Old 04-06-2011, 03:14 AM   #1
cncfoam
cncfoam's Avatar
Default $100 scratch build contest-Extra pro
I will throw my hat in. Lets see if I actually finish this.
I started with plans from a Extra 300LX 35%.
Traced out the profile of the fuse, wings, planform.
Scaled it down so that the wing span will be 40"
picture of what I traced.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-06-2011, 03:36 AM   #2
cncfoam
cncfoam's Avatar
Default plane
The plane this is based on is the one in my avatar.
This is the 35% scale Hurley Extra 300LX.
It will be a profile fuse with full foam wings
and coroplast tail and stab.
Parts so far.
3- servos 9.99 each $29.97
1- motor 2409-12T from Heads up. bought a long time ago. $11.95
1- battery 3S 1800mah 30c $22.95
APC 8-4E Prop $2.37
Prop Adapter $2.50
a sheet of coroplast 24"x36" $4.80
So far $74.54
dont know if I will make the $100 mark.
picture is of the layout on the 24"x36" coroplast sheet.
the fuse sides are obvious.
the 4 sided shape with the "X" on it will be the LE of the horizontal stab. after you fold it in half.
the other pieces that look like a shirt will be the rudder and elevators
after you fold them in half. this will make sense when I actuall
cut them out.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-06-2011, 03:47 AM   #3
cncfoam
cncfoam's Avatar
Default 3D
Here is a 3D view.
some details that I will point out.
first- you can see the main wing is transparent and you can see
2 carbon fibre-.25" rods going through the wing.
from tip to tip.
I will cut out the 2 holes in the wings.
I will also cut the 2 holes through the fuse.
I will glue the rods into the wings and the roots of
the wings to the sides of the fuse.
2nd- since the fuse is a thick foam profile with coroplast sides,
I will cut out the tail section out of the fuse
then I will slide the tail assembly into the cutouts.
Again this will make sense when the construction starts.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-06-2011, 03:49 AM   #4
View CHELLIE's Gallery13
Friends: (281)
Thats is going to be a very nice plane Can I do the Maiden flight on it Just kidding, Take care, Chellie
Old 04-06-2011, 03:53 AM   #5
cncfoam
cncfoam's Avatar
Default Yes
If you are in the Mpls, MN area.
you can maiden it for sure.
In fact, if there is anyone in the area that would like
to fly it, let me know.
But, I have to finish it first.
I am trying to make it as simple as possible so that I
will finish it.
I am going to try and cut out the coroplast tomorrow night, or at
least get the layout on the board.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-06-2011, 03:57 AM   #6
Friends: (281)
will finish it.
Here is an Idea make 2 fuselage halfs, and make it a full body should not take that much longer to do that, and you can hide all the electronics that way, just my 2 cents worth, Take care, Chellie
Old 04-06-2011, 04:05 AM   #7
cncfoam
cncfoam's Avatar
Default great minds
Great minds think alike.
My plan was to sandwich an .8" thick foam
between the coroplast sides.
the servos and the battery are .8" thick.
I will cut them out of the foam and hide them with
the coro sides.
details to come
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-06-2011, 04:15 AM   #8
Friends: (281)
the coro sides.
details to come
Ok Great I thought you were going to make a profile plane by the drawing
Old 04-06-2011, 05:19 AM   #9
jungmann1
electron deficient
Sounds like it will be bullet proof! You going to shoot it with paint balls just for fun?
jungmann1 is offline
Old 04-07-2011, 03:37 AM   #10
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
View hillbillynamedpossum's Gallery5
Club: Is under the seat
Friends: (8)
welcome to the contest!
Possum
Founder, Chief Builder, Head Designer, an Lead Test Pilot of Possum Holler Aircraft Company. (A made up company that transforms styrofoam into packing peanuts, and balsa wood into toothpicks)
hillbillynamedpossum is offline
Old 04-07-2011, 03:49 AM   #11
Stevephoon
Stevephoon's Avatar
View Stevephoon's Gallery40
Welcome to the fun!! What a cool design as well. Coroplast is the plastic stuff that looks like corrugated cardboard, right? This will be interesting.
Stevens AeroModel Daddy-O 525, Groove G-480
Mountain Models Firestorm, P-51, EVA Sport/Bipe, Dandy/Dandy Sport
Pocket Rocket, Stevephoon 3D, SSPR - Steve's Simple Pylon Racer
DJAerotech Chrysalis 2M-E Sailplane, Misc Foamy Combat Planes.....
Stevephoon is offline
Old 04-07-2011, 03:58 AM   #12
cncfoam
cncfoam's Avatar
Default progress
tonights progress
Pretty simple stuff, but I will tell all the details.
If you look at my post #2, you will see the piece that I cut out tonight.
this is the main part of the horizontal stab. the elevators will attach
to this stab. And the verticle tail will slide into the slot.
the process... I draw it up in a CAD program, print it out.
tape it to the coroplast, cut it out of the coroplast.
pic #1 the piece cut out.
pic #2 this is the cut out piece folded in half( look at post #3, you will see this piece,( front of horz stab))
pic#3 on the coroplast pieces, some of the pieces will
have a rounded leading edge, the pieces that are not rounded,
I will use packing tape to make a leading edge.
pic #4 This is how I made the LE, I cut out the corogation on the coroplast, then folded it over on itself. (see pic #3)
As always, things will make sense when more is done.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-07-2011, 04:09 AM   #13
cncfoam
cncfoam's Avatar
Default pics
pics didnt load-cut and pasted last post.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-07-2011, 04:16 AM   #14
cncfoam
cncfoam's Avatar
Default hinges
I forgot to say, when the coroplast pieces get folded in half
and glued, I will sandwich some hinges in between the coroplast sheets.
Therefore the hinges will be centered on the wing.
details will show up in later posts
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-08-2011, 02:43 AM   #15
cncfoam
cncfoam's Avatar
Default elevator
I cut out one side of the elevator.
using the same technique of cutting out the piece
and folding it in half.
the left side is a piece of paper and the right side is the
coroplast folded in half, along with the main part
So this is what the horizontal stab and elevator looks like
when assembled.
The vertical fin will have a slot in it and it will
slide into this slot on the horizontal stab.
second picture is of hinge located inbetween the folded halves
of the coroplast.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-09-2011, 02:57 AM   #16
cncfoam
cncfoam's Avatar
Default tail section
Worked on all the tail sections tonight.
Cut out all the pieces, folded them in half and taped
them with scotch tape. (temporary)
Pic #1 both pieces taped together
Pic #2 Tail section assembled.
As you can see, slide the 2 pieces together at the slots,
this creates your tail section. This assembly will
slide into the slots that will be created at the tail
end of the profile fuse. If you look at my Post #3,
the 3D picture, You can see how this assembly
slides into the slots created on the fuse.
All the rough edges will be cleaned up and wrapped
with colored packing tape.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-09-2011, 03:10 AM   #17
Friends: (281)
Your plane is looking great Do you want to Race them after there done LOL, Take care & Have Fun, Chellie
Old 04-09-2011, 04:30 PM   #18
cncfoam
cncfoam's Avatar
Default fuse
Cut out one side of the coroplast fuse sides.
I left my paper template on the fuse side, so later I can punch
the 2 holes for 2 CF tubes, for wing mounting.
pic #1 the fuse side cut out with paper template still on
pic#2 close up of paper template and holes to be punched later
pic#3 shows how the tail section slides into slot at rear of plane
I will cut one more fuse side exactly the same, then I will
use my cnc foam cutter to cut out the .8" foam core and sandwich
the foam core with the two coroplast sides.
Notice the product placement, I expect a call from them for
my multi-million dollar endorsment contract.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-10-2011, 05:00 PM   #19
cncfoam
cncfoam's Avatar
Default Progress
I wrapped the tail sections with some color.
Not super happy with the looks, but is fuctional.
I wrapped all the exposed edges of the coroplast.
I also put hinges on the V tail. just glue the hinges
in between the coroplast halves after folding, this centers
hinges automatically.
pic #1 this is how I wrapped the LE .
I cut the coroplast at an angle on each mating edge to form a "V".
laid a plastic straw ( thank you McDonalds.) and wrapped it with
colored packing tape. creates a nice LE on the coroplast wings.
pic #2 pics of the tail sections, V tail has hinges,
you can also see the LE wrapped
thats it for now.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
Old 04-10-2011, 05:09 PM   #20
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Friends: (168)
Hi Eric
Pleased to make your acquaintance
She looks great so far
Looking forward to seeing more
Take care
Yours Hank
kenchiroalpha is offline
Old 04-10-2011, 05:12 PM   #21
kenchiroalpha
Friends: (168)
Talking
Hi Steve
Check out this
http://www.spadtothebone.com/index.htm
Take care dear friend
Yours Hank
Old 04-17-2011, 05:49 AM   #22
Friends: (281)
Your plane is looking great, I always wanted to try to make a plane from that Coroplast, and i am learning a lot from your build thread, Take care and have fun, Chellie
Old 04-17-2011, 01:54 PM   #23
Rode the short bus
Friends: (8)
Son, Just wait till next election season! Ill be making a few coroplast planes my self.
Possum
Old 04-17-2011, 02:10 PM   #24
offtom
Megans Servant
offtom's Avatar
View offtom's Gallery6
Club: Maggie Mae's Menagerie
WAA-08 Pilot
Possum
They've gone cheap on us out here. During election season it used to be easy to find the stuff. Now they use a cheap sheet of plastic instead of the coroplast.
Cheesy poofs are what Yankees get when they eat Southen Food!! bub, steve
offtom is offline
Old 04-17-2011, 07:46 PM   #25
cncfoam
cncfoam's Avatar
Default a little bit done
Havent done alot lately, Doing taxes and I am also doing a 24 foot airfoil for a gentleman out in Oregon. Its for his land yacht.
I bought a set of landing gear for about $5.00 a my LHS.
I think it was made for a cub.
I will make it work when I get time. I will glue some
hard points in the foam.
Eric Zimmerman
AKA EZ or cncfoam
cncfoam is offline
$100 Scratch Build Contest: Simple Pylon Racer Stevephoon Scratch and Kit Built Aircraft 57 01-19-2012 01:27 AM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 100 01-07-2012 11:12 PM
$100 Scratch Build Contest - Blohm und Voss BV 141 offtom Scratch and Kit Built Aircraft 17 05-11-2011 01:40 AM
$100 Scratch Build Contest: X-41 DeltaStorm HeliScRapYard Scratch and Kit Built Aircraft 43 05-11-2011 12:31 AM
DISCUSSION OF $100 Scratch Build Contest hillbillynamedpossum Scratch and Kit Built Aircraft 44 03-12-2011 04:31 AM
Page generated in 1.67633 seconds with 86 queries
