Old 03-25-2011, 05:33 AM   #1
CBN FVR
Default 1930's style cabin plane scratch built for elec r/c.
Well here it is, this is the second build of basically the same plane that i also scratch built as rubber f/f and later converted to r/c with HUGE success. So Decided my plan was worth upgrading to be built as r/c from the beginning. Its almost done, need to trim the landing gear ,mount wheels and instal motor mount tube. It will be covered with Jap tissue
CBN FVR is offline
Old 03-25-2011, 05:41 AM   #2
CBN FVR
Crash proof landing gear. Torsion bar/ carbon rod construction.
CBN FVR is offline
Old 03-26-2011, 02:09 AM   #3
CBN FVR
CBN FVR is offline
Old 03-27-2011, 06:22 PM   #4
gcedillo
I love the simple elegant lines, you should post plans, Its a really nice plane.
Congrats
Evaristo
gcedillo is offline
Old 03-27-2011, 06:44 PM   #5
CBN FVR
Congrats
Evaristo
Thank you. I also find it quite pleasing to the eye
I posted a picture of the plans in the post above yours. If you have questions about size or demensions I would be happy to answer them
CBN FVR is offline
Old 03-27-2011, 10:18 PM   #6
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (169)
Attachment 145341
Attachment 145342
Attachment 145343
Attachment 145344
Attachment 145345
Attachment 145346
Attachment 145347
Hi
Pleased to meet you
Shes a looker thats for sure
Cant wait to see her all dressed up
Thanks ever so much for sharing her with us
Take care
Yours Hank
kenchiroalpha is offline
Old 03-27-2011, 10:35 PM   #7
CBN FVR
Thanks for the warm welcome to the forum guys.
I will post some more pictures as progress continues. I have some nice features planned for the looks
Thanks again
CBN FVR is offline
Old 03-27-2011, 10:41 PM   #8
kenchiroalpha
Friends: (169)
Talking
Thanks again
Hi
Your most welcome
Awaiting your next update with great anticipation
Take care
Yours Hank
Old 03-28-2011, 01:51 PM   #9
pd1
Still Learning
pd1's Avatar
View pd1's Gallery69
Club: Cape Ann RC Model Club
Friends: (53)
Nice job.
I've done a couple of old rubber powered plane conversions.
Would you believe they tend to come out nose heavy?
Glad to see you're mounting equipment before covering, you won't get caught like I did.
Paul
pd1 is offline
Old 03-29-2011, 01:36 AM   #10
CBN FVR
Thanks Paul,
The only model I ever built that I added weight to the tail to make it balance like I wanted was a peck polimers "flying aces" moth. It was a rubber powered model that one day flew away I had countless timed flights over 5min. With max turns wound in and then some more ,That model will climb in a steep,tight and fast left hand spiral and go VERY high. I enjoyed soo much to watch it come back down again I always balance and "finish " the model then cover it last. You guys got me motivated to go back to work If I could only decide what color combos. Thinking maybe a three tone.
CBN FVR is offline
Old 03-29-2011, 07:17 AM   #11
CBN FVR
White motor tube will be replaced w/carbon tube.(mock up)Then top and sides around tube sheeted with 1/16.
ESC mounted, circuit board will be visable with window over it
CBN FVR is offline
Old 03-29-2011, 07:21 AM   #12
CBN FVR
Reciecver mounted No more scotch tape.
CBN FVR is offline
Old 04-07-2011, 02:43 AM   #13
CBN FVR
The ups lady came to my house today
Now I can finish Flight test soon
CBN FVR is offline
Old 04-07-2011, 02:44 AM   #14
CBN FVR
CBN FVR is offline
Old 04-07-2011, 04:20 AM   #15
CBN FVR
CBN FVR is offline
Old 04-07-2011, 07:12 AM   #16
CBN FVR
Windows on and starting to cover
CBN FVR is offline
Old 04-07-2011, 08:48 AM   #17
CBN FVR
CBN FVR is offline
Old 04-08-2011, 02:52 AM   #18
CBN FVR
Landing gear done. Now time to make some wheels
CBN FVR is offline
Old 04-08-2011, 04:06 AM   #19
CBN FVR
CBN FVR is offline
Old 04-08-2011, 04:26 AM   #20
CBN FVR
CBN FVR is offline
Old 04-08-2011, 04:36 AM   #21
CBN FVR
CBN FVR is offline
Old 04-08-2011, 05:46 AM   #22
CBN FVR
CBN FVR is offline
Old 04-08-2011, 02:01 PM   #23
pd1
Still Learning
pd1's Avatar
Friends: (53)
Are those O-Rings for the wheels?
I ask because I saw someone using neoprene tubing for the wheel, and was wondering if yours were different.
I like the looks of them.
Paul
pd1 is offline
Old 04-08-2011, 09:25 PM   #24
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
Originally Posted by pd1 View Post
Nice job.
<snip>
Paul
That's because you're replacing a lightweight rubber band that's been stretched along the entire length of the fuselage with a heavier motor that's all packed up into the nose.
Posted via Mobile Device
FlyWheel is offline
Old 04-09-2011, 01:50 AM   #25
CBN FVR
Paul
Thanks Paul, yea they are o-rings. The wheels are 2" diameter. Made of 1/8" soft balsa. Lamiated 3/8" thick at the hub sanded to 1/8" @ the o-ring. Really easy to make once you have a system down. They weigh 5grams each.
CBN FVR is offline
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Scratch Built FPV Plane aviatordave Aerial Photography 56 12-10-2011 11:14 PM
Page generated in 0.47138 seconds with 69 queries
