Works awesome.
Electricity... It's not just for light bulbs anymore.
GoProfessional Cases industry grade protection for your gear
Dinogy Lipos professional grade energy
Project Globetrotter Participant 7/09
Wings Across America Participant 6/10
Nitro Blast is offline
Old 03-24-2011, 02:53 AM   #7
CrimzonRider
Friends: (14)
Never ceases to amaze me here at WF. Those look awesome, thank you very much, my kind of price too.!!
ltr
cr
Old 03-24-2011, 04:11 AM   #8
Nitro Blast
Friends: (67)
ltr
cr
CR, use white straws, works better than the clear ones, even with colored lights (painters use a white canvas).
I used the flexy type to get around the elevator just a little bit.
Old 03-24-2011, 04:19 AM   #9
CrimzonRider
Friends: (14)
lol. Just tried the clear ones, dont work too good, make sense to use white color more opaqueness.....lol
thanks again
cr
Old 03-24-2011, 04:20 AM   #10
Nitro Blast
Friends: (67)
Yeah, the biggest amazement was the landing gear. I can see the gear at night, and it really helps with orientation. I fly in the darkest conditions perfectly, even at good distances.
Old 03-24-2011, 05:16 AM   #11
CrimzonRider
Friends: (14)
Yeah, I bet you can see your gear pretty well, I really appreciate your help.
Not really a "night flyer", but I am getting braver every time I have an evening flight go a little long.
Before too long my rc experience will have a definite branch in it that will include night flying.
here a pic from about a month ago with the apprentice.....kinda fuzzy...sorry
ltr
cr
Old 03-24-2011, 06:20 PM   #12
Glacier Girl
Kamikaze Ace
1kW
Ditto Nitro's suggestion. White works better. And a trick.
Mount one in a straw and put a dab of hot glue in the other end. Or two, one mounted in each end, and use your glue gun to melt a hole in the center of the straw and shoot a bit of glue in.
The glue will gather and emit the light just like another LED.
Here's my old Slo-V, center "lamp" in each straw is nothing more then glue glowing.
Old 03-24-2011, 06:34 PM   #13
Glacier Girl
Kamikaze Ace
1kW
Hm, just thought of something for ya.
If you are dealing with single LED's. Take the white straw and cut off little collars from it to fit over your lamps. Dab of hot glue on the end and you'll have your diffused LED's.
When you want, slice the collar and pop off the glue, to remove em.
Old 03-24-2011, 06:50 PM   #14
CrimzonRider
Friends: (14)
That is EXACTLY what I am looking for!! I will do that for sure.
Thanks GG for the great tip.
Have a good one,
cr
Stick on lights on covering. gramps2161 Night Flying 27 01-03-2012 01:01 PM
Lights just saved my butt!! CrimzonRider Beginners 3 03-22-2011 02:09 AM
HZ Super Cub and LED lights - help needed. bcmedic16 Power Systems 9 02-04-2011 09:54 PM
For Sale 3D Foamy Lights TDisaster Airplanes - Electric For Sale & WTB 6 01-14-2011 04:23 AM
Swarm sale for lights any takers gramps2161 Night Flying 35 01-05-2011 03:17 AM
Page generated in 0.55228 seconds with 54 queries
