Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > Micro Sized Electric Helicopters > E-Flite Helicopters
Old 04-24-2011, 08:13 AM   #1
Thewyzardofdogz
Default MSR - indestructible landing gear and severely reduced tail blowout TBO
This landing gear will survive a 30 foot fall onto grass no problem. Sure it weighs a tiny bit more than stock but my heli has no problems lifting it whatsoever. I hot glued it right to the frame and unless I step on it, this landing gear will not break.
Tail blowout is virtually gone - check out the double rotor blades. I went from (full throttle) quite fast left pirouettes to just a single 1/4 turn. Insanely strong & accurate tail response, no more protruding motor shaft. Check out the flybar paddles ground from .602" to .298" - motors run at noticeably less rpm to maintain hover, huge increase in power. Tried a flybar ground to .250" - no good, wild TBE.
One thing I didn't know about the tail boom - it's supposed to be tilted at the same ten degree angle as the main shaft. Didn't know that.
This heli is so agile, stable, solid, powerful and responsive now I still can't believe it. Two months ago it floated and bobbed all over the place, couldn't maintain a steady heading for the life of it and also had terrible tail twitch. Now it works BETTER than advertised. Steel ball mod = stability.
ID:	147235   Click image for larger version
ID:	147236   Click image for larger version
ID:	147237   Click image for larger version
Thewyzardofdogz is offline
Old 04-24-2011, 11:10 AM   #2
View CHELLIE's Gallery13
Friends: (327)
nice mods, glad it flies better you, Take care, Chellie
Old 06-25-2011, 10:42 PM   #3
RaiDar
IGNORE... found it, and thanks again >>
http://www.wattflyerDOTcom/forums/showthread.php?t=61500
Sure would appreciate a photo ot two of the flybar mod. I'm having a great deal of difficulty picturing >
"... bore a 13/64" hole through it and take the steel ball from a plastic swashplate and slide it down the shaft so it is centered on the flybar..."
RaiDar is offline
Page generated in 0.25218 seconds with 28 queries
