Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Micro Sized Electric Helicopters > E-Flite Helicopters
Old 04-13-2011, 05:59 PM   #1
calldaffer
just stop crashing!!
calldaffer's Avatar
Unhappy 120 SR has lost forward flight capabilities
Alright I need help, last night was the first time I flew the 120 in the gym and things got "a little crazy" and I had a couple crashes as I expected I would. Anyways I noticed that while hovering the heli around that it kept drifting backwards so I landed it and was moving the right sticks around and now when I try to push it forwards the helicopter does not respond. I have left, right, and backwards responce to the transmitter stick but nothing when I push it forward. Every now and then I'll get an intermittence responce to it but for the most part nothing now. I'm pretty much clueless as to what to begin checking on the helicopter which is why I'm asking ya'll for help
I tried unplugging the battery and restablishing a connection to the transmitter and that didn't work so I figure there is something broke but I don't know where to begin looking. Any ideas?
calldaffer is offline
Old 04-13-2011, 07:15 PM   #2
constantCrash
prefectionist
constantCrash's Avatar
Send a message via AIM to constantCrash
Check your swash plate. make sure the part that connects to the servos is still connected fully to the part that connects to the blades. My mSR splits appart ALL THE TIME.
I wanna be a pirate. Arrrrr
AMA - 885997
constantCrash is offline
Old 04-13-2011, 11:25 PM   #3
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (168)
Hi
I agree check all the swash hookups first
If they are all on correctly then you may have a problem with the 5in1 Unit
Thats the only down fall i see with these UM blades that everything is integrated into one unt and when they fail you must replace the whole unit good for the manufacterer, bad for the owner of the heli
Take care dear friend
Yours Hank
kenchiroalpha is offline
Old 05-05-2011, 08:03 PM   #4
calldaffer
calldaffer's Avatar
Man, it's been a minute since I've been on here. Life has gotten in the way. I did finally get around to taking a look at my 120 last night and I was very pleased to see that the hookups that connect the ball joints on the swashplate had popped loose. So once I popped it back on I had full flight capabilities again. Now the only damage to my 120 is the canopy is cracked in a few places. Much less expensive fix than replacing the 5in1 unit. Thanks for the tips ya'll.
Old 05-05-2011, 10:06 PM   #5
kenchiroalpha
Friends: (168)
Hi Chris
Your most welcome
So very happy it was an easy fix
Yours Hank
Old 05-11-2011, 09:44 PM   #6
calldaffer
calldaffer's Avatar
can anyone explain this....so I took my 120 back up to the gym to fly it again. Keep in mind that I hadn't flown it since I posted this thread about it losing forward flight. The gym is the only area big enough for me to fly in and it's been to windy outside to fly since a month ago. Anyways, I thought I had fixed the issue by popping the hookups back onto balljoints but I'm still having issues.
When I put the helicopter into "easy mode" the forward flight capabilities will come and go now. Sometimes the helicopter will fly forward just fine and other times it won't move forward at all. But if I take it out of easy mod it works just fine. I think I have gotten to the point where I can control it without using easy mode but I don't understand why I would have intermittent forward control in easy mode. Has anyone else experienced this problem?
Old 05-15-2011, 12:26 AM   #7
dacaur
dacaur's Avatar
easy mode on the TX or the swash?
If you are talking about high/low rates on the TX, I would suspect a problem with the tx itself..... if its not the TX, maybe the part that poped off before is cracked, or the servo itself could be damagad, the servos actualy are replacable, at least the servo mechanics are, its around $10-15 I think...
dacaur is offline
Old 05-15-2011, 01:40 AM   #8
calldaffer
calldaffer's Avatar
on the tx. I had the same thought too so I binded it a buddy of mines tx and still experienced the same issue. I was thinking about just replacing the swashplate on the helicopter because things are still popping lose but I can't figure out why the forward flight comes and goes in easy mode.
Old 05-15-2011, 02:21 AM   #9
dacaur
dacaur's Avatar
Hmmm... with the battery unplugged, turn the servo gear by hand to move the servo all the way up and down... I wonder if its partly stripped....
dacaur is offline
Old 01-08-2012, 04:43 PM   #10
bowvmi2001
Was this problem fixed? I am having the same problem with my 120SR.
bowvmi2001 is offline
For Sale Four SR "MAX" Flight Packs 2 NEW Packs $308.00 worth of packs All American Batteries and Chargers Forsale/WTB 4 08-31-2011 08:21 PM
SR 120 Tx settings. Heli Jim E-Flite Helicopters 7 08-05-2011 10:32 PM
Anyone interested in a Longest Flight Contest? AEAJR Hi-Performance and Sailplanes 26 07-23-2011 03:27 AM
Help with new Extreme flight 47" yak - wants to snap to the right all the time? DanWard Beginners 3 04-05-2011 01:38 PM
Eflight electric Heli Blade Sr 120 wiring cessna Power Systems 2 01-30-2011 06:22 AM
Page generated in 0.27991 seconds with 37 queries
