Old 03-23-2011, 01:54 AM   #1
Hose Man
Default Prop Selection
Wondering if someone can help please? I upgraded my Mini Cub with a 2712-12 brushless motor and a 10amp speed controller. Heads up recommended a 9x5 prop and it looks huge. I run a 430 and 600mah lipo's.
How do you tell if a prop is to small or to big in regards to burning up the ESC with out using the Motocalc ? Motocalc seams confusing to me. I see Heads up's prop sizing for the motor and the prop but it doesn't really explain how you come up with the AMP/Prop rating?
Any help would be great. The search function explained allot but it didn't explain how you come up with it??
Thanks again everyone
Richard
Hose Man is offline
Old 03-23-2011, 02:16 AM   #2
Tony A.
Foam Junkie
Tony A.'s Avatar
Club: "Team Deadstick" Mt. Elim RC, Lumberton, NC
A watt meter is a "must have" tool for electric flight in my opinion. With a quick 10 second run up you would know for certain exactly how many amps/watts you are pulling for a given prop/motor combo.
Hello, my name is Tony and I am an RC-aholic..
My Youtube
Tony A. is offline
Old 03-23-2011, 02:20 AM   #3
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
View CrimzonRider's Gallery12
Friends: (14)
Two Words............Watt Meter....get one. I just got mine two wks ago, when you start upgrading, you are flying in the dark without one.
have a good one
cr
CrimzonRider is offline
Old 03-23-2011, 02:21 AM   #4
CrimzonRider
Friends: (14)
lol tony you are a faster typist than I am......ez answer though
ltr
cr
top this.....lol(copy/paste is tha best)
2712-12 Specifications:
Weight (motor only) = 0.9 ounces (25 grams)
Diameter = 1.1 inch (28mm)
Total Length = 1.7 inch (43mm)
Shaft Length = 0.4 inch (10mm)
Shaft Diameter = 3mm
Voltage = 7 to 13
KV = 1300
Current = 10 amp max.
Propeller data for 3 cell Lipo batteries:
TheGWS EP 1060 produces about 18 ounces of thrust at 10 amps with a pitch speed of 34 mph. Avoid wide open throttle.
TheGWS EP 9047 produces about 16 ounces of thrust at 9.5 amps with a pitch speed of 29 mph.
The GWS EP 9050 produces about 17 ounces of thrust at 9 amps with a pitch speed of 34 mph. Excellent choice for power and speed.
The APC 9x6E produces about 17 ounces of thrust at 10 amps with a pitch speed of 36 mph. Avoid wide open throttle.
The APC 9x3.8SF produces about 18 ounces of thrust at 9.5 amps with a pitch speed of 25 mph.
The APC 8x3.8SF produces about 15 ounces of thrust at 8 amps with a pitch speed of 29 mph.
TheGWS EP 8040 produces about 15 ounces of thrust at 6 amps with a pitch speed of 35 mph.
TheGWS EP 8043 produces about 14.5 ounces of thrust at 6.5 amps with a pitch speed of 32 mph.
TheGWS EP 8060 produces about 14 ounces of thrust at 8.5 amps with a pitch speed of 40 mph.
TheGWS HD 8060 produces about 14 ounces of thrust at 8.5 amps with a pitch speed of 44 mph.
TheTP 8x6 produces about 13 ounces of thrust at 8.5 amps with a pitch speed of 40 mph.
TheMaster Airscrew 8x6 3-blade produces about 13 ounces of thrust at 9 amps with a pitch speed of 40 mph.
TheGWS EP 7035 produces about 9 ounces of thrust at 3.5 amps with a pitch speed of 37 mph.
TheMaster Airscrew 7x4 3-blade produces about 10 ounces of thrust at 7.5 amps with a pitch speed of 36 mph.
TheGWS EP 7060 produces about 12 ounces of thrust at 7 amps with a pitch speed of 45 mph.
TheTP 7x6 produces about 12 ounces of thrust at 6 amps with a pitch speed of 51 mph.
Propeller data for 2 cell Lipo batteries:
TheGWS EP 1147 produces about 12.5 ounces of thrust at 8 amps with a pitch speed of 18 mph.
TheGWS EP 1047 produces about 12 ounces of thrust at 7.5 amps with a pitch speed of 20 mph.
The GWS EP1060 produces about 12 ounces of thrust at 6.5 amps with a pitch speed of 28 mph.
TheGWS EP 9047 produces about 11 ounces of thrust at 5.5 amps with a pitch speed of 24 mph.
TheGWS EP 9050 produces about 10.5 ounces of thrust at 5 amps with a pitch speed of 28 mph.
The TP 9x6E produces about 11 ounces of thrust at 6 amps with a pitch speed of 29 mph.
TheGWS EP 9070 produces about 9.5 ounces of thrust at 7 amps with a pitch speed of 30 mph.
TheGWS EP 8040 produces about 8 ounces of thrust at 3.5 amps with a pitch speed of 26 mph.
TheGWS EP 8043 produces about 9 ounces of thrust at 4.5 amps with a pitch speed of 26 mph.
TheGWS EP 8060 produces about 8.5 ounces of thrust at 5.5 amps with a pitch speed of 32 mph.
TheGWS HD 8060 produces about 8.5 ounces of thrust at 5 amps with a pitch speed of 35 mph.
TheGWS EP 7060 produces about 7.5 ounces of thrust at 4.5 amps with a pitch speed of 36 mph.
The above data is a result of our own testing using fully charged Lipo batteries.
Old 03-23-2011, 02:22 AM   #5
gramps2361
gramps2361's Avatar
View gramps2361's Gallery9
Friends: (24)
If Jeff recommended the setup you will not have a problem. He tests his motors with different props for a safe combo with the recommend ESC he sells.
One vendor you can trust to post true facts and not inflated ones. Here is the setup that he psoted for that motor.
President RHFC
gramps2361 is offline
Old 03-23-2011, 03:12 AM   #6
Bomb Dropper
The Reaper!
Bomb Dropper's Avatar
Hose Man- I have the very same setup in MY mini cub and I use the GWS 8040 prop. Trust me, it's more than enough. You get the same performance that the 9050 gives you (only 2oz difference BUT less amp draw) AND longer flight time per battery pack because of that.
The mini cub only weighs around 7 to 8 ounces, so the difference between 15 and 17 ounces of thrust doesn't really make much difference in it's overall performance. The pitch speed is pretty much the same and you're drawing 3 less amps from your battery.
Just my $0.02 on that.
Bomb Dropper is offline
Old 03-23-2011, 01:25 PM   #7
Hose Man
Thank you everyone, I guess a wattmeter is in my future. I see that Jeff has one at Heads Up anybody used that one before??
BombDropper
What are your flight times with the similar set up? What prop sizes have you tried?
Richard
Hose Man is offline
Old 03-23-2011, 01:57 PM   #8
Bomb Dropper
The Reaper!
BombDropper
Richard
I haven't tried Jeff's watt meter, but I have the WattsUp Meter that is sold by many places. It's saved my butt more times than I would like to admit lol.
As for my flight times and prop choices, I used Jeff's web page as my bible. I've use the GWS 9050, 8040, 8060 and 7060 props, on various setups from the mini cub, to small profile 3-D foamies.
But sticking to the mini cubs needs, with the 9050 and a 640mAh lipo pack, I got about 7 to 8 minutes.. and with the 8040 on the same battery pack, my flight times increased to about 12 to 14 minutes. And the performance was almost identical because the plane is so light (at 7-8oz AUW).
I've used 1300mAh lipo packs with the same 8040 prop and flown my small profile 3-D Yak for over 25 minutes using this motor.
What does a motor's watt rating represent? starfire73 Beginners 40 03-24-2017 09:29 PM
Scratchbuild of an Extra RC Fan Chris Scratch and Kit Built Aircraft 36 07-31-2012 07:21 PM
Z8-3D Prop -- New invention revolutionizes 3D aircraft hovering performance z-8 3D Flying 227 03-13-2011 12:58 PM
Hacker A60 18L Prop? gdwyer General Electric Discussions 5 01-18-2011 04:36 AM
Page generated in 0.08902 seconds with 33 queries
