Old 04-22-2011, 01:48 AM   #1
sidecar53
sidecar53's Avatar
Default Corona Receiver antenna problem
I have a brand new Corona RP4S1 receiver whose antenna inadvertently got caught in the propeller on an electric foamie I built (don't ask!). The antenna was severed in 4 places and the last section went missing. My questions are- 1) can this be repaired with regular stranded wire? 2) is wire gauge important? and 3) what is the approximate length of this antenna?
Thanks for the read and any and all responses.
sidecar53 is offline
Old 04-22-2011, 02:20 AM   #2
gyrocptr
Yes.
No. The important factor is the length. You can even connect (solder) pieces together to get the desired length; for example, see your collapsible Tx antenna.
For 72MHz, the length is about 41 inches for a 1/4 wave antenna. However, some Rx include extra circuitry to use a shorter antenna. If anyone can provide the length of the original antenna for this particular Rx, that would be the best length for the replacement antenna.
Usually the length is not too critical for 72MHz. You could simply install a replacement antenna wire, and then do the range check set forth in the instructions for your Rx. If it passes, your all set.
gyrocptr is offline
Old 04-22-2011, 02:24 AM   #3
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
View HeliScRapYard's Gallery3
Send a message via AIM to HeliScRapYard
the antennas on my corona RX's are 41 inches. i have many of them.
Need More Glue!!!
HeliScRapYard is offline
Old 04-22-2011, 01:43 PM   #4
sidecar53
sidecar53's Avatar
Thanks, guys for the answers. I'll give it a try.
Glitch / lock out problem!!!! Gee Power Systems 20 04-14-2011 03:29 AM
First Person Video -- Antenna Help, Please! Lieutenant Loughead Aerial Photography 32 03-01-2011 04:57 AM
corona synthesized receiver help CrashnBurn09 General Electric Discussions 21 02-18-2011 10:31 PM
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 12:45 PM
Futaba Receiver Not Working? Zocane General Electric Discussions 3 12-27-2010 09:25 PM
Page generated in 0.06768 seconds with 25 queries
