Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > WWI Era
Old 04-23-2011, 03:48 AM   #1
scigs30
Default Fokker Dr.1
This is my first laser cut design RC plane, and it will be electric. I have designed a couple of planes back in the day with a ruler, pencil, calculator and drafting curves and that was pretty labor intensive. Also building a plane from scratch took some time and special tools such as a scroll saw and major carving skills. Now with computers and laser cutting services, it is much faster and easier. There are a lot of short kits still out there and most fit my needs. I like the sturdy builds and plastic formed parts done for me so I don't have to mess with it. I have never owned an ARF and probably never will, but I like a lot of the designs out there. Electrifly produces some WWI electriflyers that would make great kits since the construction is straight forward and the designs are sturdy, the problem is they only come as ARF's. I contacted Electrifly asking about buying the plans and balsa parts, but they say that is not an option. I really wish these ARF companies would produce no thrills short kits for us builders. There are some great WWI designs out there that are light in structure and scale in appearance such as Tritle, Aerodromerc and Rake designs, excellent designs. BlueSkyRc has an excellent Fokker Dr.1 that fits my needs, but he currently has no kits available so I designed my own. I tried to keep the design as simple as possible and also be able to use plastic parts from the Electrifly replacement parts list. I downloaded a set of three views and traced them in Coreldraw. Then I enlarged the plans to a wing span of 29.5 inches and added the structures. I sent the design over to National Balsa and they cut the parts for me. They did a great job but I still need a few more pieces to complete my build. I am also designing a Nieuport II, SE5 and Sopwith Camel. The parts fit perfect and only took about an hour to get this far and that's using white glue. As yo can see from the picture, my design looks like the Electrilfy Fokker.....Hope they don't get upset. Also here is a picture of the Guillows Laser Cut Fokker Dr.1 I built for rubber power.
ID:	147151   Click image for larger version
ID:	147152   Click image for larger version
ID:	147153   Click image for larger version
ID:	147154   Click image for larger version
ID:	147156   Click image for larger version
ID:	147157   Click image for larger version
ID:	147158   Click image for larger version
ID:	147159   Click image for larger version
ID:	147161   Click image for larger version
ID:	147162   Click image for larger version
scigs30 is offline
Old 04-23-2011, 03:02 PM   #2
WWI Ace
triplane test pilot
WWI Ace's Avatar
View WWI Ace's Gallery4
Hey Scigs! Are ya thinking of making any of the kits available for sale? The DR1 would be cool!
Flying is just a question of money. How high would you like to go?
WWI Ace is offline
Old 04-23-2011, 03:15 PM   #3
scigs30
No plans for selling as a kit, I think Great Planes would sue me for copyright reasons If everything goes well, I will post the plans and parts and people could have them laser cut by National Balsa.
scigs30 is offline
Old 04-23-2011, 03:38 PM   #4
WWI Ace
triplane test pilot
WWI Ace's Avatar
Cool! Are you at liberty to say what it cost you to have the kit cut?
WWI Ace is offline
Old 04-23-2011, 04:46 PM   #5
scigs30
65.00 dollars for the wood and laser cut service. Here are the other designs I am working on. The Nieuport 11 is the next to go over to the cutter.
scigs30 is offline
Old 04-23-2011, 04:52 PM   #6
scigs30
Ooops forgot the pictures
Name:	Nieuport JPg email.jpg
ID:	147202   Click image for larger version
Name:	SE5 JPG Email.jpg
scigs30 is offline
Old 04-24-2011, 12:04 AM   #7
WWI Ace
triplane test pilot
WWI Ace's Avatar
$65.00 ain't bad at all! You just use the Electrifly stuff to finish it up huh? Are you using their wing struts and stuff?
WWI Ace is offline
Old 04-28-2011, 01:07 AM   #8
scigs30
Wings are pretty much done, just need to add a couple small pieces and finish sanding. I designed struts for this, but yes the Electrifly struts will work and this probably what I am going to use. Next is the tail surfaces and landing gear. Hopefully my last sheet of parts will arrive in the next few days so I can finish the fuselage. I sent my Nieuport II plans off to the cutters and that will be my next build.
ID:	147443   Click image for larger version
ID:	147444   Click image for larger version
ID:	147445   Click image for larger version
ID:	147446   Click image for larger version
scigs30 is offline
Old 04-28-2011, 05:28 PM   #9
scigs30
Built the Stab, rudder and landing gear wing this morning and will sand everything when dry. As you can see from the close up, the parts fit tight but they are a little smaller than what is show on the plans. I find this to be the norm when building laser cut kits and also the burnt wood makes a mess. Still the fit is much better and more accurate than the die cut method.
ID:	147490   Click image for larger version
ID:	147491   Click image for larger version
scigs30 is offline
Old 04-29-2011, 04:34 AM   #10
DH82Junky
Originally Posted by scigs30 View Post
... As you can see from the close up, the parts fit tight but they are a little smaller than what is show on the plans. I find this to be the norm when building laser cut kits and also the burnt wood makes a mess. Still the fit is much better and more accurate than the die cut method.
How much smaller are they coming out? Could it be the lazer cuting width (X2- for one side and then the other)?
David
DH82Junky is offline
Old 04-29-2011, 05:32 AM   #11
scigs30
1/32 of an inch, but only on some parts. I guess it could be the laser width.
scigs30 is offline
Old 04-29-2011, 11:54 PM   #12
WWI Ace
triplane test pilot
WWI Ace's Avatar
Looking good scigs!!!
WWI Ace is offline
Old 04-30-2011, 07:44 AM   #13
scigs30
I was able to work on the fuselage today and almost have this bird ready to cover. I still have to add some parts here and there, but otherwise I am getting close. This is a fast easy build, the longest part is writing notes and correcting any changes I need to make on the plans or parts. For the cowlings I would normally use paper patterns, but this time I decided to draw the parts in Coreldraw and have them laser cut, man that sure saves time. I was real lucky and the cowling barely fit, so I will enlarge them on the parts sheet. To make the cowlings, I brush on 50/50 water/alcohol to the non glued side, this causes the part to begin curving in the right direction on its own. Then I simply glue the cowling to the plane and hold in place with tape and clamps. The plastic cowl and Battery door will be held in place with earth magnets, these little suckers are strong. So far the Great Planes parts fit perfect, that also saves some time. The balsa parts weigh 5.9 oz and the Great Planes parts weigh 2.4 for a total of 8.3 oz.
ID:	147595   Click image for larger version
ID:	147596   Click image for larger version
ID:	147597   Click image for larger version
ID:	147598   Click image for larger version
ID:	147600   Click image for larger version
ID:	147601   Click image for larger version
ID:	147602   Click image for larger version
ID:	147603   Click image for larger version
ID:	147605   Click image for larger version
ID:	147606   Click image for larger version
ID:	147607   Click image for larger version
ID:	147608   Click image for larger version
ID:	147610   Click image for larger version
ID:	147611   Click image for larger version
ID:	147612   Click image for larger version
scigs30 is offline
Old 04-30-2011, 01:51 PM   #14
DH82Junky
Well, the parts may be a hair undersized from the plan, but it doesn't take away from the finished product. That is one clean, and very nicely built model. Very well done, scigs!
Old 04-30-2011, 01:54 PM   #15
WWI Ace
triplane test pilot
WWI Ace's Avatar
I like it!
WWI Ace is offline
Old 05-01-2011, 01:52 PM   #16
IndyJones
IndyJones's Avatar
Friends: (7)
Nice job!
I just maidened my Steve Shumate depron DR.1 this morning. This was maiden-round 2 actually, as I had tried yesterday and had to put it down hard and cracked it up a bit, but after repairs, I thought I'd try her again today. It was a bit breezy this morning, but I went for it anyway.
After yesterday's try, I could tell it seemed a bit tail heavy still, so I added a little more weight to the nose. It flew much better today, but was still a little bit of a handfull in the gusty wind. I got her down in one piece this time, with the typical nose over DR.1 landing in the grass, so I'll call it a successful maiden. Too much wind to try a landing on the narrow "runway" today. I'll try to have some video as soon as I can get a cameraman out there with me.
ID:	147699   Click image for larger version
IndyJones is offline
Old 05-01-2011, 01:52 PM   #17
eagle33
eagle33's Avatar
Club: Dallas Electric Aircraft Flyers (DEAF)
Where did you get the pilot?
eagle33 is offline
Old 05-01-2011, 02:04 PM   #18
IndyJones
IndyJones's Avatar
Friends: (7)
I purchased from Pete's Pilots on ebay:
http://cgi.ebay.com/RC-Model-plane-P...50102109268059
I also have this one from Pete:
http://cgi.ebay.com/R-C-Airplane-pil...item53e08cf9c6
Old 05-01-2011, 02:39 PM   #19
eagle33
eagle33's Avatar
Thanks Indi. I've seen Pete's Pilots on eBay before and considered ordering from him. But the prices quoted are in Great Britain Pounds (GBP). How do you buy, using PayPal, in U.S. Dollars?
eagle33 is offline
Old 05-01-2011, 03:02 PM   #20
IndyJones
IndyJones's Avatar
Friends: (7)
Yes, I used PayPal. No problem.
Old 05-02-2011, 05:01 AM   #21
scigs30
I have most of the build complete with some minor adjustments and final sanding. I will also go back and make the necessary adjustments and measurements to the plans and parts. The Great Planes parts fit well and you can see from the pictures my complicated wing jig, duct tape and clamps.
ID:	147764   Click image for larger version
ID:	147765   Click image for larger version
ID:	147766   Click image for larger version
ID:	147767   Click image for larger version
ID:	147769   Click image for larger version
ID:	147770   Click image for larger version
ID:	147771   Click image for larger version
ID:	147772   Click image for larger version
ID:	147774   Click image for larger version
ID:	147775   Click image for larger version
ID:	147776   Click image for larger version
ID:	147777   Click image for larger version
scigs30 is offline
Old 05-02-2011, 05:42 AM   #22
IndyJones
IndyJones's Avatar
Friends: (7)
Very nice!
Old 05-02-2011, 08:58 AM   #23
Fantastic work Scigs!
Old 05-02-2011, 05:14 PM   #24
texasclouds
texasclouds's Avatar
View texasclouds's Gallery472
Friends: (12)
wow!
texasclouds is offline
Old 05-05-2011, 06:24 AM   #25
scigs30
I did start covering today and finished the tail and fuselage. I am using True Red from Monokote, I know it is not WWI scale, but man I like the smoothness of Monokote.
ID:	147972   Click image for larger version
ID:	147973   Click image for larger version
ID:	147974   Click image for larger version
ID:	147975   Click image for larger version
ID:	147977   Click image for larger version
scigs30 is offline
Balsa USA 1/4-Scale Fokker D-VIII Conversion sgillmore Warbird Electrics 15 07-31-2014 12:02 PM
New Release! Flyzone's Micro Fokker Dr.I Triplane gklein Indoor & Micro Electric Planes 13 05-17-2011 04:55 PM
Scratch Built Fokker Dr.1 scigs30 Scratch and Kit Built Aircraft 17 05-09-2011 03:36 PM
Great planes Fokker D7 help. flyboy_fx General Electric Discussions 12 01-26-2011 05:06 PM
Fokker d-7 throttle up probs enemyace19 WWI Era 3 01-07-2011 05:57 AM
Page generated in 4.17541 seconds with 136 queries
