Old 03-22-2011, 08:45 PM   #1
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
Default When do you send a transmitter in for service?
Just curious, is there a time period when you should send in a transmitter for service? Specifically, my DX7. I've not had any problems with it, but I bought it used several years ago and don't know if there are updates that should be made, general service or tuning etc.
Tom
Grasshopper is offline
Old 03-22-2011, 08:48 PM   #2
Never even heard of a Tx being 'serviced' if there is no fault... What would they do?.. change the oil and filter
Old 03-22-2011, 08:54 PM   #3
Grasshopper
Friends: (52)
I didn't know if there were software/firmware updates that might get rid of some known "bug". Same as sending in receivers for the newest firmware.
Tom
Old 03-22-2011, 08:58 PM   #4
Having said that.. Tx's used to quite often suffer from corrosion of the battery wiring, specifically the black wires: http://bmfamid.co.uk/Docs/Black%20Wire%20Corrosion.pdf
i'm not sure if this is still the issue it once was?
You can check this yourself though, no need to send the Tx away.
Old 03-22-2011, 08:58 PM   #5
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
2kW  1kW
Friends: (11)
Have you checked the service bulletins?
http://www.spektrumrc.com/Products/S...ProdId=SPM2731
AMA #959089
NJSwede is offline
Old 03-22-2011, 09:00 PM   #6
Grasshopper
Friends: (52)
Thanks NJ,
I checked them recently. Mine doesn't even have that second sticker their picture points to.
Tom
Old 03-22-2011, 09:54 PM   #7
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
Send it in Tom, they do a very thorough check on them. We just got Mason's 9303 from Horizon with the repair completed as well as a complete systems check. I don't think it ever hurts to have the pro's look at it just to make sure.
President - Smoky Mountain Aero Club, Sevierville Tennessee
firemanbill is online now
Old 03-22-2011, 09:56 PM   #8
Originally Posted by Grasshopper View Post
Thanks NJ,
The photo is confusing.. The sticker with the 'PID' number is not on the back of the Tx, it's actually to be found under the battery.. remove the battery cover, lift out the battery and there it should be.
Old 03-22-2011, 10:07 PM   #9
Grasshopper
Friends: (52)
I did remove the battery to look. Not there.
Tom
Old 03-22-2011, 10:08 PM   #10
Grasshopper
Friends: (52)
I think I might just do that Bill. Better safe than sorry.
Tom
Old 03-22-2011, 10:26 PM   #11
Friends: (64)
Yeah and it sure gives you a renewed since of assurance in your equipment.
Old 03-22-2011, 11:12 PM   #12
Probably a false one IMHO.. In the main Electronic equipment tends to be very reliable but if an electronic component is going to fail it usually does so without warning and cant be detected 'in advance'. That's why you dont get stuff like TV's and DVD players 'serviced'.. There are no 'servicable components' within!
Most likely they will give it a clean, blow out any dust, and charge you $50 for the privalage... or maybe I'm just cynical (in fact there is no maybe about it, I am cynical)
But seriously.. I'm sure if Spektrum recommended that their gear was regularly 'serviced' they would tell you so in the manual... i've checked, it says nothing about 'servicing' other than in relation to fault repairs.
Old 03-23-2011, 02:25 AM   #13
swimmer
Sent my DX6i to Horizon to replace a broken trim switch. They replaced it and three others plus replaced both gimbals. All I read said I could replace it on my own but the PC board plugs were so tight I broke a wire removing one. Glad I sent it in and will from now on. Didn't take long and they made all repairs and checks FREE.
swimmer
swimmer is offline
Old 03-23-2011, 03:26 AM   #14
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
There is an age old maxim that starts with the words "If it ain't broke..."
Posted via Mobile Device
FlyWheel is offline
Old 03-23-2011, 04:39 AM   #15
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
View hillbillynamedpossum's Gallery5
Club: Is under the seat
Friends: (8)
If it aint broke, give it to an oakie....he'll find a way!
Possum
Founder, Chief Builder, Head Designer, an Lead Test Pilot of Possum Holler Aircraft Company. (A made up company that transforms styrofoam into packing peanuts, and balsa wood into toothpicks)
hillbillynamedpossum is offline
Old 03-23-2011, 07:42 AM   #16
baz49exe
baz49exe's Avatar
View baz49exe's Gallery15
Club: East Devon Radio Control Club
Outstanding Contributor Award  Scratchbuilders Award
Friends: (15)
I'm with the " If it ain't broke" brigade on this one. Up until I bought my 6i tx last year I was using my trusty old Futaba Challenger bought when I started flying R/C back in 1988. It was used full time up to the arrival of the 6i without any issues and is still in full working condition. Never had the back off it let alone a "service" I bet there are many stories like mine.
baz49exe is offline
Old 03-23-2011, 08:08 AM   #17
swimmer
swimmer,
That would be, i assume, because it was still under warantee (unlike the one that's subject of this thread)... Very good service none the less, but still not a reason to send your Tx in if there was no fault IMHO.
Old 03-23-2011, 04:32 PM   #18
swimmer
Default Out of Warranty DX6i Repaired FREE
swimmer,
You are incorrect but only because I did not mention the age of my DX6i in my original post. My DX6i is at least three to four years old and is way out of warranty. If I hadn't broken a trim switch I would not have sent it in. Replacement of the gimbals is something I did not think about but considering the yanking and cranking that this mechanical part of the tx is exposed to maybe they should be replaced every so often. As to why they repaired it free I don't have an answer only that Horizon has always provided excellent service whenever I needed anything. I gladly would have paid them for the repairs but I really appreciate them doing it for free.
By the way, broken trim switches are common on Spektrum transmitters as you can see for yourself by "searching" on the RCG forum. Horizon replaces them with a more "robust" component as they call it.
I agree. If it "ain't" broke leave it alone but mine was broken and Horizon repaired it to what I consider like new condition. Fixing it for free when I did not expect it was icing on the cake.
swimmer
swimmer is offline
Old 03-23-2011, 04:59 PM   #19
cbatters
cbatters's Avatar
Friends: (4)
Need to separate firmware updates (BIOS) as transmitters and protocols get more sophisticated from any non-sealed electrical components. Even the analog transmitters I have from 30 years ago that I have sealed potentiometer for varying electrical resistance. That said, the mechanical movement of all transmitters may benefit from a little lubrication on the gimbal movement once in a while or adjustment if you notice it binding.
So I agree... If it it ain't broke don't fix it!
Clint
Current - Ventura, HZ SuperCub-Freedom-Swift-AB3, PZ Typhoon, T-28 Trojan, Radian, AeroAce Biplane
Maiden - F-27C Stryker
10 years Ago - ElectroSoar 2M Glider, 2M Foam Glider, Mirage 550
Retired - Sky Fly, Red Hawk, Extreme, Challenger
cbatters is offline
Old 03-23-2011, 07:03 PM   #20
Octavius
Alien Surfer
Octavius's Avatar
Club: Renegade Air Force
Modern economy seems to make most electronics disposable by default. Not always but it's pretty common.
i.e. An item might cost $200, and minimum service is $99, plus shipping, plus if they find it needs labor and/or parts.
Octavius is offline
Old 03-23-2011, 07:36 PM   #21
krtf4u_corsair
Psalms 1:1-2
I'm not sure they would do much to really benefit ya, except for peace of mind of course.
krtf4u_corsair is offline
Old 03-23-2011, 07:58 PM   #22
You are incorrect but only because I did not mention the age of my DX6i in my original post. My DX6i is at least three to four years old and is way out of warranty. ......
That's outstanding service!.. Of course it could not be taken for granted that they would always do repairs for free, they arent a charitable institution after all.
Old 03-23-2011, 09:43 PM   #23
Friends: (64)
They just repaired my Son's 9303 for free too! Best customer support in the industry!
http://www.wattflyer.com/forums/showthread.php?t=60940
Old 03-24-2011, 03:30 AM   #24
swimmer
Forgot to mention, Horizon did not charge me return postage. The repair was made in the time quoted on their repair website.
swimmer
Allan
swimmer is offline
For Sale Cold weather Transmitter glove. Dannyrevs General RC items For Sale and WTB 4 08-31-2011 03:28 PM
is it necessary to remove battery pack out of transmitter?? Flysohigh Batteries & Chargers 12 02-11-2011 04:36 PM
J3 Cub not responding to the transmitter. CHEVELLESS Beginners 12 02-11-2011 04:40 AM
Sold Heli-Max walkera 6-Channel TX6024 2.4GHz Transmitter reduced electrodude71 Radio Equipment For Sale & WTB 1 01-14-2011 01:58 AM
Transmitter pack question - changing from 9.6V NiCd to 11.1VLipo DanWard Beginners 16 12-24-2010 12:16 AM
Page generated in 0.49699 seconds with 65 queries
