Old 04-02-2011, 08:27 PM   #1
holeinhead
Default Ultra Micro P-51 - Reverse Polarity - What would happen
Theoretically speaking, what would happen if the battery was connected to a Parkzone Ultra Micro P-51?
I bought one used, and I'm trying to determine why something bad happened, and this is one of the possibilities.
Thanks!
holeinhead is offline
Old 04-02-2011, 08:38 PM   #2
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (168)
Hi
Welcome aboard
Im pleased to meet you
To answer you theoretical question it could possibly damage the ESC
If you tell us the problems your experiancing we could help you out better
Take care
Yours Hank
kenchiroalpha is offline
Old 04-02-2011, 09:14 PM   #3
holeinhead
Sorry to re register, but I somehow got instabanned as a spammer with that one post with no warning. I'm sure it's a simple mistake, but I was hoping to get an answer so I know what was the source of the problem so that I can get this fixed when I go to the hobby shop tomorrow. I've sent a message already asking what I did wrong to get permabanned, but I don't know how long that will take.
UPDATE: Mods were quick to fix the situation. As I thought, all just a misunderstanding.
Basically, I plugged my battery in after a shop re did the plug the battery connects to (it's a different plug than stock), and the motor fired up all of a sudden. I had been messing with the settings on my transmitter, so I thought I screwed up the trim or something. But then it stopped, and the battery I was still holding onto got hot. In my attempt to disconnect it, I ended up pulling the wires out which had melted all of the insulation. There was also a small hole burned into the left side of the fuselage.
My thoughts are either the shop put the connector back in the wrong way when they re did it, causing a reverse polarity connection when I plugged it in, or the wiring inside the fuselage was bad and a short circuit occured.
I appreciate any help! Thanks!
Old 04-02-2011, 09:35 PM   #4
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery38
100mph Speed Demon  3kW  1kW  WAA-08 Pilot
Friends: (65)
Honestly, that problem sounds like something that should go right back to the shop that did the work.
If they screwed up, you cant prove anything if you 'fix' it. Melting anything in a model is not good. Having to yank wires on a 'hot' anything is also not good.
We could guess and speculate all day, but you are better off looking the retailer in the eye and asking them to demonstrate how it is supposed to work.
Normally...... any shop that does anything to a model, will demonstrate it functioning before you leave. If they did not, hopefully you will have some recourse.
Nitro Blast is offline
Old 04-02-2011, 10:27 PM   #5
holeinhead
Thanks. Yeah, just depending on what actually happened changes who I should hold accountable. If it's bad wiring on the inside, I would go to the guy who sold me the plane since I made no changes to the internal wiring. Otherwise it would be the shop if they redid the connector the wrong way.
We'll see tomorrow I guess. Thanks!
Old 04-04-2011, 02:37 AM   #6
holeinhead
Turned out to be the shops fault. They checked and confirmed the plug was on wrong. At least I got a new one to set things right. So I'm good to go.
Old 04-04-2011, 02:49 AM   #7
Nitro Blast
Friends: (65)
<----- is here to help.
Glad it worked out, enjoy the flights!
Ultra Micro planes gear in the 250 size planes wattman WWI Era 4 03-31-2011 04:12 PM
Warning: ParkZone Ultra Micro T-28D elevator sticks NJSwede Indoor & Micro Electric Planes 4 03-07-2011 02:11 AM
Ultra micro Mosi! flyboy_fx General Electric Discussions 2 02-14-2011 10:03 PM
Sold Futaba Ultra Micro Flight Pack R124F RX and three S3110M Servos All American Radio Equipment For Sale & WTB 0 07-02-2010 04:47 PM
Page generated in 0.20287 seconds with 31 queries
