Old 04-21-2011, 07:10 AM   #1
siansoft
Question Propeller Size 3 Blades and 2 Blades
Hi all
I have a motor KV = 560 and requierd propeller 15 x 8 2 blades it's look to big on my plane so I am looking to change the propeller to 3 blades propller to look smaller
What is the size of 3 blades propller I can use to my motor? and is it better to use 3 blades or 2 blades with KV 560 motors? and what is the diffrent between 3 blades and 2 blades?
Thank You All
siansoft is offline
Old 04-21-2011, 08:39 AM   #2
slipstick
Outstanding Contributor Award
The general rule is when changing from 2 blades to 3 you reduce the diameter by 10% and leave the pitch alone. So a 15x8x2 would be 13.5x8x3. That will give you effectively the same load on the motor.
2 blade props are generally slightly more efficient than 3 blades but at the size/power you're using it will make very little practical difference.
Of course if you just want a smaller prop but the same power another way of acheiving it is to use a battery with more cells. More cells, more revs, smaller prop.
slipstick is offline
Old 04-21-2011, 12:25 PM   #3
siansoft
Question
My battery is 4 cells and the prop that I use now is 12x10x2 but when use this prop my motor ,ECS 80A and the battery is getting heated too much because I think the
problem is the size of the prop and i can't increase the prop size to 15x8x2 this is the motor manufacture requirement because it will touch the ground that why I decide to use 3 blades prop so do I have to increase the battery volte to make the motor and all my electric to reduce the heat?
siansoft is offline
Old 04-21-2011, 01:31 PM   #4
slipstick
If your motor, ESC and battery are overheating on a 4S pack and 12x10 prop then a bigger prop or more volts will just make it all MUCH WORSE !
It would help if you gave some details of what motor you're talking about (we're not very good at mind-reading ). For now I'll just guess that the manufacturer probably intended the 15x8 prop to be use with a 3S battery NOT 4S.
Page generated in 0.06537 seconds with 24 queries
