Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Crash and Safety Forum
Crash and Safety Forum Punch something in lately? Have safety suggestions? Tell the story, share safety tips, and show the pictures here.
Old 04-30-2011, 03:05 AM   #1
flyboy_fx
flyboy_fx's Avatar
Club: Western carolina rc skyhawks.
Default Radian brown out?
I was flying at the local park today, about 250" away from me and my radian became unresponsive. It is using the AR600. Minor damage, just cracked the wing in half- surprisingly after falling 200 ft.
The RX was blinking after the flight, doesn't that mean that it lost power in the flight? The battery was at 11.7v, around there.
What do you think happened?
flyboy_fx is offline
Old 04-30-2011, 06:39 AM   #2
View CHELLIE's Gallery13
Friends: (281)
Did a tree, pole or something get between you and your plane, if yes, you might of had a Masking problem, your battery or motor could have Masked your receiver if they got between the transmitter and the receiver, if you were drawing a lot of amps , WOT in a climb, you could of had a brown out problem due to low voltage, or you could of had a bad/loose connection at the battery connection/dean and it caused the receiver to reboot, there are just so many things that can go wrong, its hard to say for sure what caused the problem, the only thing you can do is to take measures to prevent what could cause problems with a 2.4 receiver, First thing to do is to always use a UBEC, that will prevent a brown out due to low voltage, a ubec is a cheap INSURANCE POLICY with 2.4, second thing that causes problems is Masking with non full range receivers, the only thing to do here is to buy Full Range receivers, the third thing to give you problems is range problems, use full range receivers here too, and you could have a problem with your Transmitter, did the transmitter batteries get low on you, As you can see, Lots of things can go wrong, and I just listed a few things that will help to prevent problems, Hope that helps, Chellie
Old 04-30-2011, 01:15 PM   #3
flyboy_fx
flyboy_fx's Avatar
Facepalm, yea, there are big light poles where I was flying around. LOL
Old 04-30-2011, 07:09 PM   #4
Friends: (281)
Ok, on the non full range 2.4 receivers dont let anything get between you and your plane to prevent a masking problem and use a UBEC, and dont let your plane get to far away from you and you should be ok. Hope that helps, Chellie
http://www.headsuprc.com/servlet/the...iversal/Detail
remove the red battery wire on the ESC plug where it plugs into the receiver, normally you can take a needle and lift up on the plastic lock and pull the wire and connecton free, tape it up, so it can be used later if needed, use a y harness if you only have a 4 channel receiver and are using all 4 channels, plug the y harness into your receiver throttle port with the esc plug and the ubec pluged into the y harness.or if you have a open receiver port, normally you can plug the UBEC into any open receiver port.
Old 05-01-2011, 01:36 AM   #5
flyboy_fx
flyboy_fx's Avatar
The problem I think now is that it was close to power lines.
I saw a big RC at the field today comedown due to the same problem.
He flew it close to 4-5 power lines and then lost connection. He also had an AR500 so we are not sure of the real killer.
I spoke with Eric Meyers at horizon and he said that the 2.4 does not like powerlines. Basically if the powerlines are in between you and the plane.
Radian Pro... Not impressed. firemanbill Hi-Performance and Sailplanes 38 02-05-2012 05:14 PM
Modifying a Parkzone Radian Huffy01 Hi-Performance and Sailplanes 2 01-14-2011 05:41 AM
For Sale Aluminum motor mount for Parkzone Radian / Radian Pro 3530 / 3536 / 3542 series motor terrynshed Motors and Speed Controllers for sale & WTB 0 12-28-2010 08:46 AM
has any one painted thier Radian? Fulanito_uk Hi-Performance and Sailplanes 0 08-10-2009 09:32 PM
Page generated in 0.19374 seconds with 27 queries
