Old 03-24-2011, 12:57 AM   #1
zzlentz
zzlentz's Avatar
Club: Local Sports Bar
Default Ailerons For Flaps
Would it be feesible to turn ailerons into flaps on a 4 channel.
I know it sounds silly,but I can't fly 4's yet.And don't know my way around yet to install flaps.Couldn't I just turn one servo backwards so they work together?
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:00 AM   #2
JBoyd
completely green
Club: KORC
Depending on your radio, there should be a way to program in flaperons
JBoyd is offline
Old 03-24-2011, 01:12 AM   #3
zzlentz
zzlentz's Avatar
Ailerons will already be on their own channel.
Reason I ask,it might help me at landing a 3 channel.
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:14 AM   #4
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
View hillbillynamedpossum's Gallery5
Club: Is under the seat
Friends: (8)
I have one of these radios. http://store.polkshobby.com/scripts/...3001&conum=002 They are very cool, and will do everything but make the bed. On mine, to use flaperons you have to use a 6 channel Rx and 2 aileron servos. The servos go into chan 1 and 6 and then you mix in a switch to turn the "flaps" on. When the landing switch is flipped, both ailerons dial down about 50% to give you flaps, but you still have some aileron control. I guess when I get the Bipe 33 set up I could try to get some pics.
On a regular old 4 channel radio you can still use two aileron servos connected with a "Y" harness and it'll work just fine. You cant have flaperons on 4 channels.
My "Possum Holler Bipe", and "Mr Saturday Night Special" both use 4 channels with just one servo running the ailerons. I use the double sided control horn and one linkage on either side running to each aileron.
I hope this is as clear as mud
Possum
Founder, Chief Builder, Head Designer, an Lead Test Pilot of Possum Holler Aircraft Company. (A made up company that transforms styrofoam into packing peanuts, and balsa wood into toothpicks)
hillbillynamedpossum is offline
Old 03-24-2011, 01:15 AM   #5
Rode the short bus
Friends: (8)
Are your 3 channels rudder, throttle and elevator?
Possum
Old 03-24-2011, 01:18 AM   #6
FlyingBrick50
FlyingBrick50
FlyingBrick50's Avatar
Club: Gooney Birds Flo, SC
Friends: (13)
Arrow Flap option with no flaps
I run the flaperon option on my radio (JR 6 Channel), using an extra channel switch to activate them. When I flip the switch they the ailerons will drop down to the degree I preset. The ailerons still function as normal with the flaps down. You will need to have two servos operating your ailerons and have the extra plug-in on your receiver.
See post 4 for a better explanation
FlyingBrick50 is offline
Old 03-24-2011, 01:19 AM   #7
zzlentz
zzlentz's Avatar
It is! Why can't the ailerons work as flaps?I don't want the ailerons anyway.
Just make them go up and down in same direction like flaps.
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:20 AM   #8
Rode the short bus
Friends: (8)
That goes back to the radio. What radio are you using?
Possum
Old 03-24-2011, 01:21 AM   #9
zzlentz
zzlentz's Avatar
Possum
Rudder,Aileron,elevator,Throttle.
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:27 AM   #10
zzlentz
zzlentz's Avatar
Let me start over:
I can't fly a 4 ch. plane as yet.
BUT!! If I get a 4 ch plane,could I set the ailerons as flaps,then have Rudder,elevator,flaps,throttle?
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:29 AM   #11
Rode the short bus
Friends: (8)
The short answer is yes, with the right radio and reciever.
Possum
Old 03-24-2011, 01:33 AM   #12
zzlentz
zzlentz's Avatar
Possum
That's the part I don't understand. It will be a 4 channel radio with ailerons already in place.Why wouldn't those same ailerons work as flaps?
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:37 AM   #13
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (169)
Hi
You would need a decent computer TX, Dx6i, DX 7, etc with mixing functions
The TXs included with most RTF packages are mostly lower end without the functions needed to make that type of adjustment
Take care dear friend
Yours Hank
kenchiroalpha is offline
Old 03-24-2011, 01:44 AM   #14
zzlentz
zzlentz's Avatar
Originally Posted by kenchiroalpha View Post
Hi
Yours Hank
So then,I can't just turn one of the aileron servos' around and make ailerons go down and up together on the channel they are now on?
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 01:48 AM   #15
kenchiroalpha
Friends: (169)
Hi
I would not recomend that course of action, imho it would make the aircraft quite tricky to fly properly
Yours Hank
Old 03-24-2011, 01:52 AM   #16
zzlentz
zzlentz's Avatar
I surrender. Just a thought.
Would save on my crash landings though.
"ZZ Rider"
zzlentz is offline
Old 03-24-2011, 02:00 AM   #17
Rode the short bus
Friends: (8)
Another thing to remember is when the flaps go down the elevator needs to go down too.
Possum
Old 03-24-2011, 02:10 AM   #18
C140
Tailwheels Fly Better
C140's Avatar
In theory, you're correct; if you flipped a servo, you could get both ailerons to move the same. If they are full-span, they'd probably work fine as flaps. The problem I see is actuating the flaps with a four-channel radio. Holding a stick to the side to deploy flaps while simultaneously trying to land the plane seems like it would be annoying at best. If there was a channel controlled by a pot or toggle available, you might have something, although I've never flown a rudder-elevator-throttle ship with flaps.
-Mankind has a perfect record in aviation. We've never left anyone up there.
C140 is offline
Old 03-24-2011, 02:42 AM   #19
CrimzonRider
Fastest PropHead Crasher
CrimzonRider's Avatar
View CrimzonRider's Gallery12
Friends: (14)
Been flying and landing with flaps for a couple weeks now, as a beginner, IMO flaps have become kinda LOVE/HATE relationship.
I set the flaps up at about 15 degrees, and the first time they come on, she dang near goes straight up. Needed like 35% down elev. Soo much lift, it was crazy.
I am getting more used to them now, but when its really like 10 to 15 mph I dont even use them. I only use them for dead calm conditions. Honestly, 90% of the landings I have done and in the future I dont even use them.
In my "humble" opinion, flaps are mainly for EDF and jets, and other "fast landing" a/c in the rc world. They are cool to watch though for scale.
ltr
cr
CrimzonRider is offline
Old 03-24-2011, 07:55 AM   #20
I suppose my first question is 'why do you think you dont want ailerons?'
The likely problem is planes designed for ailerons usually dont have dihedral and a plane without dihedral usually wont turn very well, if at all, on rudder only. All that usually happens if you add rudder to a flat wing plane is the plane 'skids' sideways the direction of travel doesnt change, some planes may eventually turn but only in a very sluggish way. Most aileron equiped planes NEED ailerons to turn, ailerons are your primary turn control.
On most models flaps are unessasary, just use the ailerons.
Old 03-25-2011, 01:13 AM   #21
CBN FVR
Default Yes
Hi guys iI am also new to the forums . I am currently building a revised version of a free flight model that I ended up installing r/c equipment into. It flew soo good I decided to redesign it to be build r/c. I asked a local modeler about flaps as a four channel. The answer is yes the alerons can be made to use as flaps, Just not with a four channel only radio sys. You need a 6th channel . At least my Tx. says flaps ch 6 . All I need to do is change my burg 4 to the 7 I have Oh and add the servo in the wing directly on top of the c.o.g. and cut it. I currently built the wing without it though. I will see how it flys first i guess. Btw the idea for the model started out based off of the "Light weight zepher" plan scanned from 1936 air trials. Fast, easy to build light weight plane to make r/c. Very tame. Some might say floater ? It is covered with tissue of course.
CBN FVR is offline
Old 03-25-2011, 01:16 AM   #22
CBN FVR
Maybe will learn how to post pics on here
CBN FVR is offline
Old 03-25-2011, 01:39 AM   #23
As others have indicated, higher powered transmitters have a mix called "Flapperons", which allows the ailerons to work as aileron/flaps. But, in my experience that doesn't work to well unless your ailerons have a fair amount of surface area. IMHO, Don't think that making a strip aileron into flaps would make a lot of difference.
I've got models with both ailerons AND separate flaps, and models with ailerons/flaps.
You do need to have a transmitter that has a flap switch. Not a self centering stick for flaps, as that would really be hard to work with.
Old 03-25-2011, 01:53 AM   #24
CrimzonRider
Friends: (14)
To post pics just click on the paperclip in the "reply" window that pops up and upload. I think you have to have 5 or 10 posts.
Welcome to Wattflyers
have a good one
cr
Old 03-25-2011, 01:54 AM   #25
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery45
Frankenstein Build Contest Award  100mph Speed Demon  3kW  1kW
Friends: (67)
Not to get too far off topic, but you can also use flaperons as 'spoilerons' in a glider setup, and they are very effective in slowing and reducing lift.
Electricity... It's not just for light bulbs anymore.
GoProfessional Cases industry grade protection for your gear
Dinogy Lipos professional grade energy
Project Globetrotter Participant 7/09
Wings Across America Participant 6/10
Nitro Blast is offline
$69 RTF Exceed RC 3-Channel J3 Piper Cub, yep it flys ! phillipmorris Beginners 197 07-23-2011 03:11 AM
Mixing Flaps and Ailerons when you only have ailerons? Zocane Scratch and Kit Built Aircraft 19 03-11-2011 02:21 AM
2 channels for ailerons, 2 for flaps? Alaska General Electric Discussions 8 02-02-2011 02:33 AM
Page generated in 0.56905 seconds with 69 queries
