Old 03-30-2011, 06:32 PM   #1
sgillmore
Default SIG Somethin' Extra Conversion
I'm planning to convert SIG Somethin' Extra to electric and hoping to use a setup that I already own. The plane should come about around 4.5 - 5 lbs AUW and is a general sport flyer. Hovering is not a goal. I'm pretty flexible on flight time as long as it's over 5 min.
Here's the planned setup:
Rimfire .46
CC Phoenix 80
Koolflight Systems UBEC
A123, 2300mAh 6S1P
I have a watt meter and expect to test many props before I'm finished, but I'm thinking that an APC 13x6.5E would be a good starting point.
I'd appreciate any constructive comments or recommendations on this setup.
Thanks!
sgillmore is offline
Old 03-30-2011, 06:36 PM   #2
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (169)
Talking
Hi
Pleased to meet you
Very good info here
http://www.rcgroups.com/forums/showthread.php?t=544821
Hope this is of help
Take care
Yours Hank
kenchiroalpha is offline
Old 03-30-2011, 06:58 PM   #3
sgillmore
Originally Posted by kenchiroalpha View Post
Hi
Pleased to meet you
Very good info here
Take care
Yours Hank
Thanks for the link. BTW, great avatar--R. Lee Ermey is "The Man".
Old 03-30-2011, 07:12 PM   #4
kenchiroalpha
Friends: (169)
Talking
Hi
Your most welcome
I agree 110%
Take care
Yours Hank
Old 03-31-2011, 12:27 AM   #5
Dr Kiwi
Well, a Rimfire .46 is 268g..... and the suggested ESC on 6s is 60A.
The first rule of thumb suggests watts = cubic inches x 2000... thus 920W max.
The second rule of thumb (3W/g) suggests 800W max.
Motocalc suggests that using a 13x6.5 (max recommended for 6s is 11x5) you'll draw
>63A and 1360W... welcome to the world of immersion heaters.
Motor: Great Planes Rimfire 42-60-800 (#4725); 800rpm/V; 4.6A no-load; 0.017 Ohms.
Battery: Thunder Power TP4400 (G4 ProPower 45C) (45C); 6 cells; 4400mAh @ 3.7V; 0.002 Ohms/cell.
Speed Control: Castle Creations Phoenix 80; 0.001 Ohms; High rate.
Drive System: Direct; 13x6.5 (Pconst=1.17; Tconst=1) direct drive.
Airframe: Anything you want.
Motor Amps = 63.7
Motor Volts = 21.4
Input (W) = 1361.5
Prop RPM = 9570
Thrust (oz) = 121.7
PSpd (mph) = 58.9
Dr Kiwi is offline
Old 04-01-2011, 06:29 AM   #6
sgillmore
Motor Amps = 63.7
Motor Volts = 21.4
Input (W) = 1361.5
Prop RPM = 9570
Thrust (oz) = 121.7
PSpd (mph) = 58.9
I'm using A123 cells, not LiPOs. They're lower voltage and I'm not getting anywhere 1300 watts on MotoCalc with the 13x6.5.
Old 04-01-2011, 06:45 AM   #7
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
If your using A123 cells, then a 13" prop is probably safe for a first test but it will likely still be pushing that motor. Be prepared to prop down.
Those are not the most efficient motors so I would stay on the lower end of the power range Dr kiwi suggested above and use throttle management.
I think I need a signature.
Larry
Larry3215 is offline
Old 04-01-2011, 03:37 PM   #8
sgillmore
Yeah, I'll do some static testing of course and try to keep an eye on things. I don't fly a plane like this very hard. Just cruise it around with some basic aerobatics thrown in. I'll only be full throttle for short vertical up-lines. I suspect a 12x6 or a 12x8 might be the ticket.
I had a Somethin' Extra converted to electric a couple years ago with an AXI 4120 and CC Phoenix 60. I was flying it on a 4S1P 4000mAh Li-PO with a APC 13x6.5E. It performed really well. It was a beautiful, kit-built SE that I wish I'd have held on to. I sold it at a fun fly and the guy crashed it that night.
I have this setup hanging on the wall and have an opportunity to acquire another SE so I thought I'd give it a try.
I fly with a Hitec Aurora and have a full sensor station on order that will allow me track RPM, motor & ESC temps and current while in flight. I ordered it for another, much larger project (B.USA 1/4-scale FOKKER D.VIII). However, I might slip the sensor station in the Somethin' Extra for some test flights to get everything worked out.
Thanks.
cox 20" Extra 300 EP RTF A_Smith ParkFlyers 12 02-26-2013 07:40 PM
Scratchbuild of an Extra RC Fan Chris Scratch and Kit Built Aircraft 36 07-31-2012 07:21 PM
Carl Goldberg (???) Giant Extra 330 Electric Conversion kyleservicetech Sport Planes (Formerly I/C & Gas Conversion) 12 04-06-2011 10:46 PM
SIG 1/4 Clipped Wing Cub Electric Conversion Question constantmotion Power Systems 1 03-06-2011 02:49 AM
Futaba T9CAP to Spectrum Conversion query Skyydogg Beginners 1 02-24-2011 02:33 AM
Page generated in 0.13489 seconds with 33 queries
